Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > Review Board > Product Reviews
Old 10-26-2008, 11:00 PM   #1
Houston54
Thumbs down Dolphin Quad Gauges - Not Recommended
If you are considering Dolphin for a set of 5 inch quad gauges you might want to consider my experience. I installed a set last July in my 54 Chevy and noticed on the first night ride the illumination between the two buckets was significantly different with the speedo nice and bright and the gauge bucket very dim. Thinking I had wiring it incorrectly I checked everything and confirmed my grounds. Everything checked out. I contacted the Dolphin Tech line and was informed they were aware of the problem and were working on a new gauge bucket with brighter lighting. I was told to call back in a month and they would swap the unit I had out with a new one. Sounded good to me.
Two months later I called to see if the new buckets were available and was informed they will not be fixing the problem and they suggested I wiring in a resistor to reduce the lighting level of the speedo to match the gauge bucket. This is not an acceptable solution to me. If the problem had been know going into the purchase I would not have selected this product.
I requested they buy back gauges from me or refund my purchase price to which I have not received a reply.
I have attached a pic of the gauges at night. While the gauges can be read it is not as easy as the speedo which is obvious. If you would be happy with this level of lighting or only drive during the day then these might be the instruments for you but to me they are a second rate product which will be included in my next swap meet material.
Houston54 is offline   Reply With Quote
Old 11-07-2008, 03:41 PM   #2
Houston54
Re: Dolphin Quad Gauges - Not Recommended (UPDATE)
Wanted to provide an update to this:
I have had an email discussion with Dolphin regarding this problem. Seems it got the attention of someone high enough on the ladder to give a green light to corrective action.
I think it bodes well they are doing something positive to address the issue instead of shooting the messager.
If the fix solves the problem I will be back to let you know.
Old 11-08-2008, 12:07 PM   #3
hotrod 80
mini truck racer
hotrod 80's Avatar
Please keep us updated on this . I just bought a set for the 49' and have not even opened the box .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 11-16-2009, 03:32 PM   #4
Houston54
After giving this company many opportunities to correct the problem either by providing me with a new gauge bucket with updated lighting or refunding me some of the initial cost I am tossing in the towel.
Since I made my initial post I contacted Dolphin several times. Each time I was told the fix was in process. The Fix has never been done. Their 5" quad gauge is a poor product. The company knows of the problem but continues to sell it.
Please do not waste your time and money as I have by dealing with this company.
It is a shame that the magazines continue to take this companies dollars for advertising. I guess they do not care about us either and just want the money.
Old 11-26-2009, 09:11 AM   #5
andrewmp6
That's odd a company that won't stand behid there products.If they won't fix it you could try adding some leds to it should work.
Old 11-26-2009, 05:09 PM   #6
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
That sucks,
I was considering picking up a set. Thanks for the review.
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
71 C20 Longhorn/Ole Yellor
69 C30 Former Motor Home, Flat Bed time
71meangreenc10 is offline   Reply With Quote
Old 11-27-2009, 10:43 PM   #7
kev2809
low n' slo
kev2809's Avatar
man that sucks. i wonder how they even make the lighting that far off, knowing as soon as its on it will be noticeable. good luck to ya
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is online now   Reply With Quote
Old 12-03-2009, 04:53 PM   #8
0331grunt
Now what??
0331grunt's Avatar
Has anyone had any problems with the AutoMeter quads? Just curious.. I am going with a quad set up- but NOT Dolphin!
69 Long Fleet - Project
06 Ram 1ton Cummins 4x4-DD
01 Tahoe- wifes
"The quality of a persons life is in direct proportion to their commitment to excellence, regardless of their chosen field of endeavor." ~ Vince Lombardi
"A dream doesn't become reality through magic, it takes sweat, determination and hard work." ~ Colin Powell
my, um, build
USMC OIF Veteran SEMPER FI!
0331grunt is offline   Reply With Quote
Old 12-25-2009, 03:32 PM   #9
thrtsxchambers
thrtsxchambers's Avatar
Man that sux, I was planning on using those gauges in my truck but guess I'll look for something else. Glad I found this post, I should be ordering some soon
thrtsxchambers is offline   Reply With Quote
Old 12-26-2009, 06:05 PM   #10
leddzepp
Moderator
leddzepp's Avatar
Wow Houston! Your original post was a year ago. You have way more patience than I do.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 12-15-2010, 11:16 AM   #11
Houston54
Since I have seen several people opting to use these guages during the past year I thought I would give this a bump in the hope others who may be thinking of using these guages will be aware of the problems.
