Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 02-21-2017, 10:34 AM   #1
cpnbnanamn
Hazard lights diagram?
Anyone have the hazard light wiring from the relay ~> out? Just discovered that my front flashers are working when the hazard lights are on, but the rear ones aren't. Yeah.. need to fix that. Just need a starting point.
cpnbnanamn is offline   Reply With Quote
Old 02-23-2017, 11:14 AM   #2
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: Hazard lights diagram?
By relay I assume you mean the flasher in the fuse panel. If so, there is a 16 gauge brown wire from the fuse panel to the half moon connector on the steering column, that sends power to the hazard switch in the turn signal switch.
The hazard switch sends power to the front and rear lights through the same wires that the turn signals use. LT blue, Dark blue, for the fronts and Yellow and Dark green for the rears.
Do your rear signals work? If they do then you aren't getting power through the hazard switch and the contacts may be dirty or they may be damaged and you'll have to replace the switch.
Here is a diagram. The half moon connector is on the upper right and the 16 gauge brown wire is in the middle next to the purple wire. The brown wire is hot all the time and does not need power from the key switch like the turn signals do.
Name:  Copy of Cab-1web panel lights.jpg
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 02-23-2017, 11:45 AM   #3
cpnbnanamn
The rear turn signals and brakelights do work, and so do the front parking lights when the hazards are on. It seems that the issue is after the switch, and I am trying to figure out where.
'67 C10 SWB - (frame-off in progress)
'78 K5 Blazer - LQ4/4L65e - 4WD
Old 02-23-2017, 02:19 PM   #4
VetteVet
Msgt USAF Ret
VetteVet's Avatar
It sounds to me like your hazard switch is bad. Your wiring circuits are good but you aren't getting power to them from the hazard switch. You must be getting power to the hazard switch if the fronts flash, but not the rears. And you must be getting power to the fronts through the switch because the fronts are flashing.
Unplug the half moon connector and do a continuity check between the brown wire in the connector and the dark green wire. Look for zero ohms and then do the brown, and yellow wires looking for zero ohms. This is on the wires that go to the turn signal switch.
Your wires in the harness might not be the same colors on both sides of the half moon connector, so you might have to match them up with the wires on the other side of the connector, that comes from the fuse panel. When you check the wires be sure to pull the hazard switch on. You can also check the two blue wires too, and they should have zero ohms since the fronts do work.,
Here's a picture. notice that all the wire colors don't match, but you wires should because your lights work. If you are confused then just post back and I'll clarify it more for you.
VetteVet
Old 02-23-2017, 08:14 PM   #5
cpnbnanamn
Found the issue. Bad switch. Everytime I wiggle the switch, either they all (rears) come on, or just one comes on, or they all go out. Thanks for the help!!
Old 02-24-2017, 01:36 PM   #6
VetteVet
Msgt USAF Ret
VetteVet's Avatar
From you very good description of your symptoms I was pretty sure it had to be the switch. Good job. VV
VetteVet
Old 02-24-2017, 01:42 PM   #7
cpnbnanamn
No, man.. Thank you! I greatly appreciate the help!
I was hoping to see the wiring diagram between the relays and the switch, and the one that's published doesn't show it. I really appreciate all the help and responses.
-Roger
Old 03-18-2018, 09:01 PM   #8
jeff_wilson70
jeff_wilson70's Avatar
Thank you VetteVet. Your instructions on this helped me diagnose my problem as well.
jeff_wilson70 is offline   Reply With Quote
Old 03-18-2018, 11:15 PM   #9
VetteVet
Msgt USAF Ret
VetteVet's Avatar
-Roger
Thanks guys I'm always glad to help.
Welcome to the forums Jeff.
VetteVet
Old 08-23-2019, 03:27 PM   #10
Goose
Goose
Goose's Avatar
Thanks for this thread. It helped me troubleshoot my flasher system.
'72 GMC short-step 350/350
Goose is offline   Reply With Quote
Old 08-24-2019, 01:32 PM   #11
VetteVet
Msgt USAF Ret
VetteVet's Avatar
This forum is the best one on the net.
VetteVet
Old 08-24-2019, 01:47 PM   #12
The Rocknrod
Moderator
The Rocknrod's Avatar
I think so by far. Thanks for your service also.
Old 08-24-2019, 02:24 PM   #13
Goose
Goose
Goose's Avatar
VetteVet - just curious about your discussion concerning the continuity check of the switch harness where you mention to "...be sure to pull the hazard switch on." To turn the hazard lights on in my truck you push the hazard switch on. Either way, I understood you to mean the hazard switch had to be on for a proper continuity check and that's the way I checked it. Are there versions where you pull the hazard switch on? Again, thanks for the help.
Old 08-25-2019, 11:35 PM   #14
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Yes you are correct that the switch has to be turned on whether it is pushed in or pulled out. I was probably thinking of one of my other vehicles.
VetteVet
