08-19-2021, 11:15 PM | #1 |
Repairing Radio Cutout
I am looking at a 72 C20 that a previous owner enlarged the original radio cutout to accommodate a later model radio. I HATE THAT! So...is there a reasonable way to return that to original?
I believe one could get an original patch from a donor truck, weld it in, and repaint to match original. However, that is beyond my skill set and I expect would be very expensive to have a body shop do. So is there hope??? Thanks!
1972 C20 402/TH400/3.54 Highlander 1969 Camaro RS with SS trim, 1967 Camaro RS/SS (sold) 1983 GMC Sierra Classic 2500 crew cab (sold) 1972 Chevy C10 Cheyenne Super (sold) 1984 Chevy Silverado C20 crew cab (bought new by my uncle, in the family until I sold it) |
08-20-2021, 12:44 AM | #2 | |
Re: Repairing Radio Cutout
Then I would buy the correct paint from an automotive paint shop - have them put it in a rattle can for you - tape off the dash, and spray it myself.
DAVE Edmonton, Alberta 1959 Apache 1967 K20 1968 C20 1970 C10 1972 GMC 2500 1981 C10 |
08-20-2021, 01:06 AM | #3 |
This thread has some photos and an explanation of a good way to cut a patch panel.
http://67-72chevytrucks.com/vboard/s...d.php?t=823465 My truck had a butchered dash when I bought it. I replaced my entire dash by drilling out the spot welds in the window opening. This required removal of the windshield. I have good enough welding skills to fill in spot welds, but I didn't trust myself to weld in a patch panel to my satisfaction. I wanted to do the work myself, so that's why I did it this way. Welding in a patch panel would definitely be way easier for someone with the right skills. |
08-20-2021, 03:58 AM | #4 |
brothers truck, LMC, and others sell radio restoration panels and with some of the bonding supplies available now, jbweld etc. they can be installed without welding and with permanant results. hope this helps
08-20-2021, 08:44 AM | #5 |
Got pics? Maybe a radio delete cover will work to hide the mess
08-20-2021, 10:06 AM | #6 |
Welding and repainting is a big job on an already running/driving truck. For me I made 3 patch panels. One from aluminum, one from wood, and one from ABS. I ended up using the ABS piece as I don't have woodgrain Cheyenne interior. For <$5 it was a reasonable solution for me.
08-20-2021, 10:28 AM | #7 |
https://www.brotherstrucks.com/1967-...tinfo/DFRP072/
i didn't use it, my project isn't a restoration but here's a link. They also sell a single din repair surround that I did use that made the butchered hole look factory. https://www.brotherstrucks.com/1967-...tinfo/BRB6772/ Both are a bit spendy but if you want a pro look and dont have pro skills are money well spent, imho Last edited by bob arrington; 08-20-2021 at 10:30 AM. Reason: more info |
08-20-2021, 11:52 AM | #8 |
Below is a link to one of my post's for a low-cost do-it-yourself radio delete. It could be used as a temp solution if you decide to patch/weld your dash in the future or even as a permanent solution if you are happy with the look/results.
http://67-72chevytrucks.com/vboard/s...d.php?t=655585
66 GMC Suburban Custom 66 Chevy K10 Suburban |
08-20-2021, 01:11 PM | #9 | |
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
08-20-2021, 02:56 PM | #10 | |
08-22-2021, 08:48 AM | #11 | |
https://www.crutchfield.com/p_120ABS...ra-ABS316.html Take your time cutting it slowly with a jigsaw or it melts & gums up the kerf, but can sand/file edges to smooth it all off slick.
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432 '85 K30 "Big Nassy" '06 3500 Duramax ...tow truck '06 Silverado SS...DD '06 C1500 WT...DD '07 Classic C1500 WT...DD Built & sold cause can't keep 'em all: '72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190 '55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938 '69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541 '86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619 |
08-22-2021, 10:47 AM | #12 |
Well as others have shown there are some quick, easy options that will work. It all depends on how far you want to take it. For me I cut a patch out of a donor truck. The patch I cut was just around the radio opening of the donor and welding it in. My welding skills are not the best so it took a long time to get it to look right.
IF I were to do it again I would cut out the donor patch as shown by the blue tape in the pic. The reason for such a large patch is that 80 to 90% of the welding is hidden. This would allow for the welding that doesn't look the best to hidden, be so much faster than the way I did it, and be a lot cheaper. That's my experience anyway. Keep us posted as to what you decide to do. NOTE: Please disregard the blue tape by the ignition switch. That marks a small paint touch up I need to do. The ignition switch decided to give me a had time when I went to install it.
-------------------------------------------------------- 1967 C10 "Snowball" (Currently in a million pieces down from a bazillion) 1989 Toyota DLX pickup "The Hulk" 2012 Jeep JKU "Crush" 1976 Chevy short bed with a 327 and 3 on the tree (Sold it to buy the Blazer) 1971 Chevy Blazer (Sold it) Last edited by Peanut74; 08-22-2021 at 10:50 AM. Reason: added note |
08-22-2021, 11:01 AM | #13 |
Since the OP said back to original abs isnt going to help . OP you have one options buy a patch panel . I chose to make this to mount an original type radio I made it on it on a plasma cutter I planned on just using panel adhesive. Never got around to it though so the din is still in the truck. Made from heavy gage stainless.
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