Old 05-24-2011, 06:20 PM   #12
Houston54
btt
Old 05-24-2011, 06:45 PM   #13
7T2
Active Member
7T2's Avatar
Thanks for bumping this up...I always thought Dolphin made a nice looking product, and I am half-heartedly looking for some gauges to replace a set of Autoloc gauges I'm not entirely happy with. I will take this into consideration on my next purchase.
Maybe direct them to this thread? If they see enough people are changing their mind because of it maybe they will do something about it?
1957 GMC Ambulance
1962 Belair Wagon
1963 C80 Truck Cab *FOR SALE*
1969 Chevy C10 Short Bed
1972 Chevy C10 Long Bed *SOLD*
1996 C3500 Dually *SOLD*
7T2 is offline   Reply With Quote
Old 05-25-2011, 11:07 AM   #14
Clyde65
Clyde65's Avatar
I have used Dolphin gauges for over 6 years, I have always been satisfied with their quality. I dont particularly care for their customer service just because talking to someone or getting emails back in a timely manner is like flossing alligator teeth. I have had a few issues with a guage here and there, they have always sent a new one without question, all though I didnt know they did until I get a package at my door.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 05-25-2011, 09:31 PM   #15
Indian113
Indian113's Avatar
Has anyone used the 5 or 6 gauge sets ? The price is close to VDO 5 gauge set for a 6 gauge Dolphin or Shark set
Indian113 is offline   Reply With Quote
Old 05-26-2011, 05:39 PM   #16
Clyde65
Clyde65's Avatar
I have both. a 6 guage and a 5 guage, both work fine.
Clyde65
Rebuild of Clyde
support our troops!
Old 05-27-2011, 09:22 AM   #17
Houston54
This thread is specific to their 5" quad set. I do not have any opinion about any of their other products other than based on my current experience I would look elsewhere first.
This company is aware of this thread and others I have posted on similar sites. I am only sharing my experience with this company and with this specific product so others can be aware of its shortcomings. The gauges have worked well for the 3 years and 37K miles I have been running them and fortunately most of those miles are in the day light.
They have my contact information and have opted not to make an effort to resolve my issues with this product.
Old 05-29-2011, 07:32 AM   #18
dfleming7
Don't mean to hijack thread. But, was wondering if anyone has wiring procedure for these on a '69?
dfleming7 is offline   Reply With Quote
Old 05-29-2011, 02:37 PM   #19
Clyde65
Clyde65's Avatar
wiring procedures? they are pretty straight forward, what are you looking for exactly?
Clyde65
Rebuild of Clyde
support our troops!
Old 05-29-2011, 08:07 PM   #20
Olden Days
Living In The Past
Olden Days's Avatar
Looks like you "mean it" to me.
I dont care if they have "some" good products. Customer service means a lot to me. I had looked at their line of gauges but after seeing this thread without any attempt by Dolphin to respond , I sure wont be doing any business with them.
after telling the OP to wire in a resistor, at the very least they should have sent said resistor with wire harness if that is their fix
Olden Days is offline   Reply With Quote
Old 06-01-2011, 05:26 PM   #21
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
emailed the company
71 Suburban 350/700R4 Project Trixie
72 CHEVY,Highlander,SWB,396,T400
BB72CHEVKT is offline   Reply With Quote
Old 09-27-2011, 08:57 AM   #22
McCoyAZ
McCoyAZ's Avatar
I was also considering gauges from Dolphin.
After reading this thread I sent them an email.
Their reply to me was that the light issue was only an issue if using a programmable speedo and it was not an issue if using a mechanical speedo.
Iwonder if that is the underlying problem for real?
scott
McCoyAZ is offline   Reply With Quote
Old 09-27-2011, 09:31 AM   #23
OJ1988
Just a car guy
OJ1988's Avatar
scott
If that is true, then the mechanical speedo will be as dim as the quad gauge posted above.
Way to dim for night driving imo.
1955 belair Blown Pro Street cruiser
1971 Camaro Pro Touring
1973 Vega Drag Car
1970 C20 tow rig
OJ1988 is offline   Reply With Quote
Old 10-04-2011, 08:56 PM   #24
motornut
78K & 79C Jimmys
motornut's Avatar
heck one looks yellow and one white
way to dark.....
not gona buy that one
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 10-14-2011, 06:37 PM   #25
51chevytruck
Bump.....Glad I found this, was going to go with Dolphin Gauges!!!
51chevytruck is offline   Reply With Quote
