Old 10-10-2012, 04:49 PM   #1
|ow|ife
|ow|ife's Avatar
swapping automatic trans. to manual with 4wd
Hi Guys,
I am going to go look at a 75 Blazer that has a factory 400. The owner wasn't sure what transmission was bolted to it, but it is an automatic and is starting to slip. Now, I would prefer to swap in a 3 speed manual if I were to buy this truck. And I know that since it's a 400 (not a 402) the motor is an SBC, so the 3 speed would bolt right up.
The only thing I don't know is how the transfer case figures into the equation. I've always worked on 2 wheel drives. I know some modern trans integrate the transfer case into the trans, but I also know that people like to put TH400s into trucks with 4wd so I am thinking the Trans cases are stand alone units here
My question is this: Does the 4wd capability affect what transmissions I can swap in? And btw, this is a pic of the potential new project--owner wants $850 firm
it's not what you buy, it's what you build
use your skills, not your wallet
|ow|ife is offline   Reply With Quote
Old 10-10-2012, 05:56 PM   #2
68Timber
I know the pieces fit
68Timber's Avatar
Re: swapping automatic trans. to manual with 4wd
An SM465 should be a bolt in, the 4-speed w/granny low. You'd have to have the correct adapter for the xfer case in the truck, but you can get them on ebay pretty easily.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 10-11-2012, 07:36 AM   #3
Keith Seymore
Keith Seymore's Avatar
well...plus, you'd have to hand the clutch pedal and associated hardware, which makes it a little bigger deal....
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 10-11-2012, 08:16 AM   #4
68Timber
68Timber's Avatar
I figured he knew he'd need the third pedal. I've got everything to swap one into my 85, still on the fence though.
John
74 Honda Z50 build
Old 10-11-2012, 09:04 AM   #5
Berg
Thats a pretty good deal, I'd jump on it! The SM465 4 speed manual is considered by some to be a 3 speed with granny low since 1st gear isn't synchronized. It was a factory option in these truck. Your best bet is to replace the transmission and transfer case as an assembled unit since the case that is currently in the truck is most likely going to be 27 spline input. The early Muncie SM 465's used a 10 spline input shaft with a 10 spline output shaft and required a collar to adapt it to either an NP 205 gear driven transfer case or an NP 203 chain driven full-time case with a differential built into it. In the early 80's GM made both the transmission and transfer cases stronger by eliminating the 10 spline output and going to a 32 spline which is much stronger. It also drastically reduced slop caused by wear from the coupler. TH400 automatic transmissions used the same 32 spline transfer cases as the later 4 speeds. In 1985 GM started using a hydraulic slave and master cylinder externally mounted on a bellhousing. From 1973-1984 this body style truck had a mechanical clutch linkage. If this Blazer has the original transmission it is most likely a TH350. You need to get the right adapter to bolt the transmission and transfer case together. If you have a 203 case this is also a good chance to upgrade to a 205. Cutting the hole in the floor for the shifter is no big deal either since the transmission tunnel unbolts out of the truck.
Make sure you get an externally balanced 168 tooth flywheel for an 11" or 12" clutch. The SM 465 uses a larger bellhousing with the Chevy bolt pattern but it has a larger hole for the input bearing retainer. A standard car bellhousing can be opened up by a machine shop but these things are a dime a dozen out there and really shouldn't be modified unless you really need to.
1970 Chevelle SS396
1984 K5 Blazer -First Truck!
1999 Big Block K2500 'Burb
Berg is offline   Reply With Quote
Old 10-12-2012, 12:59 PM   #6
bmchevy1979
bmchevy1979's Avatar
only thing I dont see mentioned is that the 400sbc is an externally balanced engine so in order to make it right you either have to have a counter weight that goes in between the flywheel and the crank or have the correct flywheel for a 400
Counter weight
http://www.ebay.com/itm/New-SBC-Chev...9ffbee&vxp=mtr
Flywheel
http://www.ebay.com/itm/New-Flywheel...6548d7&vxp=mtr
<Brandon>
1974 Chevrolet K5 Blazer 350sbc/SM465/NP205, dana44 front, corp 14bolt rear with 4.10s and a powertrax locker, custom rear bumper 400sbc in the works.
1981 GMC C1500 stepside 250i6, 3spd, 12bolt with 3.08s 2.5/4drop on 15x10 with 275/50r15
81 GMC C3500 cab-chassis dually with utility bed 350sbc, Sm465, 14bolt with 4.10s nv4500 getting ready to go in
1979 Chevrolet K5 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434096
1976 Chevrolet C10 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434195
bmchevy1979 is offline   Reply With Quote
Old 10-12-2012, 01:46 PM   #7
84 400
Sb 400 club
84 400's Avatar
I did the swap 2 years ago and have since replaced the transmission again... It is a heavy trans so make sure you have one that was known to be good. I did the swap in a 77 k10 so Everything except you needing the 400 specific flywheel should be the same. I actually just make a vid for some guy on youtube and it might help you too. Keep in mind I opted for the hydro clutch because I wheel this truck and the Z bar can pop out and kill your leg after a day on the trails.
If you don't already have an np205 transfercase swap that at the same time. you will need a longer drive shaft and shorter shaft but you get gear drive transfercase.
Also Go for the 12 inch clutch.
1984 chevy c10, built 400sb,.(SOLD)
77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363
1956 Willys Wagon (327 chevy) Project (Now Buick 225)
1980 Corvette L-48 4 speed
1992 Mustang GT built 5.0 5 speed
1985 C10 LWB Sold
1982 K10 SWB plow truck Parted out
1986 D30 M1028 fire brush truck Parted out
84 400 is offline   Reply With Quote
Old 10-12-2012, 04:38 PM   #8
84 400
Sb 400 club
84 400's Avatar
here is the auto to stick vidvid link Kinda shakey but you get the general idea
http://www.youtube.com/watch?v=5LERy...ature=youtu.be
1985 C10 LWB Sold
