Old 11-18-2019, 10:49 AM   #1
6t727t2
Active Member
restoring old light lens gaskets
Anyone tried to soften up the old gaskets, which are far superior to thin re-pop gaskets?
6t727t2 is offline   Reply With Quote
Old 11-18-2019, 11:08 AM   #2
Andy4639
Old member
Andy4639's Avatar
Lightbulb Re: restoring old light lens gaskets
I haven't ever restored one but would be interested in if some one has.
I use Dow Corning 111 on them when I take them a part and put back together. Seems to work pretty good on keeping water out of them.
Just idea:
I haven't tried this though,
You might try going to a hardware store and buying some rope that would fit in the gasket area and coat it with the DC 111 and it would soak up the water. I know rope type material was used years ago for gasket.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 11-18-2019, 03:49 PM   #3
RodnRudy
RodnRudy's Avatar
Another idea is to go to a fabric store and look for the foam piping they use when they make trim, like what is used to make fender welt etc. They have it in different diameters and usually sell it by the foot. Jo- Ann Fabrics is a store in my area that handles the piping. Or you might try an upholstery shop.
Phil
"Money is only a tool to create and achieve what you want most in life"
PayPal: rodnrudy@comcast.net
RodnRudy is offline   Reply With Quote
Old 11-18-2019, 06:34 PM   #4
HO455
HO455's Avatar
I have soaked window gaskets in dishwashing soap for a week with good results. It may work for those. WD-40 is good for vinyl's it may work too.
For a replacement I would try some PTFE Sealant cord.
https://www.lowes.com/pd/danco-ptfe-...E&gclsrc=aw.ds
RIP Bob Parks.
1967 Burban the WMB,1991 S(stink)-10 Blazer,1969 GTO, 1970 Javelin, 1952 F2 Ford 4X4, 29 Model A, 72 Firebird. 85 Alfa Romeo
Old 11-18-2019, 07:42 PM   #5
LockDoc
The Older Generation
LockDoc's Avatar
Replace it with Rope Caulk:
3/16"
https://www.acehardware.com/departme...E&gclsrc=aw.ds
1/4":
https://www.menards.com/main/hardwar...2582940251.htm
LockDoc
Leon
Old 11-18-2019, 08:15 PM   #6
tdangle
tdangle's Avatar
Originally Posted by LockDoc View Post
Great idea!!
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline   Reply With Quote
Old 11-18-2019, 08:44 PM   #7
70LonghornCST
Moderator
70LonghornCST's Avatar
I just did the "dish soap method" this last week; it works well. As long as the gasket is not cracked up and falling apart, then the gasket's integrity should still be intact. The gasket is a petroleum-based product of some sort, so soaking it hot water and dish soap for a few hours won't hurt the gasket. Change the hot water every so often to keep the gasket hot/warm as it soaks. After at least an hour, start cleaning and the crud will come right off. You may need to scrape it off at first to get the goop to start coming off of the gasket. Most of the oils come off as well. If you use a petroleum based solvent to remove any further stains or discoloring on the gasket, be careful; as you're liable to dissolve the the gasket itself.
2018 Chevy Crew Cab
2006 Impala SS
1965 Plymouth Sport Fury
1970 Chevy Longhorn
  • Bucket Seats
  • Shoulder Belts
  • Front Tow Hooks
  • Factory Air
  • Factory Speedwarning, Tach & Vaccum
  • Factory Tilt
  • CST Package
  • AM/FM Radio
  • Bumper Guards
Richard
70 Longhorn CST Build
Adding an AM/FM Decal
70LonghornCST is offline   Reply With Quote
Old 11-18-2019, 09:23 PM   #8
Smitty
Smitty's Avatar
I purchases Soft Seal 9342. Tail light lens gaskets and they were as thick as the original. Got mine from Jegs who say they are out of stock. But the Soft Seal sight said they have 2. SS-9342.
Smitty
'71 Short Fleetside
Spring Valley, Ca.
Smitty is offline   Reply With Quote
