01-28-2013, 11:48 AM | #452 |
Re: 86 squarebody made2drag
01-28-2013, 01:48 PM | #453 |
Porterbuilt.
01-30-2013, 12:25 AM | #454 |
looking good !
Sin7 = Luis 1959 Apache |
01-30-2013, 12:30 PM | #455 |
02-02-2013, 06:36 PM | #456 |
my 86 c10 build: http://67-72chevytrucks.com/vboard/s...d.php?t=496829 my 56 3100 build: http://67-72chevytrucks.com/vboard/s...09#post5712509 my 95 silverado build: http://67-72chevytrucks.com/vboard/s...35#post5879335 my gray 86 c10 http://67-72chevytrucks.com/vboard/s...34#post7624734 |
05-14-2013, 10:40 AM | #457 |
Did you ever get your rear shocks mounted?
05-14-2013, 12:00 PM | #458 |
yes, i used front shocks from a 73-87. mounted bottom mounts to the leaf spring lower hardware plates and then upper shock mounts welded to the U shaped upper bag mounts. with the 2500's i have on the rear now the shocks only make a difference when i ride with the bags with less than 40 psi. i am currently looking for narrow but taller bags to fit in the space but allow me more lift and let the shocks work better. i think the only real answer is to use sleeve bags. ive heard they ride well.
my truck rode a 100 times better when i had 2600's mounted on the leafspring closer to the cab. i lost the ride placing them on the axle but i prefer them there for maintenance reasons, being able to see them in action while driving and knowing my truck will carry more load when i need it to
06-15-2015, 12:08 AM | #459 |
Howdy! Nice build I love those mid 80s C 10s. Nice work with yours ,
Have a good week,
64 C10 Fleetside LB 4 Sp/292 Build http://67-72chevytrucks.com/vboard/s...d.php?t=602438 70 GMC 1500 Fleetside LB 3OT/350 Build http://67-72chevytrucks.com/vboard/s...83#post6767983 76 GMC CCLB Dually Build http://67-72chevytrucks.com/vboard/s...d.php?t=691612 79 GMC 3500 Fleetside LB 454/400 90 Suburban Silverado 4x4 350/700R4 97 1500 Cheyenne Short Fleet 350/5sp |
06-15-2015, 01:45 PM | #460 |
thanks!
10-27-2015, 01:28 PM | #461 |
Sweet truck does it drag when driving?
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
