01-09-2012, 06:06 PM | #1 |
steam lines
What's the deal with running the steam lines back into the water punp?....any more info on this?
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
01-09-2012, 08:29 PM | #2 |
Re: steam lines
Running the steam line into the pump eliminates the connection back to the radiator or into the radiator hose itself. It's just a shorter route to run the steam line. This Also allows the use of stock radiators and not having to purchase adapters that go in the radiator hoses.
Posted via Mobile Device |
01-09-2012, 08:52 PM | #3 |
Re: steam lines
ok thanks......now I need to know more about the actual proceedure.
01-09-2012, 09:52 PM | #4 |
Re: steam lines
I usually go to lowes and purchase a barbed fitting. Then drill and tap the water pump on radiator return side of pump ( top radiator hose area). This will draw steam out of line. Then run hose from head vent to barbed fitting.
01-09-2012, 09:58 PM | #5 |
Re: steam lines
any pics?
01-09-2012, 10:03 PM | #6 |
Re: steam lines
I'll post pic on Tuesday.
01-09-2012, 10:09 PM | #7 |
Re: steam lines
thanks alot man.
01-10-2012, 12:20 AM | #8 |
meowMEOWmeowMEOW
Re: steam lines
I got lazy, just used a T in the heater line and plugged mine in there. I just made just to do a really good system bleed first, since realistically with a full bubble-free cooling system, the steam lines don't serve a huge purpose.
01-10-2012, 12:31 AM | #9 |
Re: steam lines
so the line goes into one side of the tb, out the other and the to the rad?
01-10-2012, 12:09 PM | #10 |
meowMEOWmeowMEOW
Re: steam lines
I bypassed the TB, thats actually a TB heating function for cold days....really freaking stupid (wait you live in Canada...it might be important lol). I blocked the tb off, and went from the steam vent in the head, to my T in the heating line.
01-10-2012, 01:38 PM | #11 |
1965 Chevy C10, 2005 4.8L/4l60
Re: steam lines
BR3W, what is the size hose you used? Mine are blocked front and back. I havent noticed any issues but I also dont drive my truck often or long distances either.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
01-10-2012, 02:49 PM | #12 |
Re: steam lines
I usually just have a fitting brazed in the radiator tank and run the line to it. My theory is that if I'm in someplace like Chickenfart nowhere and the water pump craps out on me, I can go to any auto parts store and get a new one and slap it on with the regular set of hand tools I pack for long trips. I don't have room for drills and tap and die sets in my cars.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
01-10-2012, 06:30 PM | #13 | ||
Re: steam lines
BTW, Hows it goin John. Quote:
01-10-2012, 06:33 PM | #14 |
Re: steam lines
ok, thanks. its going good, how about you?
01-10-2012, 07:40 PM | #15 |
Re: steam lines
I ran mine back to the radiator. Works fine. I had the radiator cleaned and they welded the bung in for me.
1950 Chevy 3100 Ramp Bed 1-ton http://67-72chevytrucks.com/vboard/s...d.php?t=749386 1965 Chevy Step Side 1971 Chevy Short Wide Bed http://67-72chevytrucks.com/vboard/s...d.php?t=277191 1971 Chevy Chevelle 1972 Chevrolet C-30 1 ton 2002 Winnebego Class A MH Ford E-550 Chassis V-10 2005 Dodge Ram 2500 5.9 Cummins 2008 GMC Denali 2020 Jeep Wrangler Unlimited Rubicon |
01-10-2012, 07:46 PM | #16 |
Re: steam lines
sorry but thats the look I'm trying to get away from...I've seen it somewhere they've drilled and tapped a hole in the water pump....but now I cant find it.
01-10-2012, 09:18 PM | #17 |
Re: steam lines
Here's a couple of pics of the hose in my car. I have done a few this way. Sure if you are out driving and water pump goes out you may have to cap it off or another alternative method. But, in my personal opinion ( and everybody has their own) I like the look of this versus the line going to the radiator. Hope these help.
01-10-2012, 09:27 PM | #18 |
Re: steam lines
that's what I'm talkin bout.....does it matter where you drill the hole? the one I saw was to the right of this one..
01-10-2012, 09:34 PM | #19 |
Re: steam lines
I would say that as long as the hose enters on that side of the water pump impeller that it should be fine.
01-10-2012, 09:45 PM | #20 |
Re: steam lines
Here's another pic from my 1969 chevy truck install. This was before completion.
01-11-2012, 06:00 PM | #21 |
Re: steam lines
You may look at picking up a LS swap book from Amazon.ca, they all cover the basic's to the swap and may help with some of the detail's.
01-12-2012, 05:29 PM | #22 |
Re: steam lines
Heres a dumb question but, So with the last picture posted, do you not worry about water getting in the steam line? The only reason I asked is because on my last ls conversion I tapped into the water pump for my tempsending unit.
01-12-2012, 06:32 PM | #23 |
Re: steam lines
Coolant does flow through it, it's not just steam in it.
01-15-2012, 09:27 PM | #24 |
Re: steam lines
I drilled and tapped my water pump on the flat part on the front and installed a 90 degree brass hose fitting.
My build project http://67-72chevytrucks.com/vboard/s...=1#post4158671 |
01-16-2012, 11:30 AM | #25 |
Re: steam lines
I thought it was supposed to be mounted higher than the steam lines?...are you still running it through the throttle body?
