Old 05-22-2021, 08:12 PM   #26
LockDoc
The Older Generation
LockDoc's Avatar
Re: Dana 60 3.54 in the '68 Chevy C20
Originally Posted by chevmn View Post
That is correct. Any idea which I should place to rear? As I said, this is my first experience seeing both same length.
The shoe with the lining farthest from the top would go on the front.
LockDoc
Leon
Old 05-23-2021, 03:45 AM   #27
Killer Bee
Killer Bee's Avatar
I agree, the bare lining table at the top should be forward..
interesting that the lower end of the rear shoe lining table is also bare..
probably cost savings, only manufacture one lining, just oriented for F or R shoe..
Old 05-23-2021, 04:02 AM   #28
Killer Bee
Killer Bee's Avatar
good job on that axle swap Doc!
I scored a D60 4:10 LS leaf sprung for my k20 burb, then later scored a 4:10 locker third for the 4:10 eaton in it..
red longhorn has a factory locker so thinkin I might haul that D60 home for the ochre longhorn..
swap my leftover 4:10 eaton gears into the red longhorn and everything will be just right for my uses
Old 05-23-2021, 04:56 AM   #29
RichardJ
I bought the same NAPA shoes a couple of years ago and found the same problem. At the time, i checked the other retail part stores and found the same shoes. They all had part numbers that were a variation of Napa's 419 part number.
This thread from last year talks about the same shoes.
https://67-72chevytrucks.com/vboard/...ighlight=shoes
The shoes seem to work OK when driving. Having disc brakes on the front may be a factor on that.
I did find that when parked, nose up on a hill the e-brake had to be applied extra hard to keep it from rolling back. You don't always have curb to turn the wheel against.
I think it sucks that they can't give you the correct lining length for the rear shoe.
'67 GMC 2500, 292, 4spd, AC
RichardJ is offline   Reply With Quote
Old 05-23-2021, 03:43 PM   #30
LockDoc
LockDoc's Avatar
Thanks.
That sounds like a lot of swappin' to me. I was glad to get the one done....
I needed the 3.54 to make it easier to drive on the highway. I do very little work with it. Heck, I do very little work anyway...
LockDoc
Leon
Old 05-23-2021, 05:36 PM   #31
Lee72
I did a coil spring Dana 60 swap last year for a friend. What did you do for the track bar? I think that the bracket at the frame is different. Stock track bar from the Eaton was a different length and the angle at the bracket on the frame was more than the one for the Eaton. I shortened his and am looking for the correct bracket. When I got the rear end, I got the rear part of the driveshaft and the track bar but didn’t think to get the bracket. Glad to see someone else has done this also. My friend really likes the 3:54 versus the mid 4: ratio that the Eaton had. I think you’ll like it too.
Lee72 is offline   Reply With Quote
Old 05-23-2021, 05:49 PM   #32
jocko
jocko's Avatar
That may be more a function of cable slack than shoe surface length. Agree, I wish they still manufactured correct length linings too. I bought some shoes for a 71 D60 4.10 about 10 years ago and they were correct, or at least as best I can recall - the rear shoe was indeed much longer than the front shoe.
Old 05-23-2021, 08:11 PM   #33
LockDoc
LockDoc's Avatar
I heated the Dana 60 bar right in the middle and bent it over so it lined up with the frame bracket, jacked the frame over about 3/8 inch toward the passengers side and put the bolt in. Lined up on the first try and the bolt slid right in.
LockDoc
Leon
Old 05-23-2021, 08:22 PM   #34
DA71Grande
DA71Grande's Avatar
This may help…
http://67-72chevytrucks.com/vboard/s...ght=Brake+shoe
Doug
71 Sierra Grande C25
16 Sierra 2500HD All Terrain
23 Chevy Tahoe Z71
https://paypal.me/digdug7131?locale.x=en_US
DA71Grande is offline   Reply With Quote
Old 05-16-2023, 09:34 PM   #35
sloGMC
Active Member
Originally Posted by LockDoc View Post
Well, I finally finished up the Eaton HO52 / Dana 60 rear end swap. The Dana was a coil spring rear end so that made the swap pretty easy.
