Old 06-16-2019, 11:04 AM   #1
Marty68
Help identify my junk
I have a 51 gmc. With a transplanted small block I believe 283. Can you pros help pin down more exactly what it was from.
Thank you
Marty
Marty68 is offline   Reply With Quote
Old 06-16-2019, 11:17 AM   #2
Marty68
Re: Help identify my junk
More pictures.
Old 06-16-2019, 11:37 AM   #3
Warrens69GMC
Warrens69GMC's Avatar
Looks to be a 283, powerglide equipped
Old 06-16-2019, 11:57 AM   #4
Marty68
bellhousing number 6263756... ?12" truck". not bolted to existing bellhousing crossmember
Old 06-16-2019, 12:51 PM   #5
The Rocknrod
Moderator
The Rocknrod's Avatar
Suffix code is DE, it's a 1967 283, 195hp normally "was" for a Powerglide.
Old 06-16-2019, 01:21 PM   #6
68Gold/white
My 67 Bel Air had a 283 in it, I spent money on it, ran it another 175,000 miles in that car...
67 283's were only available with the 2 bbl carb. It was last year for the 283. Mine had a cast crank in it. My engine builder said he had never seen a cast 283 crank...hardly matters. My 283 in it's original form did not have a bolt to hold the balancer on, only the press fit held it on...when the engine was rebuilt, my engine builder sent the crank to another friends machine shop to drill and tap the crank snout for a bolt...
I remember the decal on the air cleaner of my engine, stated, 195 HP...
68Gold/white is offline   Reply With Quote
Old 06-16-2019, 03:11 PM   #7
The Rocknrod
Moderator
Built in Flint Michigan.
Old 06-16-2019, 06:38 PM   #8
Marty68
so the "truck" bellhousing didnt come with the engine?
any way with these castings to know if it is car or truck? or does it even matter?
Old 06-16-2019, 07:30 PM   #9
geezer#99
geezer#99's Avatar
It’s truck.
Look here.
https://www.4speedconversions.com/460486_1.html
Old 06-17-2019, 04:44 AM   #10
Marty68
so 67 283 built in flint Mi. possibly from a truckl were the power pak heads the only available heads or is there clues there also?
Old 06-17-2019, 07:38 AM   #11
The Rocknrod
Moderator
You'd have to remove a valve cover and take a pic of the casting number and date code. But from your pic I probably make out - "Narrow triangle over rectangle c/n 520, 896, 1958 and up 283 Power Pak and 1957-'60 FI. 9.25:1 CR, 1.72" x 1.50" valves, 59cc nominal chamber volume. Could be used on a 305 but no accessory holes and has unhardened exhaust seats." - https://www.crankshaftcoalition.com/...identification
Old 06-17-2019, 08:49 AM   #12
geezer#99
geezer#99's Avatar
Not a 67.
Could be 58 or 62.
http://www.nastyz28.com/gm-chevy-cod...s-suffix-4.php
And casting code says 57-66.
https://www.mortec.com/castnum.htm
Old 06-17-2019, 10:27 PM   #13
Marty68
clear as mud.
i will get valve cover gaskets and open it up.. not tonight though stay posted
