Old 02-27-2020, 04:09 PM   #1
MidLifer
MidLifer's Avatar
Ignition switch bug
I'm hoping that LockDoc or one of the other lock experts can help me with this one.
My battery was dying on a regular basis but I couldn't find a parasitic drain for the life of me. Then I realized that on one out of three times or so that I would shut the truck off and pull the key, the ignition switch would be in ACC instead of off. The key cylinder would only be cocked a few degrees to the left, not all the way into the ACC position. But it was the source of the current drain.
My question - is the fault with the switch or the lock cylinder?
MidLifer is offline   Reply With Quote
Old 02-27-2020, 04:43 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Ignition switch bug
It is really hard to tell which it is without changing the lock cylinder, to see if that cures it. Is your key in bad shape? (worn)
LockDoc
Leon
Old 02-27-2020, 05:38 PM   #3
Steeveedee
Who Changed This?
Steeveedee's Avatar
I'd try the lock cylinder first, since the key generally shouldn't pull out except in the "Off" position.
~Steven
Simi Valley, CA
Old 02-27-2020, 05:38 PM   #4
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Ignition switch bug
My Ramp truck 56 and 64 Impala both will let me pull the key out in ACC. I have got in the habit off turning it all the way left then back 1 notch.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 02-27-2020, 06:49 PM   #5
MidLifer
MidLifer's Avatar
Thanks all - Leon, the key is rather new. I sent my locks to a list member a few years back to have them all rekeyed with one key.
I guess it's the cylinder then. I'll buy a new one and find a local locksmith to rekey it.
Old 02-27-2020, 10:07 PM   #6
LockDoc
LockDoc's Avatar
Be careful what you get. If you buy one made overseas he may not be able to re-key it. The tumblers are not interchangeable with GM stuff on some of them.
Also if the new lock cylinder does not have the same keyway as your other locks he won't be able to do it. What year is your truck and Is there a letter stamped into your key? If your truck is a '71 it should be the letter "A".
LockDoc
Leon
Old 02-28-2020, 07:31 AM   #7
rpmerf
rpmerf's Avatar
My truck does this. Learned real quick not to just turn and pull. Instead move it by the feel of the notch until it is straight up and down. I don't even think about it anymore.
1970 C20 Custom Camper - 350, TH350
1997 GMC Suburban
1994 Acura Integra GSR
1987 Dodge Daytona Shelby Z
rpmerf is offline   Reply With Quote
Old 02-28-2020, 09:01 AM   #8
derotoreut
Roto Reuter thats the name...
derotoreut's Avatar
I used to have a '67 GTO that would allow me to remove the key while the engine was still running. It never caused any battery drain in any way. I always thought that was kind of cool to be able to do that.
~ Dan
My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232
My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394
1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt
1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project
"Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977
derotoreut is offline   Reply With Quote
Old 02-28-2020, 05:30 PM   #9
MidLifer
MidLifer's Avatar
Yep my key is an A. I was going to order the AC Delco part. It’s available on Rock and Amazon for about $10. I had looked it up for my year on Rock, would that part number have the A keyway?
LockDoc
Old 02-28-2020, 06:26 PM   #10
LockDoc
LockDoc's Avatar
No way to tell. I looked at a couple of them to see if I could see a letter designation on the key in the pictures and one of them on Rock had a "C" on it and one on Amazon had an "E" on it. It would be a crap shoot.
LockDoc
Leon
Old 02-29-2020, 01:47 PM   #11
MidLifer
MidLifer's Avatar
LockDoc
Maybe I’ll visit the local stealership and see if they can help. Would be worth a few bucks more to get the right thing.
Old 02-29-2020, 04:30 PM   #12
LockDoc
LockDoc's Avatar
If you don't find anything let me know and I'll see what I can come up with. If nothing else maybe I can rebuild yours.
LockDoc
Leon
