Old 05-12-2017, 09:31 AM   #26
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: 66 C20 327, green original engine paint
Originally Posted by calichevyv8 View Post
Since it was a custom paint mix i think it's just the company's codes on it, not a general code that would work anywhere.
They may seem like just numbers but to a paint shop they are not.
Old 05-15-2017, 01:25 PM   #27
likaroc13
Rollin' Old Skool
I agree. I asked a paint-knowledgeable, fellow forum member who said there's probably a code on the can or at least a list of toners & how much of each used. If you still have the can used, please post a picture for us!
Phillip
My Build threads:
1966 Chevy C-10 "Black Betty"
Pics:
Previous Rides:
Old 05-16-2017, 10:44 AM   #28
scuderia
scuderia's Avatar
Do you have, or can you get a pic of the paint can showing any codes/info?
What he said, please : )
'66 C10 SWB
'64 C2 roadster
'38 Indian Scout Flattracker
'70 Triumph T120R
'81 Laverda Jota
scuderia is offline   Reply With Quote
Old 05-16-2017, 11:09 AM   #29
Calichevyv8
No info on the cans besides the paint brand info. I'll get ahold of the company and see if they saved the info, will report back shortly.
Calichevyv8 is offline   Reply With Quote
Old 05-16-2017, 01:55 PM   #30
kingchr
Interested in this color as well. Does anyone know if a '64 327 would have been the same color? I have seen tables that listed it that way, but they had a * by them saying that this is an assumption.
kingchr is offline   Reply With Quote
Old 05-16-2017, 06:53 PM   #31
likaroc13
Rollin' Old Skool
Thank you. Fingers crossed! It would be a huge help to those wanting to duplicate the original color as close as possible.
It would.
Phillip
My Build threads:
Pics:
Previous Rides:
Old 05-17-2017, 09:02 AM   #32
likaroc13
Rollin' Old Skool
I apologize for my previous statement that it would be the same, however I think I read where the 327 wasn't available in trucks until 1966. Maybe someone else can verify.
Phillip
My Build threads:
Pics:
Previous Rides:
Old 05-17-2017, 09:52 AM   #33
60-66
60-66's Avatar
I just recently bought a 1964 C30 Factory AIR 327 truck , pretty well documented 33,000 mile truck. Heres the valve cover and some engine shots ( much more on this truck has been posted). Another member also just found a 1964 C20 with a 327. We are coming to a conclusion that these are late 1964 factory builds . Possibly the start of these engines for production ?
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 05-17-2017, 12:25 PM   #34
61K10
61K10's Avatar
If the can has a paper label the recipe might be written on the back. Don't know if they still do this. They should have it in their computer.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 05-17-2017, 01:35 PM   #35
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
I ended up having a local paint shop match my original flywheel color.
Very nice.
The last two engines I had have been black.
I don't understand black. You can't see oil leaks as easy.
I had kinda planned on doing chevy orange, but I like that green.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 05-17-2017, 02:29 PM   #36
The Rocknrod
Moderator
This would account for seeing various colors in different years also:
http://67-72chevytrucks.com/vboard/s...1&postcount=11
Old 05-17-2017, 04:03 PM   #37
likaroc13
Rollin' Old Skool
Guess that proves they did start arriving in trucks earlier than '66. Love these finds guys like you come up with! Looking at pics it's hard to tell with color, as the lighting might be different. The OP's newly painted pic looks a bit darker due to lighting. It makes his engine seem a little more green. Yours looks brighter & a bit more teal (like '60s Buick green). However, we're looking at two different painted areas (valve cover vs. flywheel) that have had different exposures to the elements.
Thanks for sharing your info.
Phillip
My Build threads:
Pics:
Previous Rides:
Old 05-17-2017, 05:51 PM   #38
60-66
60-66's Avatar
That chart is way off Rocknrod . Never was a Chevy orange truck engine 60-66 , period. A lot of this stuff was done years ago , copied and posted in different places with little to no knowledge of this era trucks. I should note , I have confirmation on Chevy 1964 327s being green right from the Flint Michigan assembly plant. Bob Hensel was a very smart man , met him several times being from Wisconsin ( author of that color chart ) he also had the biggest all Chevy Library for the VCCA . Even those guys can get it wrong when they are not , lets say , experienced, in a certain field .
Old 05-17-2017, 06:05 PM   #39
60-66
60-66's Avatar
Heres some color samples. One valle cover is a 1963 292 cover. One is a 1966 327 cover and wire holder. The spray card Im holding up to the cover was done by theastronaut , a member here with a can of NOS Green engine paint I sent him.
