Old 11-17-2017, 01:10 PM   #1
davischevy
davischevy's Avatar
Cleaning the rust out of my gas tank
I'm trying something I have heard about, but never tried. WE put some 1 inch rocks and three cans of rust converter in this tank and let it rip. We will let it spin a couple of hours. Of course two hours backhoe time will pay for a new tank but this one was just sitting there today.
I will let you know how it works.
other Larry
Build thread, Arkansas K10
https://67-72chevytrucks.com/vboard/...=755797&page=5
The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless.
davischevy is offline   Reply With Quote
Old 11-17-2017, 01:27 PM   #2
72 tigger
72 tigger's Avatar
Re: Cleaning the rust out of my gas tank
Sounds like a plan- should work
72 tigger is offline   Reply With Quote
Old 11-17-2017, 01:49 PM   #3
Boog
laying low
Boog's Avatar
“ if you’ve ever strapped an old gas tank to your backhoe wheel to give it a spin cycle you might be a redneck.”
Now we know.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 11-17-2017, 02:30 PM   #4
LockDoc
The Older Generation
LockDoc's Avatar
I would check it after 30 minutes. I think two hours would be too long.
LockDoc
Leon
Old 11-17-2017, 02:33 PM   #5
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Now we know.
here's your sign......
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 11-17-2017, 03:07 PM   #6
Boog
laying low
Boog's Avatar
It is genius though.
Boog
primer is finer
Old 11-17-2017, 03:22 PM   #7
Ol Blue K20
X2, I'll give ya that.
Dale
Old 11-17-2017, 06:20 PM   #8
scampr
I was thinking something similar, was going to put some sand in mine and strap it on the front of our screener when we are screening loam. It vibrates and i was thinking it would be like a gentle sandblasting???
scampr is offline   Reply With Quote
Old 11-17-2017, 08:59 PM   #9
davischevy
davischevy's Avatar
Yes, red neck spoke here.
After two hours, we had sludge. We rinsed it out with water and left it to dry over the weekend.
Rotten part is we have a beautiful non EEC tank, but this is an EEC truck.
other Larry
Old 11-17-2017, 09:03 PM   #10
100%Chevy
I also have a back-hoe.And,that's a good idea!
I was cleaning an old 20 gallon boat tank a while back and got about 200,3/8" steel nuts out of it!
It was pretty clean inside after I got it emptied out!
Mike.
100%Chevy is offline   Reply With Quote
Old 11-17-2017, 11:51 PM   #11
Ol Blue K20
Mike.
Hmmmm.....redneck maybe, but if it works.....what the he!!, I learned something. ...
Dale
Old 11-18-2017, 12:35 AM   #12
wilkin250r
wilkin250r's Avatar
I've done something similar to many motorcycle gas tanks. I use brass chain because the brass won't spark, and the tanks are usually small enough to shake by hand.
I usually use just normal water, it makes rinsing really easy, and then a final rinse/shake with rubbing alcohol (the alcohol will pull the water).
I know a little about cars, but if you have a question about electricity or sport quads, I'm your man!!!
wilkin250r is offline   Reply With Quote
Old 11-18-2017, 12:42 AM   #13
davischevy
davischevy's Avatar
Thanks for the tip. I can strap MC tanks to the front wheel.
other Larry
Old 11-18-2017, 07:54 AM   #14
I never knew Caterpillar made a gas tank washing machine.
Old 11-18-2017, 10:57 AM   #15
Grandpas 72
I have been told to use a bicycle chain. I like the brass chain idea better. ��
Grandpas 72 is offline   Reply With Quote
Old 11-18-2017, 07:15 PM   #16
Greg58
Greg58's Avatar
Arky-Engineering!
I like it!
Greg
________________
1970 GMC Sierra Grande, 2500 133" wb, 402, 4spd.
2007 GMC 3500 SRW 4x4, Crew cab, Duramax/Allison. (Sold}
1987 Chevy Suburban 2500, Silverado, 2wd, 454, t-400
2023 Chevy Silverado LT 3500, crew cab, longbox, 4x4 Z-71 Duramax.
Greg58 is offline   Reply With Quote
Old 11-18-2017, 07:39 PM   #17
davischevy
davischevy's Avatar
The machines are special order. This one was mistakenly used to dig ditches and load trucks for over 12 years. It is at the shop to get the front axle and rear swing pins rebuilt so I had time to make use of the tank cleaning capabilities it was meant for.
other Larry
Old 11-18-2017, 07:52 PM   #18
Are they available in white t match my drier or only Caterpillar yeller?
Old 11-18-2017, 07:54 PM   #19
davischevy
davischevy's Avatar
Sometimes you can find them in white at government surplus sales.
Caterpillar loves their yeller. The paint is what makes them so expensive.
other Larry
Old 11-18-2017, 08:58 PM   #20
Looks like ochre to me
Old 11-18-2017, 09:09 PM   #21
franken
That's great!
I made a frame from 2x4s, a stand and sat around drinking beer while spinning the tank with some chain inside. By the time I fell off the chair I would have figured it was clean--had I been able.
Old 11-18-2017, 11:16 PM   #22
davischevy
davischevy's Avatar
Thanks for the tip. I need to do some touch up and I have some Cat paint. I'll check it out.
other Larry
Old 11-18-2017, 11:22 PM   #23
davischevy
davischevy's Avatar
Originally Posted by franken View Post
That's great!
WE had the same thing happen to the operator of this backhoe. He hit the ground hard when he took that last step.
other Larry
Old 11-18-2017, 11:31 PM   #24
100%Chevy
Well,I painted mine Caterpillar yellow!
And,I need to put new pins and bushings in the digger bucket too!
I've busted my butt on the bottom step a few times.It moves when you step up on it.
Mike.
Old 11-19-2017, 09:51 PM   #25
mike16
you may have bought some time but your in the market for a new tank too.
mike16 is offline   Reply With Quote