LockDoc
Any idea what the D60 came out of? I've been thinking about swapping out my leafs for coils and debating whether or not to grab a coil sprung D60 vs having new perches welded onto my existing rear end.
The reason I ask about the donor, is that I do not know if there is a difference in the brake package between a C20 Suburban Dana 60, a C20 Truck coil-sprung D60, and a C20 leaf-sprung D60. It sounds like your new rear has the 12x2.5" brakes that G70 trucks have.
1971 Pontiac Firebird
1971 GMC C2500
sloGMC is offline   Reply With Quote
Old 05-16-2023, 10:27 PM   #36
LockDoc
LockDoc's Avatar
Not 100% sure. I think I picked it up over at the salvage yard. They are kind of hard to find.
LockDoc
Leon
Old 05-17-2023, 12:45 AM   #37
RichardJ
If you are looking for a Dana 60 you might look under the Dodge trucks. My GMC 2500 came with the 292 six and a Dana 60 with 4.56 gears. I ran across a Dodge D200 with 3.54 gears and a posi carrier in a wrecking yard for $50. The Dodge Dana is the same except for different yoke splines and they use the smaller "U" joints. A 4 wheel shop had a yoke with dodge splines, but for the larger "U" joint.
3.54 gears, even with a six, made a bigger, single difference than most everything else I have done to the truck, except maybe the AC.
Old 05-17-2023, 10:47 PM   #38
sloGMC
Active Member
I talked with a guy from VintageChevyTrucks and he did say that C20s with coils are uncommon and that C20 suburbans would be the best bet.
I currently have a Dana with 4.10s and, yes, even with my 4L80 I'm going to switch to 3.54s.
Maybe I'll make a post in the suburban section and see if anyone knows if their Dana has 12x2.5" brakes.
1971 GMC C2500
Old 05-18-2023, 11:54 AM   #39
chevmn
The Dana 60 with 3:54 came in the big block trucks. Small block got the 4:10s. I purchased a C20 at an estate auction which had sat for a very long time, but only had 62,000 miles when parked. It had tires put on just before being parked in favor of a new truck, and date code on Montgomery Wards (remember those?) tires are early 80s, so the truck was about 10 years old when parked. It has factory big block, TH400 and Dana 60 powerloc with the 3:54 ratio. When I purchased it had a camper shell, set up to tow, and propane conversion on top of the q-jet. Camper, propane was first to go, and initial plan was to put 1/2 ton suspension on it. Engine and drive train seem all good, so it is getting some much needed restoration work, and paint, and remaining a 3/4 ton after some research. I'll see how it rides/drives, but for sure getting some "P" rated 16 inch tires to soften it up a little since I have no plans on heavy hauling or towing, and I know how the C/D/E load tires ride on the roads around here.
chevmn is offline   Reply With Quote
Old 05-18-2023, 12:15 PM   #40
KQQL IT
At the body shop.
KQQL IT's Avatar
Dad said the 3.54 gear would swell the converter up to the point of killing the thrust surface in the 454 in old blue.
True ? I don't know.
But probably pulling this up the grapevine at 55 in 2nd had more to do with it.
Old 05-19-2023, 11:05 AM   #41
sloGMC
Active Member
Sort of. My truck came with a 400 and the optional 4.10 gear set. What I can't make sense of is why GM didn't offer the coil sprung 4.10 Dana with a 400. My guess would be that the trailing arm suspension would handle the torque even better than a leaf set up but, other than reducing the amount of rear end variations available I can't figure why it wasn't offered.
1971 GMC C2500
Old 06-06-2023, 12:41 AM   #42
gmtech68
Most Canadian trucks had coil springs, Chev or GMC. At least that has been my experience.
gmtech68 is offline   Reply With Quote
