Old 03-13-2018, 04:30 PM   #1
forestb
forestb's Avatar
break peddles peddle question
I know that the brake peddles on this trucks are vary high but mine does not seem to even enguage the brakes until the peddle is about half way down.
I have front cpp discs and rear drums with a captonfab booster bracket. they stop the truck fine but it is a little bit of a pain. I have the correct proportioning valve for a disk drum setup. Will shortening the rod and lowering the peddle help? Or will I just be stepping around the problem?
forestb is offline   Reply With Quote
Old 03-13-2018, 06:08 PM   #2
TheBrewery
TheBrewery's Avatar
Re: break peddles peddle question
I'm chasing down brake problems too
If you shorten the pedal won't that just put the effective area out of reach? Have you checked the clearance between the booster and the master? It should be 0.25 - 0.75 mm of clearance, but if there is more it will cause what you are talking about. There also could be air in the setup that is compressing before the fluid moves. Have you tried rebleeding?
Mike
1960 C10 Short Step 235 w/ 3 on the tree
1999 Mazda Miata <- Track Car
2016 Chevrolet Colorado z71
2016 Chevrolet Traverse - Wifes Car
2014 Honda CBR500R <- Also A Dust Collector
2009 Suzuki GSXR600 <- Stolen
TheBrewery is offline   Reply With Quote
Old 03-13-2018, 06:28 PM   #3
forestb
forestb's Avatar
Do you mean clearance from the push rod or between the surfaces that come together when it is bolted together. No I have not tried rebleeding but when I took it to the mechanic to check them out he said they were fine. Maybe it is low on fluid.
I wonder if there is a way test to see when I start to get brake pressure maybe the rod is to short.
Old 03-13-2018, 09:06 PM   #4
TheBrewery
TheBrewery's Avatar
So check out this video, https://youtu.be/rYYzPIGoxfY?t=1915, It shows you how to measure the booster pin and MC piston to ensure they are "set" correctly.
Mike
Old 03-13-2018, 09:27 PM   #5
jayoldschool
Moderator
Do you have the correct DISC drum master as well?
jayoldschool is offline   Reply With Quote
Old 03-13-2018, 09:45 PM   #6
forestb
forestb's Avatar
I believe so. It is a dual cylinder.
Old 03-13-2018, 09:54 PM   #7
forestb
forestb's Avatar
here is the best photo I have of it.
Old 03-13-2018, 11:16 PM   #8
TheBrewery
TheBrewery's Avatar
That looks like the corvette style dual pot, it is equal but you have a proportioning valve so you should be fine there.
Mike
Old 03-14-2018, 12:25 AM   #9
Captainfab
60-66 Nut
Is your booster pushrod in the original hole in the pedal or did you drill a new hole 1" lower?
Old 03-14-2018, 10:38 AM   #10
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Yes, what he said. This is one of the most common mistakes people make. The pedal ratio is different between manual and power brakes. Power needs to be 1" lower than where a manual pedal would hook too. If not, your pedal will engage way too low and the brakes tend to be touchy.
Buddy did his truck conversion and didn't believe me. Had the same problem of low pedal engagement and being touchy. Finally drilled a hole 1" lower and the brakes were perfect.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 03-14-2018, 10:52 AM   #11
TheBrewery
TheBrewery's Avatar
Does this apply to the 1960?
Mike
Old 03-14-2018, 11:29 AM   #12
forestb
forestb's Avatar
I have heard of that but never done it. I should give it a try.
Old 03-14-2018, 03:36 PM   #13
The Rocknrod
Moderator
The Rocknrod's Avatar
Brake pedal ratio - https://techtalk.mpbrakes.com/how-to...ng-pedal-ratio
Old 03-14-2018, 03:49 PM   #14
forestb
forestb's Avatar
Thanks. This is always something I have thought about doing but never got around to.
Old 03-14-2018, 06:01 PM   #15
verdell
verdell's Avatar
Yes, it does apply to the '60. Helped my brakes quite a bit.
verdell is offline   Reply With Quote
Old 03-14-2018, 09:52 PM   #16
TheBrewery
TheBrewery's Avatar
Sorry to Hijack the thread, I am using Captinfab's bracket, I did drill a hole for the clutch master but not the booster. I don't think the bracket would fit any lower...
Mike
Old 04-02-2018, 04:27 PM   #17
forestb
forestb's Avatar
So i lowered the hole but have not gotten a chance to drive it yet. But what I was wondering while I was laying on my seat pushing the break peddle down with my hand I heard what sounded like air coming out of where the rod comes out of the booster. But it might just be air being pushed out of the rubber cup that covers where the rod goes into the booster. Is this normal?
Old 04-02-2018, 05:24 PM   #18
The Rocknrod
Moderator
While the truck is running? or off?
Old 04-02-2018, 05:37 PM   #19
forestb
forestb's Avatar
while running
