01-28-2018, 12:24 PM | #1 |
Dana 60 question
I've looked all over the World Wide Web and cannot find any answers on application of part numbers
Left hand steering knuckle cast number c41896 and c38138 , are these the same ? Will either fit 1990 gmc v3500 ? Thanx in advance
88 3+3 454 400 205 410 drw to srw still in pieces 90 3+3 350 400 205 410 srw 84 1/2 ton lb 6.2 4x4 parts truck |
01-28-2018, 06:07 PM | #2 |
Re: Dana 60 question
72 K20 Custom Camper, D60, 14BFF, full roller 406 TPI w custom built ECU and yes..it has tow hooks... |
01-28-2018, 08:06 PM | #3 |
If it has 6 bolt spindles then yes. Ford used 5. GM and dodge are pretty much the same.
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
01-28-2018, 08:49 PM | #4 | |
dodge = middle of knuckle for casting ear for tie rod. gm = lower area of knuckle for casting ear for tie rod. but yes they can swap otherwise .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
01-28-2018, 10:33 PM | #5 |
https://www.ebay.com/itm/CUCV-GM-Dan...xaQrXD&vxp=mtr
this is correct for your v3500 they do appear to be interchangeable.
1985 k5 396/nv4500/203/205 d60/d70 4.56 42 sx2 1991 V3500 350/4l80/205 60/14 4.10 35 toyos. |
01-28-2018, 10:44 PM | #6 | |
Price is good
01-28-2018, 11:53 PM | #7 |
It fits. You're fine.
