Old 11-18-2016, 08:37 PM   #1
leonphelps
rear control arm bushings
is it possible to just unbolt behind the cab to change these?
thinking a c clamp should let me do the job.
trying not to take the whole rear end apart to do it.
thanks for any suggestions.
leonphelps is offline   Reply With Quote
Old 11-18-2016, 09:46 PM   #2
PGSigns
PGSigns's Avatar
Re: rear control arm bushings
To get mine out I had to pull the trailing arm. I went with urithane so I needed to leave the outer sleeve in it from the old bushing. I used a hole saw to drill out the rubber. Those things are in there good and are not easy to get out. I don't think it will work just pulling the front bolt.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 11-18-2016, 10:00 PM   #3
dracko
dracko's Avatar
I haven't done it, but with the bolt out, could you drop it down out of the mount and burn the old bushing out with a torch?
dracko is offline   Reply With Quote
Old 11-20-2016, 12:54 PM   #4
leonphelps
I was figuring on trying with a c clamp first then if that doesnt work trying to drill the bushing out then the c clamp.
Ill let you know when I give it a try tonight.
Old 11-20-2016, 12:58 PM   #5
The Rocknrod
Moderator
The Rocknrod's Avatar
I did it with a C-Clamp and a socket (wrench type) I forget what size but a larger one I had in my drawer.
Once the center race was out I worked out the rubber.
Old 11-20-2016, 02:09 PM   #6
bumwine
bumwine's Avatar
When I did mine I supported the truck with jack stands at the rear of the frame. Dropped the front bolts and drilled through the old bushing several times and tapped it out with a chisel. Installed my new urethane bushings and put her back on the ground
bumwine is offline   Reply With Quote
Old 11-20-2016, 02:22 PM   #7
dracko
dracko's Avatar
Sound like some solid ideas, avoiding using the torch is good, the rubber fumes are toxic.
Anybody done this job with the arms still attached at the axle with the sleeved bushing replacements? Figure I can just cut the old cups out with a sawzall but pressing the new ones in might be interesting.
Old 11-22-2016, 10:08 PM   #8
leonphelps
I just did it with the poly bushings and the new inner sleeve. The first one was a little tough, but second one was easy.
I did bend the bottom of the brackets 1/4" to center everything. After in, when the bolt tightened the pieces bent back to straight.
Figure that rubber would have been a walk in the park. Not really a poly fan, place I ordered from sent me the wrong ones.
Old 11-23-2016, 11:59 PM   #9
dracko
dracko's Avatar
Good to hear, what method did you use to get the old bushing/sleeve out?
Old 11-24-2016, 08:18 AM   #10
leonphelps
I got the first one half way out with a c clamp. The second half went out with a hammer.
The second one went out with a hammer to a straight bar. Second one was way easier.
The c clamp is tougher; you need to hold c clamp, hold large socket and tighten.
I made sure to drill way more holes with the second one. no chance of any rubber holding me back.
Old 11-25-2016, 12:22 AM   #11
dracko
dracko's Avatar
Okay cool thanks for the info. I was really thinking I would need to remove the arms to do thi.
The C clamp is a great idea but I could see if being a PITA
Old 11-26-2016, 04:23 PM   #12
leonphelps
once the bolt is out, get a crow bar and push down on the arm. Once the arm clears the frame, put a long piece of metal between the arm and the frame to keep it down out of the way. Gives you a little more room to drill.
Old 08-29-2017, 01:14 AM   #13
mrjata
I am doing the poly bushings but am not sure which way they go in. The instructions were very vague at best. Can ya help a brother??
mrjata is offline   Reply With Quote
Old 08-29-2017, 05:53 AM   #14
James903
I hope you have better luck then I did. I couldn't impact them off or use my super long breaker bar to even get them to budge. I ended up having to cut them off as well as the ubolts on the axel. Since I had to go though all that trouble I just pressed the bushings out. I already had the bed off so it wasn't that hard to get to.
James903 is offline   Reply With Quote
Old 04-18-2018, 08:56 PM   #15
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Subscribed
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is online now   Reply With Quote
