Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 04-17-2021, 09:19 AM   #1
65chevysub
65chevysub's Avatar
Color engine bay wiring diagram for an 84
Does anyone here have a color wiring diagram they can post here, for the engine bay on an 84 GMC?
I'm trying to hook up an aftermarket tach, but I'm not getting anything. I grounded it to the dash, connected the red wire to the only "IGN" terminal I can see, and plugged the green wire into the "TACH" port on the distributor cap. I found out the white wire coming out of the TACH port went to the plug for my ac.
Thanks in advance
65chevysub is offline   Reply With Quote
Old 04-17-2021, 04:53 PM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Color engine bay wiring diagram for an 84
I've only seen B&W - http://forum.73-87chevytrucks.com/sm...?topic=11766.0
Old 04-19-2021, 10:47 AM   #3
65chevysub
65chevysub's Avatar
Thanks Rocknrod. That's all I've ever seen too.
Old 04-20-2021, 12:05 PM   #4
VetteVet
Msgt USAF Ret
VetteVet's Avatar
This may or may not help.
https://www.youtube.com/watch?v=DjpV2xvA-b4
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 04-21-2021, 08:24 AM   #5
MT65
GM is big on color coding, violet for starter , pink for ignition, etc, looks like you have an HEI distributor...check another GM vehicle for the tach signal color code and you will probably have your answer...most all the aftermarket wiring harnesses are GM color coded...if my memory is correct, it’s a white wire
MT65 is offline   Reply With Quote
Old 04-22-2021, 12:40 PM   #6
Scott91370
Scott91370's Avatar
Tach is white but if it doesn't already go from the distributor to the firewall you'll have to run one. My harness didn't have a white wire in it.
Scott
1982 GMC Sierra
Scott91370 is offline   Reply With Quote