Old 05-17-2017, 06:07 PM   #40
60-66
60-66's Avatar
Heres a 1960 C30 283 with 502 miles in truck green. Many of the larger truck V8s were green.
Old 05-17-2017, 08:27 PM   #41
factorystock
factorystock's Avatar
This has been discussed on other threads, but here it goes. 327 185 hp 2 BBL truck engine first introduced on C 50- C60 trucks in '62. This engine became a SPECIAL ORDER option on C 20-C 30's under COPO (Central Office Production Order ) around early '64 to early '65. During early '65 it was replaced with new 220 hp 4BBL version and became a REGULAR ORDER option on C 20's and C 30s only. For the '66 model year, it became a regular option on all C 10 thru 30's. Article from '64 camping magazine.
factorystock is offline   Reply With Quote
Old 05-17-2017, 10:06 PM   #42
likaroc13
Rollin' Old Skool
Yep, in my research on the forum I came across the thread (factory correct restoration?) where these pics were posted. I'm friends with John (theastronaut) on Facebook & made him aware of this thread when I found it.
Cool!
Thanks for clearing that up!
Phillip
My Build threads:
Pics:
Previous Rides:
Old 05-18-2017, 11:03 AM   #43
aotte1
With your engine mods, intake,cam, heads, etc. how does it drive with turbo 400 in your truck? Difference between stock and your upgraded 327?, is it a 350 crank and rods, in your 327 block?
Les
aotte1 is offline   Reply With Quote
Old 05-19-2017, 06:21 AM   #44
60-66
60-66's Avatar
Factorystock,what book was this published in ? Also like to know when it was printed??
Old 05-20-2017, 01:19 PM   #45
factorystock
Found in Camper Coachman magazine April '64. Unfortunately many who were involved in building these trucks when they were brand new, are no longer around to learn from. That is why we need to learn from era literature as much as possible. To me, history matters, knowledge is power. Here is some more from Oct '64 talking about the new 220 hp version vs. the older 185 hp version. Remember, at this point the 327 was a still a special order option, became a regular option around Spring '65. Photo shows a '64 C 30 which a Camper Dealer stocked with the special order 327 from May '64 Camper Coachman magazine. Not familiar with the lead time of magazines back then, so May issue might of been written in March?
Old 05-20-2017, 03:51 PM   #46
Calichevyv8
I have had a couple different phone calls with the paint company and looks like they don't have my info saved for the paint mix. I'm going to need to bring my quart in and have them do a match to it.
Old 05-20-2017, 09:35 PM   #47
factorystock
Thanks for going the extra mile Cali, there are a lot of folks who would be interested in the formula for the correct color paint for the 292-327 and maybe someday we will have the correct color paint for the 230-250's and 283's!
Old 05-21-2017, 12:40 AM   #48
aotte1
FactoryStock,
Along the subject of "327 engines in 1964 C 20s and 30s" do you know if the Oakland plant was making big trucks, e.g. C50/60, in May of 64'. I ask because, have a 64' C20 with a 327, suffix is correct for HD truck UG and dated mid May 64.
It is a totally loaded truck from CA desert, has three gas tanks.
Question thinking about, where did the special order 337s in 64' come from, e.g. Supply line for big truck line at that plant, or did flint specially make these 327s for each, or some plants, to be use in C20/30s.
Still confirming that mine is original 327 install, looks like it.
O Oakland mid May 1964, engine suffix pad. The VIN is around 170,000.
Thanks,
Les
Old 05-21-2017, 01:42 AM   #49
likaroc13
Rollin' Old Skool
I guess it's my fault for getting you involved in all this, but I knew after finding this thread that so many folks could benefit if you were able to help at all. It sucks they don't have the info saved; but if you're willing to take your quart in to be matched, I know I personally will be very grateful. I've been holding off buying paint for mine until I knew if you'd be able to get the info needed to duplicate your color.
Phillip
My Build threads:
Pics:
Previous Rides:
Old 05-24-2017, 10:55 AM   #50
Calichevyv8
Les
When I got the truck it had been sitting in a field for years and wasn't running, so I never got to drive it stock to compare. After the engine rebuild with all the original stuff I put it on a engine dyno which came out to low 200 hp range, that prompted me to put the double hump heads and corvette intake and headers before dropping it in the truck which brought me closer to 300. Runs well!
