Old 06-16-2018, 11:41 AM   #1
jabborabbo
jabborabbo's Avatar
Heat riser valve...
On my 67 L6 the thing flops back and forth as soon as I crank the engine...it’s also in the general vicinity where I’ve located my manifold leak. The coil spring isn’t broken - I can operate it by hand with the engine not running. Anyone have any experience or thoughts about this????
jabborabbo is offline   Reply With Quote
Old 06-16-2018, 12:19 PM   #2
jabborabbo
jabborabbo's Avatar
Re: Heat riser valve...
Ok, it’s not flopping so much as vibrating a bit...and the knock doesn’t go away when I push it open or closed while the motor is running, so it’s back to the diagnostics drawing board for me....
Old 06-16-2018, 05:06 PM   #3
LockDoc
The Older Generation
LockDoc's Avatar
Sounds like it is working correctly but maybe the spring is weak. The pressure from the exhaust has to open it some when it is cold so there is no back pressure, so it should open a little every time an exhaust valve opens. When the engine is hot the coil spring expands and holds the valve open all the time. If you open it by hand when the engine is cold it should rotate back to the closed position when you release it.
LockDoc
Leon
Old 06-17-2018, 04:31 PM   #4
jabborabbo
jabborabbo's Avatar
LockDoc
Thank’s for the reply! It does rotate back when I open it by hand, but the spring seems kinda weak - I had never noticed the thing until I started looking for the manifold leak.
"It is hard to search for a black cat in a dark room, particularly if it is not there. Especially if this cat is smart, brave, and polite." Sergei Shoigu, Russian Minister of Defense
Old 06-17-2018, 05:49 PM   #5
Jason Banks
Jason Banks's Avatar
Mine was leaking there too. I replaced the whole manifold with aftermarket. But I believe you could re-bushing the shaft to cure the leak.
I got a great deal on the aftermarket manifold...so instead of trying to fix it, I replaced it.
You can find my review on Amazon
https://www.amazon.com/ATP-Automotiv...ws/B000IYCY3E/
Jason Banks is offline   Reply With Quote
Old 06-17-2018, 05:59 PM   #6
Jason Banks
That flapper is in there to either allow hot exhaust up to the bottom of the intake or shield the bottom of the intake from the hot exhaust.
I recall a past thread where someone said they removed the shaft and drilled and tapped the holes for plugs, or maybe they locked the flapper in place and sealed up the holes somehow.
Old 06-18-2018, 11:17 AM   #7
Steeveedee
Who Changed This?
Steeveedee's Avatar
It helps heat up the engine so you get up to operating temp sooner, for better mileage. If you want to delete it, you can just put a bolt all the way through with a nut on the far side. That way you won't have to tap the manifold. A bolt will offer no more back pressure than the shaft and straight flap would.
~Steven
Simi Valley, CA
Old 08-10-2021, 01:21 PM   #8
4thgencreamsicle
LockDoc
Thanks for the explanation! I have been trying to figure out what this thing is (newbie over here)! Mine at some point was pulled open and is being held open with bailing wire. Ugh. I’m guessing it has a weak spring and we’ll be looking to replace it.
4thgencreamsicle is offline   Reply With Quote
Old 08-10-2021, 03:12 PM   #9
LockDoc
LockDoc's Avatar
No problem. It's actually a pretty simple device once you understand it.
LockDoc
Leon
