Old 08-08-2017, 09:10 PM   #1
Edahall
Leaking steering box
The steering box on my 3/4 ton 4x4 Suburban is leaking out of the seal and it's getting worse. How difficult is it to change out this seal? I also have a steering box from a 1/2 ton 2 wheel drive Suburban. Will they interchange? Both vehicles have over 500k miles.
1990 ¾ ton 4x4 Chevy Suburban
-Cummins Diesel - 12 valve - factory rebuilt
-6 speed bullet proof manual transmission - NV5600
-Gear Vendors Overdrive - HX35 Holset Turbo
-NP205 iron transfer case
-3.73 gears -2" Lift
Edahall is offline   Reply With Quote
Old 08-08-2017, 09:41 PM   #2
70K10Hunter
70K10Hunter's Avatar
Re: Leaking steering box
4x4 box pitman arm is clocked differently than a 2wd box. not interchangeable....unless you want to go with cross over steering. to replace the seal in the box that is leaking, you will need a pair of snapring pliers and a small seal puller although I do it slightly differently with a drill and sheet metal screws. disconnect the rag joint remove the snapring remove the dirt seal and use small seal puller to get old seal out then install new seal.
I bought a seal kit from Napa for like $20
70K10Hunter is offline   Reply With Quote
Old 08-08-2017, 09:55 PM   #3
sweetk30
sweetk30's Avatar
you sir do it the hard way . . . .
remove pitman arm .
clean mud/dirt from seal area .
remove snap ring .
BIG drain pan to catch fluid under the box .
fluid in system .
fire up and turn the wheel to the bump stop of the box . then bounce it off the stop with the steering wheel . . . .and POP the seal should come right out by its self.
old school gm tech showed me this trick years ago .
NOTE : orignal poster never said if input or output seal tho .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 08-09-2017, 07:09 AM   #4
Edahall
It's the input seal that is leaking in mine.
Old 08-09-2017, 08:46 PM   #5
70K10Hunter
remove pitman arm .
remove snap ring .
fluid in system .
Not hardly.....I was referring to the input shaft. I too know many shortcuts that I have learned and USED with great success, that so called shortcut works about a third of the time but you ALWAYS get the MESS.
No thanks
Old 08-16-2017, 11:22 PM   #6
Edahall
Thanks for the tips. I changed out the input seal and put her all back together and it's leak free. It took me about 4 hrs to do the job. Fairly simple job IMO but if I were to do the job again, I would not remove the power steering box from the frame. I would have changed it in place. It was a challenge getting the box bolted back to the frame. Had to use rachet straps to lift it into place and it was horribly greasy from leaking for several years.
Old 08-09-2017, 08:24 AM   #7
aggie91
I'm just glad to be here!
aggie91's Avatar
There is a great How To thread on resealing a power steering gear on here. Ill see if I can find it for you.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 08-09-2017, 08:26 AM   #8
aggie91
aggie91's Avatar
I found it, but let me make this statement before I add the link to it...Photosuckit has made this thread nearly useless. All the pictures are no longer there....
http://67-72chevytrucks.com/vboard/s...d.php?t=619634
Karl
The LST Challenge:
Old 08-09-2017, 03:32 PM   #9
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Next time I do another one of those I'll snap new pictures and host them at my good place and make a new thread.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 08-09-2017, 03:49 PM   #10
aggie91
aggie91's Avatar
Kevin, You are the man!
Karl
The LST Challenge:
