Old 01-13-2019, 10:03 PM   #51
mongocanfly
mongocanfly's Avatar
Re: 1963 1/2 Ford Falcon aka Martha
Haha...I've been hoping foose would show up at my shop to......
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 01-16-2019, 09:37 PM   #52
nlped
nlped's Avatar
Wiring is going really well, actually. Nothing picture worthy, but I’m plugging along
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 01-18-2019, 11:08 AM   #53
BossHogg69
motor exploder
BossHogg69's Avatar
I see what you did there... Just remember wiring isn't to be taken lightly.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 02-04-2019, 02:52 PM   #54
nlped
nlped's Avatar
Hahaha!!! I actually missed that the first time I read it!
Just for inspiration, here’s a passenger side shot
Carter
Old 02-17-2019, 09:47 PM   #55
nlped
nlped's Avatar
No pictures, but I’ve made some really good headway on the AAW harness. I also decided to abort the EEC IV EFI stuff and switched to Holley Sniper EFI like I’m using in Walter. I am selling off all the EEC IV EFI stuff to fund this change. I’ve got the Sniper EFI and an Edelbrock RPM AirGap Intake plus the Holley HyperSpark box, coil & distributor coming so I can control the timing with the Sniper kit too. Should be pretty simple to go this route.
Carter
Old 02-21-2019, 11:21 AM   #56
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Subscribing to watch the progress on this cool little car. ....
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 03-04-2019, 08:57 PM   #57
nlped
nlped's Avatar
Got some more wiring done and a gratuitous shot of the Sniper and Air Gap in place.
Carter
Old 03-04-2019, 09:01 PM   #58
flashed
Looks great .
flashed is offline   Reply With Quote
Old 03-10-2019, 01:37 AM   #59
nlped
nlped's Avatar
Originally Posted by flashed View Post
Looks great .
Thanks flashed!
I’ve got the AAW harness completed. I’ve also got the Dakota Digital gauges installed and working. Still have a few wires left on the Sniper EFI setup and then the wiring will be done. Still need to get the fuel lines, radiator & lines, and all the other new motor stuff worked out
Carter
Old 03-10-2019, 08:12 AM   #60
mongocanfly
nicely done.....
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 03-12-2019, 10:05 PM   #61
nlped
nlped's Avatar
No pictures again, but I did some more work. I got the “Falcon...Powered by Ford” cast aluminum valve covers modified to accept the FMS reusable gaskets. Also got the roller rockers installed and adjusted the valves, so the valve covers are hopefully on for the final time. The list is certainly getting shorter. In a perfect world, I may be able to crank it this weekend! #fingerscrossed#
I lied, I added a pic. The lip I’m pointing at won’t work with the Ford Motorsports reusable gaskets, so it had to go.
Carter
Old 03-13-2019, 01:20 AM   #62
Advanced Design
Advanced Design's Avatar
Martha is coming along nicely. Good progress!
Advanced Design is offline   Reply With Quote
Old 03-13-2019, 10:21 PM   #63
nlped
nlped's Avatar
Thanks Doug.
I got a couple more small projects done tonight. One of the starter bolt holes was stripped by the previous owner, so I put a helicoil in there. Then I pulled some ‘0’ gauge power & ground wire from the front to the trunk for the relocation of the battery....what a PITA!!! That’s some big wire.
Carter
Old 03-14-2019, 08:44 PM   #64
BossHogg69
motor exploder
BossHogg69's Avatar
KILLING IT!!!!
Adam
Old 03-14-2019, 09:19 PM   #65
nlped
nlped's Avatar
KILLING IT!!!!
Thanks Adam! I’m stoked to continue moving forward.
Issue tonight was that we had some HORRIBLE rain and such and my shop flooded. But nothing appears hurt...wet, but not hurt.
Carter
Old 03-14-2019, 09:27 PM   #66
mongocanfly
Rain...oh yeah...we got plenty to.....before today we have gotten 23.58 inches this yr...
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 03-14-2019, 10:16 PM   #67
nlped
nlped's Avatar
Yeah Greg,
We got 6” of rain here in a matter of roughly an hour and a tornado about 2 miles south of us. We spent several hours cutting trees for some friends that had damage from it...hence why I’m not ranting & bit€hing about my water encroachment.
Carter
Old 03-15-2019, 11:03 PM   #68
nlped
nlped's Avatar
Well, after cleaning, vacuuming and cleaning some more in the shop, I got a chance to tinker on the Falcoon.
I got some more wiring done. I got the wiring far enough to actually turn the motor over with the KEY!!!
Carter
Old 03-16-2019, 08:45 PM   #69
nlped
nlped's Avatar
Well, either my old @$$ battery or the starter that was in the previous motor...or both are crap, so I’ve gotta replace both to get the motor to turn over more than 25 rpm. I’ve got fuel, spark, 180+ psi compression, and the Sniper seems to be working appropriately, so I’m at a dead stop.
Carter
Old 03-20-2019, 03:54 PM   #70
nlped
nlped's Avatar
It isn’t the battery as I bought & tried that to no avail. So, while I wait on the starter, I tried something else I found in my collection of parts... I just didn’t like the idea of filling the tank inside the trunk. And the stock fillers are notorious for leaking...hence the clear being gone under the cap.
Carter
Old 03-26-2019, 12:57 PM   #71
nlped
nlped's Avatar
Well, it isn’t the starter or battery, so I’m going to have to do some more intense electrical research. But, it’s my youngest daughters bday/spring break, so we are doing some family bonding.
Heads up...there ain’t a leanin’ tower in Alabama.
I’m doin’ some rep’ing for Slosh Tubz international.
Carter
Old 03-26-2019, 01:27 PM   #72
Troy Sr
Troy Sr's Avatar
Cool Car!!! My Mom had one when I was little same color and all. I think it had a 4 or 6 cyl. She traded it to my grampa for his '65 Fairlane 500 I'd say she got the best deal!!!
Take Care
Troy
Troy Sr is offline   Reply With Quote
Old 03-26-2019, 04:47 PM   #73
nlped
nlped's Avatar
Exactly why I chose this car! My mom’s first car was an exact copy of this one!!!
My dad helped me put me the new motor in it.
Carter
Old 03-26-2019, 06:26 PM   #74
Advanced Design
Now that is a cool trip! And a great opportunity for making family memories. Enjoy!
Old 04-06-2019, 11:16 PM   #75
nlped
nlped's Avatar
Sounds good to me....
https://youtu.be/-fxiSIAps5U
https://youtu.be/7x4Ijtkxl1c
Carter
