Old 03-31-2009, 08:04 PM   #26
Green Monster
Green Monster's Avatar
Re: Need help with wiring stock temperature and vacuum gauges
Excellent! So the temp gauge does not have a wire going to the back of the gauge, instead the signal is sent though the printed circuit, correct?
Green Monster is offline   Reply With Quote
Old 03-31-2009, 08:06 PM   #27
msgross
msgross's Avatar
Originally Posted by msgross View Post
The green wire should be built into your main harnass that clips onto the back of your dash bezel. You "should" just need to hook up the printed circuit on the back to the new gauge. .
yep,
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 03-31-2009, 08:57 PM   #28
Green Monster
How does the vacuum hose attach to the vacuum gauge? I only have a gauge but don't know what type of hose to attach or how to attach the hose.
Old 03-31-2009, 09:46 PM   #29
msgross
msgross's Avatar
good question.. post some pics when you figure it out.. I have yet to mount mine as well... I'm think vacuum hose but not sure on the gauge connector...
The Garage:
Old 04-01-2009, 08:47 AM   #30
jaros44sr
jaros44sr's Avatar
Just looked at mine, 1/8" copper tube and ferrule with the female locking nut. Just like your oil pressure gauge if you have a manual, comes off the block by the distributor and not electric
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 04-01-2009, 08:05 PM   #31
badpeanut
Not a bad nut after all..
badpeanut's Avatar
IIRC the vacuum gauge fitting is larger (1/4"?) than the oil fitting (1/8"?).
'05 Chevy 2500HD 4x4
'72 GMC LWB 4x2 driver
'72 Chevy LWB 4x4 plow truck
'71 Blazer 4x4 driver
'70 GMC LWB trailer
badpeanut is offline   Reply With Quote
Old 04-02-2009, 05:37 AM   #32
jaros44sr
jaros44sr's Avatar
I could be wrong, I'll go look again
SAFETY FIRST
AS usual, off topic
Jim
Old 04-02-2009, 05:39 AM   #33
enaberif
vac gauge is just hooked up to the manifold vacuum source. May have to do some custom fitting.
enaberif is offline   Reply With Quote
Old 04-02-2009, 07:04 AM   #34
jaros44sr
jaros44sr's Avatar
Looks to me it is a 1/8" tube, but it could be a 1/4" ferrule. I could measure if needed
SAFETY FIRST
AS usual, off topic
Jim
Old 06-25-2009, 11:11 PM   #35
seldomseen65
spirit rider66
seldomseen65's Avatar
Location: pahrump, nevada, in the bowels of the Mojave desert
OK guys it's my turn to ask for help, I'm sure there are a lot more younger guys than i am, that could help me out, my problem is my horn , everything else is OK, i went for a test run to check things out and i try to use my horn and nothing happened ,,i came back to the house and find out that the horn had been by passed, with a horn bottom,,why would any one do that and i have been trying to figure this out with out tearing the steering wheel apart ,, so give me some idea what i might have to do OK,,thanks ,,i hope i posted in the right area to ask for help ?
Larry
:Chevy: If you don't run your own life,, some one else will.
to our vets,, welcome home,, and thank you for your service.:Chevy:
seldomseen65 is offline   Reply With Quote
Old 06-26-2009, 11:45 AM   #36
jaros44sr
jaros44sr's Avatar
Larry
I would repost this down on the Electrical section, or have a Mod. move it. Really smart guys down there and I'm sure one of them could help you out. I had a question for them and they even drew up a schematic for me to follow along
I'm electrically challenged, so I can't help
SAFETY FIRST
AS usual, off topic
Jim
Old 06-26-2009, 05:51 PM   #37
seldomseen65
spirit rider66
thanks jaros44sr; i'll five them a try and see if they can come up with a solution for me,
Old 03-08-2010, 08:59 PM   #38
Green Monster
It's been a while but I finally got around to refurbishing my instrument cluster. Out is the hand throttle and aftermarket Sun Pro gauge. I installed a new bezel, lens, printed circuit, and tin along with the correct factory temp gauge with vacuum gauge. It looks awesome.
