Old 12-04-2017, 07:53 PM   #1
bbluma
Procar Seats in 66'
Has anyone put a set of procar seats in their truck? Im looking at the lowback vinyl ones, and just wanted to see if anyone has done it before. These are the seats and brackets for it. The brackets are the universal ones, but just curious if anyone has experience. Thanks in advance!
https://www.summitracing.com/parts/s...-51l/overview/
https://www.summitracing.com/parts/sca-81000/overview/
bbluma is offline   Reply With Quote
Old 12-05-2017, 12:27 AM   #2
Captainfab
60-66 Nut
Re: Procar Seats in 66'
Not a '66 but pretty much the same as far as seat fitment goes.
http://www.67-72chevytrucks.com/vboa...d.php?t=444502
Old 12-05-2017, 09:45 AM   #3
Rich 5150 69
Rich 5150 69's Avatar
Video of John`s `65 with procar seats..https://www.youtube.com/watch?v=S5-u4a7hTf4 all the images that are left after the photo bucket snafu...
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 06-30-2018, 06:23 PM   #4
53chevyforever
53chevyforever's Avatar
I just installed the Summit procar bucket seats in my 66 C10. I used the universal 81000 Summit seat brackets. I found a 89 bench seat frame and used the
outer pieces for my seats. I am 5' 8" so it worked fine for me. I made the
inner bracket 1/4 shorter than the outer to try and level the seats. Seems
to be right on. My gas tank is behind the seat. I will be moving it soon.
Here are a couple of pics. Tim
53chevyforever is offline   Reply With Quote
Old 06-30-2018, 06:28 PM   #5
53chevyforever
Here is another.
Old 06-30-2018, 06:40 PM   #6
Heater63
Heater63's Avatar
I tried one in my 63, and thought it was about 10% undersized and lightweight. A good seat at a great price, but it seemed too small.
I ended up with high quality seats from Larry Dennis Company in Ft. Worth, covered by Fuller Upholstery in Haltom City.
292 + TKO500
Heater63 is offline   Reply With Quote
Old 07-01-2018, 12:09 AM   #7
markeb01
Senior Enthusiast
markeb01's Avatar
Here's what mine looked like with the stock Procar seats installed, and later after my son whipped up some diamond stitched covers for them that I installed and added buttons to: My seats are about 15 years old now and every bit as comfortable as when first installed.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 04-03-2019, 03:51 PM   #8
53chevyforever
Originally Posted by 53chevyforever View Post
Here is another.
Here is an updated shot of my procar seats....
Old 07-10-2019, 10:14 AM   #9
Tommyups
I like those seats. In your updated photo it looks like you moved your gas tank and you have a speaker behind the seats?
Tommyups is offline   Reply With Quote
Old 07-10-2019, 03:41 PM   #10
53chevyforever
Yes...moved the gas tank and made a pattern out of card board that goes all the way across the back and behind the lip of the door facing....if you do it right
you can slide it behind one side and then behind the other door covering all. I used blocks of wood to space it out and keep tension so it holds against the back of the door facings...worked out great. I then cut the pattern for the top and used velcro so can take off when I need to.
Old 07-10-2019, 04:03 PM   #11
The Rocknrod
Moderator
The Rocknrod's Avatar
53chevyforever - That bad boy looks fantastical. Still want to know what arms rests those are and if they fit the stock door holes.
Old 07-10-2019, 07:40 PM   #12
53chevyforever
The armrest are 66 chevelle...can be bought alot of different places and
in different colors...the holes are different so have to do some measuring
and either cover door panel or fill in and repaint....Tim
The stainless strips came from an older impala...maybe from
the rear.
