Old 01-22-2019, 06:09 PM   #51
Green Monster
Green Monster's Avatar
Re: Who's running steelies on their K5 - post your pics
Currently running 15" x 10" alloy aluminum wheels but would strongly consider running these 20" Rally reproduction wheels from US Mags in white or grey.
http://us-mags.com/sierra-u706-6-lug-w-7843.htm
Green Monster is offline   Reply With Quote
Old 01-22-2019, 09:40 PM   #52
Chulisohombre
Chulisohombre's Avatar
Originally Posted by Sandtrap9072 View Post
Figured i would, try and bring this post back up to date. these are the tires i ended up going with on my 15x6 steelies (34x9.5r15 tsl super swampers). However, i ended up finding a set of 15x8s that are at the powder coater as i type. What are you guys running on you 15x8s with a 4in lift?
35x12.5 with a little bit of fang trim in the front. I put longer shackles on now and probably wouldn’t need the extra trim anymore but it doesn’t hit off-road anymore either. Could probably fit skinny 37s as well.
72 3/4 ton blazer. 5 inch lift on 35 inch tires. 355 corvette engine with crane roller rockers, rv cam, edelbrock carb and intake with one inch spacer. Thrush Headers with flowmaster 40 duels. 4speed sm465 manual. 4 wheel disk brakes with Inboarded rear shock prerunner style mounts and shocks.
Chulisohombre is offline   Reply With Quote
Old 01-23-2019, 03:28 PM   #53
bigdon-70blazer
Painted these traditionally. Open face steelies.
bigdon-70blazer is offline   Reply With Quote
Old 01-24-2019, 02:49 PM   #54
fun in dirt
fun in dirt's Avatar
37" on 16.5 homemade to 9.75 wide - painted with Rustoleum hammered black, which comes out dark gray.
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432
'85 K30 "Big Nassy"
'06 3500 Duramax ...tow truck
'06 Silverado SS...DD
'06 C1500 WT...DD
'07 Classic C1500 WT...DD
Built & sold cause can't keep 'em all:
'72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190
'55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938
'69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541
'86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619
fun in dirt is offline   Reply With Quote
Old 03-05-2019, 04:49 PM   #55
jimmy70
jimmy70's Avatar
Running 31x10.5x15" on stock 15" x 6.5" stock steel wheels on my '72 4x4 Jimmy / stock suspension.
jimmy70 is offline   Reply With Quote
Old 03-05-2019, 06:15 PM   #56
Sandtrap9072
Sandtrap9072's Avatar
33x12.50R15's Mickey Thompson Baja Claws mounted on 15x8 steelies.
Sandtrap9072 is offline   Reply With Quote
Old 03-07-2019, 07:35 AM   #57
rsavage
rsavage's Avatar
15" X 8" Wheel Vintiques steelies with Mickey Thompson Degan 38 32" X11.50 " tires. I have hub caps but haven't yet decided if I am going to put them on.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 06-04-2019, 11:38 AM   #58
Ryanz
Originally Posted by DeadheadNM View Post
Nice ride's fellas! Here's a side shot of mine....
This is gorgeous - what size of tires and lift?
Ryanz is offline   Reply With Quote
Old 06-04-2019, 11:47 AM   #59
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Thank you - I miss that one. 4" lift and 33 x 10.5" old style BFGs. I went with zero lift on my current Blazer with same size tires. With the 4" lift it was tough for my wife to get inside. That said, I still added the accessory steps to my zero lift current Blazer for her.
Old 06-04-2019, 11:50 AM   #60
Ryanz
Awesome. I'm running the 12.5/33's - no lift but new leafs so it sits up decently. Thinking of going to the 10.5s for potentially better steering.
Old 06-04-2019, 01:30 PM   #61
argonaut
argonaut's Avatar
Rsavage, what is the backspacing on those wheel vintiques? And do the stock dig dish hubcaps fit onto the nubs?
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
Old 06-05-2019, 06:41 AM   #62
rsavage
rsavage's Avatar
I believe they are 4.25" back space. It puts the inside edge extremely close to the tie rod ends. Thought I would have to run 1/4" spacers so put some longer studs in the hubs in preparation but ended up not needing to. The nubs accept stock type caps. One thing I found is that these wheels are not perfectly true from the manufacturer. I didn't notice that on the 15 X 6 set on bought for my Vette or the 14 X 7 set I put on the 65 GTO. Had to make sure that the two used on the front of the Blazer ran true - that's how close the inside wheel lip is to the tie rod end.
1961 C1 Corvette
2021 Durango RT 5.7
Old 06-05-2019, 07:09 AM   #63
argonaut
argonaut's Avatar
Thanks! That is great info. I like that you can use the stock caps, but my concern also was whether or not they would clear the tie rods in front. I have an older set of 15x8 wheels that are about 3-7/8" backspace and they are fairly close as well. Maybe I should restore these instead of buying new. Hmmmm....
1980 Jeep Wagoneer
2005 Honda RC51
1981 Honda CB750C
Old 06-06-2019, 10:21 AM   #64
praisegeetarman
Here's my 71. I had a set of 16X7's made for it with maximum backspace. (If I remember correctly, 4 1/4" backspace). It has a set of 235/85/R16 Hercules mudders mounted up on them
71 Blazer 4X4 (unmolested, all original (including paint) 74,000 mile barn find)
67 Camaro RS SS (unmolested, all original (including paint) 81,000 mile barn find)
Keith Riel
praisegeetarman is offline   Reply With Quote
Old 06-10-2019, 03:54 PM   #65
GMC-YA68
GMC-YA68's Avatar
I know it's not for everyone, but I REALLY like these wheels. Been contemplating for while.
-Keegan-
'72 Jimmy 4x4 - 5.3/4L65E/NP205 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=663780
GMC-YA68 is offline   Reply With Quote
Old 06-10-2019, 06:30 PM   #66
craneboy72
craneboy72's Avatar
12:50 33” km2s
craneboy72 is offline   Reply With Quote
Old 12-08-2019, 06:48 PM   #67
Ryanz
Originally Posted by mdunn View Post
Finally got mine back from the powder coater and got the tires mounted. Need to finish painting the dog dish bowties, but at least a step in the right direction....
What size tire are you running? Do your Steelies have 4 nubs? I’m trying to find some. But only found with 3 nubs so far.
Old 12-08-2019, 07:15 PM   #68
craneboy72
craneboy72's Avatar
They are 12:50 x 33” on 8” 4 nub Steele’s. My buddy just found some 3 nub from firestone with the correct back spacing for the calipers. I was always told 3 nub does not clear. I just saw hillbilly wizard.com has some m1009 rims but they are pricey. Mine are m1009 rims
