10-06-2018, 05:20 PM | #1 |
L33 5.3 Oil pan for '66 Stepside
Hey yall, so am getting ready to LS swap my '66 stepside, and have confused myself with oil pans. lol so i know Holley 302-1 and 302-2 work, but well holley is expensive. So trying to find an F-Body pan that works.
Is there a certain brand, or pan that people are using, if so, is there a link to it? Or any links to good F-body pans would be appreciated. Thanks. |
10-06-2018, 10:22 PM | #2 |
Re: L33 5.3 Oil pan for '66 Stepside
Is your truck lowered at all?
Mine is lowered about 4” front, spindles and springs, I have the truck pan and I have no issues with clearance. Hangs below cross member about 1.5” or so.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
10-06-2018, 10:33 PM | #3 |
I just put a c6 pan on mine...it was the shallowest of the factory pans...about 4-3/4" deep...
10-12-2018, 06:10 PM | #4 |
I just did a pan swap, mild 4 inch front drop, 60/17 tires. Went with the GMPP "H3/hot rod/muscle car" pan kit. $200 shipped fast from Summit
Comes with everything needed, simple easy swap. Hangs down even with cross-member, plenty of ground clearance, clears top of cross-member with room to slide fingers underneath. Keep in mind any bolt holes on pan that may or may not line up with your tranny bellhousing bolt holes. 1 didn't on mine, but I'm ok with that, others bolted up fine. Pics in recent post in my build thread. Or going with an F body pan should be fine, just be sure to get all the parts - windage tray, p/u tube, seals, gasket etc. I have '06 L33, only 86k miles . The L33 is awesome
- long term project '68 C10 true shortbed! Resto-mod. LS swap. Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=769919 "I've still kept this project truck when anyone else would've given up and sold it as is. Giving up is easy, staying the course is part of life's journey" ___________________________________________ '68 C10 true shortbed, LS swap restomod. '03 Z71 daily, '63 AMC Rambler V8 survivor |
10-16-2018, 10:24 AM | #5 |
I swapped an L33 from an '05 Silverado, with BTR Stage III cam, LS6 blue beehive springs and Speed Engineering Headers. With 2.5" drop spindles and the torsion bars turned down a bit, I was more comfortable with the F-body pan also as it sits above the cross member.