I was able to get the vacuum gauge to work by buying a brass adapter to attach a 1/4" barb to the back of the gauge. The adapter and 1/4" barb were threaded on with teflon tape. I used six feet of 1/4" vacuum line and ran it to a T that I installed about two inches from the vacuum line coming out of the rear of the intake manifold that leads to the AC canister. The gauge reads right down the center at "15" during idle and drops to "0" if I stab the throttle but bouces right back to "15". I guess that's what it should be doing?
I found a few cut wires behind the block wile under the hood. One wire on the passenger side and another on the driver side. Not suprising to me, the volt meter and temp gauge do not work. I installed a new temp sensor. I think the cut green wire I found needs to be connected to the temp sensor and that will resolve my temp gauge issue.
I'm not sure what I have to do to get the volt meter working. Any ideas?
Thanks,
John
Old 03-08-2010, 11:46 PM   #39
lks dcvn
lks dcvn's Avatar
GM - do you have any pix of the new setup with the hookups under the hood - I have a vacuum gauge that I want to get hooked up this year at some point.
lks dcvn is offline   Reply With Quote
Old 03-09-2010, 12:16 AM   #40
jaros44sr
jaros44sr's Avatar
Thanks,
John
Good job John, glad it worked out for you. You're right on the green wire, I'll see if I can find the volt wire for you
SAFETY FIRST
AS usual, off topic
Jim
Old 03-09-2010, 10:37 AM   #41
John H.
John H.'s Avatar
There should be a brown/white wire from the junction block on the passenger fender. The small wire from the positive battery cable hooks on it. I think the other wire (brown) comes off the voltage regulator. Both of these wires go through the firewall at the bulk head and go into the back of the guage cluster like the temp. I might have the colors backward, but you can look at the diagram for a start.
John H. is offline   Reply With Quote
Old 03-09-2010, 02:36 PM   #42
Green Monster
I'll see if I can get some pix.
Thanks for the tips.
Jaros - If I can't get this corrected then can I stop by for some help? From your pictures, it looks like you have experience with wiring.
Old 03-09-2010, 03:40 PM   #43
jaros44sr
jaros44sr's Avatar
[QUOTE=Green Monster;3849901
Jaros - If I can't get this corrected then can I stop by for some help? From your pictures, it looks like you have experience with wiring.[/QUOTE]
Sure anytime! But don't use that as a reason to visit...got my cell number? sposed to rain this weekend
SAFETY FIRST
AS usual, off topic
Jim
Old 03-09-2010, 03:45 PM   #44
Green Monster
Rain will stop me. GM is a fair weather vehicle only.
I don't have your cell number. Can you PM me with it?
Old 03-09-2010, 04:47 PM   #45
jaros44sr
jaros44sr's Avatar
I knew that that's why I posted it up, but maybe Sunday
SAFETY FIRST
AS usual, off topic
Jim
Old 03-09-2010, 09:58 PM   #46
Tynee
I miss this truck.
Tynee's Avatar
Congrats, I bet it looks great.
'07 GMC Acadia SLT. Sweet ride.
'08 Crew Cab Z-71 short bed. Really like this truck A LOT.
Tynee is offline   Reply With Quote
Old 03-09-2010, 10:02 PM   #47
jaros44sr
jaros44sr's Avatar
SAFETY FIRST
AS usual, off topic
Jim
Old 03-10-2010, 09:55 AM   #48
Green Monster
I'll get pictures up soon. I have an under hood picture and dash picture to share.
Old 03-23-2010, 04:57 PM   #49
Green Monster
Jim (aka Jaros44sr) was gracious enough to host myself at his home on Sunday morning to help me get the stock temperature gauge wired up and operating again. Jim knows his wiring and wasted no time finding chopped up wiring under my hood and quickly identifying where it belongs and what it was for. The previous owner installed a new motor and aftermarket SunPro temp. Gauge. Jim supplied the correct advice, wire, connector, heat shrink tubing and crimping tools to help me get the job done right. Jim is both patient and knowledgeable. Great guy and super nice. Jim has a neat project Jimzer with a 67 Chevy pickup front clip he is working on. It was great to look at his project with the oak bed and to share my 72 Blazer with someone that REALLY appreciates it. Thanks again Jim!
Attached are photos of the vacuum gauge set up as requested.
Old 03-23-2010, 05:01 PM   #50
Green Monster
One more.
