Old 09-29-2009, 08:26 PM   #1
shilo
shilo's Avatar
Welding my 14 bolt and sprung a leak!
I was re-doing my traction bar on my jeep's 14 bolt and it now have a small drip out of the press joint between the tube and center section. Damn. And on top of the housing a small bit of oil pulled up im guessing thru some porosity. No biggy but i thought id share it with yall.
71 swb 4x4, 37" Iroks, t400/205 496
77 CJ-7, Narrowed Dana 60 Lockrite, 14 Bolt Spool, 4.56 gears, 39.5" boggers. 360 t-18/d20
shilo is offline   Reply With Quote
Old 09-29-2009, 11:12 PM   #2
dammitmitchell
the pollock
dammitmitchell's Avatar
Re: Welding my 14 bolt and sprung a leak!
i would make man love to that jeep...
just a FYI... dont be offended
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
Old 09-29-2009, 11:19 PM   #3
shilo
shilo's Avatar
haha. no offense taken. Its a slow build. Between the 496 for my 71 and this thing, im pretty strapped for cash and time but mainly my patience.
Old 09-29-2009, 11:31 PM   #4
2tons of fun
awesome, you just managed to warp the housing fit enough to leak oil, congratulations
2tons of fun is offline   Reply With Quote
Old 12-01-2009, 12:45 PM   #5
turp mcspray
turp mcspray's Avatar
Is that a homemade bar? It kinda looks like an Off-Road Design bar.
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 12-01-2009, 03:06 PM   #6
fun in dirt
fun in dirt's Avatar
I think it's just the 14 bolt crying because it's now wasted under a Heep...oops typo, I mean Jeep
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432
'85 K30 "Big Nassy"
'06 3500 Duramax ...tow truck
'06 Silverado SS...DD
'06 C1500 WT...DD
'07 Classic C1500 WT...DD
Built & sold cause can't keep 'em all:
'72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190
'55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938
'69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541
'86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619
fun in dirt is offline   Reply With Quote
Old 12-01-2009, 08:03 PM   #7
shilo
shilo's Avatar
it is the ord bar. And jeeps need 14 bolts too!
Old 12-04-2009, 10:03 AM   #8
OLDCHEV4X4
OLDCHEV4X4's Avatar
Since we are on the subject, Has anybody ever welded the tube to the housing?
I know one is steel and one is cast, but would it be stronger if done correctly?.......Pre heat...Post heat....etc.
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 12-04-2009, 12:05 PM   #9
rwolf9653
more ideas than money
rwolf9653's Avatar
My understanding is that it all has to do with the post heat/cooling rates between the two metals. Petersons 4wheel did a write up on it a couple of months ago, I'll have to flip through and see if I can find it.
Randy
1948 Chevy 3100 5 window
1966 Chevy C30 Dually
1967 Chevy K10
1972 Chevy K20
1972 Chevy C10
1972 Chevy K5 Blazer
1987 Chevy V10
2003 Chevy Suburban
rwolf9653 is offline   Reply With Quote
Old 12-06-2009, 01:55 PM   #10
cheepin
Weld the tube to the diff.14 bolts are known for spinning the tubes.Just pre and post heat.Using a high nickel rod doesn't hurt either.But many have just used a Mig.
1984 1ton 4x4 crew cab dually 6.2 diesel,465,205,D60,D70,1987 3/4ton 4x4 suburban 5.7 FI350,TH400,208,1985 CJ-7 FI406,465,205,D60,FF14, 1970 Jeepster 350,465,205,D44,FF14,
cheepin is offline   Reply With Quote
