11-11-2017, 01:21 PM | #1 |
Center boring a GM transport wheel
I have a small dilemma. I have a 67 c10 typical 6 lug drum brake set up. I recently acquired a complete set and they just will not fit the hub. The center hub on drum in a conical shape and it doesn't like much to fit flush.
I thought about a spacer kit and bought one but it just doesn't fit flush over the lugs either. Does anyone know what diameter I need to have my wheels bored to? Thanks in advance |
11-11-2017, 10:15 PM | #2 |
Re: Center boring a GM transport wheel
Surely somebody has performed this. I can't be the only one struggling with this.
11-11-2017, 10:57 PM | #3 |
Best way is to pull your brake drum off and measure the center hole in it. I am pretty sure it's 3.5 inches. You should be able to take them to a machine shop and have them opened up. But measure your back spacing. Most say you need 2 inch spacers to have the wheels fit in the wheel wells in the back without hitting.
11-12-2017, 11:17 AM | #4 |
Born Psycho
i would not recommend boring out the center hole, it will weaken the wheel. when i was a kid my dad had a 72 scout which has the 5 on 5 1/2 bolt pattern, same as older ford trucks. the center hole of ford truck wheel is smaller so he had our local machine shop bore them out. the wheels ended up cracking between the lug hole and the center hole because the center hole lip was bored out which took away the strength mounting area.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
11-12-2017, 11:30 AM | #5 |
x's 2 on what Mr. Moss stated.
11-12-2017, 12:48 PM | #6 |
67-72 parts collector,…
Check out @themaintenancedepartment or @dillman1977 on Instagram.
They have been modifying these transit wheels for a long time. They also do 5-lug and 8-lug conversions for these wheels.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 11-12-2017 at 12:54 PM. |
11-12-2017, 02:20 PM | #7 |
Thank you guys. There is a lot of meat left in these centers for safety sake. It really don't need about a quarter inch to clear. I want a true ride on hub wheel vs riding on spacers. My reputable machine shop asked me to pull my drum and hub for a proper fit. Just don't want to cripple my vehicle while I'm getting them machined out.
11-12-2017, 03:14 PM | #8 |
I don't think the amount of material you take off is the problem. If you look at the picture is post #6 you see that they took out the crease around the middle hole. The crease is what gives it strength/rigidity.
11-12-2017, 05:08 PM | #9 |
Thank you guys. So do you feel riding on aluminum spacers is a safer bet?
Let me ask this senerio? So let's say I trim out enough to fit snug and flush on the hub, and have full length studs for tightness, even though it may be weaker, how is that any worse than aftermarket wheels that have huge center hubs, and only riding basically on the wheel studs? Last edited by stewmagoo73; 11-12-2017 at 05:14 PM. |
11-12-2017, 05:53 PM | #10 |
FWIW, I had the centers of the stock steelies on my 67 opened up to fit center caps and havent had any problems in the past 5 years. Part of the center rib is still there but its extremely thin, and the lug nuts are what is centering the wheels now.
-j-rod '06 3500 LWB CC 4wd, 8.1 Allison |
11-12-2017, 07:03 PM | #11 |
its never a good idea to rely on the tapered surface of a lug nut to maintain the wheel on center.
also, the center portion of the wheel, and the area of it that interfaces with the hub are hardened by working the metal when it is pressed to that shape and by the heattreatment of the sheetmetal when it is actually manufactured. among safety inspectors in the dragracing community it is not allowed. I had a ford 9 inch rear modified to install under a 50 pontiac, it used the 50 pontiac rims wich had a different inside diameter.. the wheels kept comming loose. I took it to a shop that installed my tires and their solution was to put the lug nuts on with so much force that I could not remove the lugnuts with a wrench. I took it back to them and when the attempted to remove the lug nuts they stripped the studs out of the axle flange. when in doubt, consider this. the engineeres did things for a reason, and the accountants did too. |
11-12-2017, 07:21 PM | #12 | |
11-12-2017, 08:35 PM | #13 |
I dont know transit, transport or DOT approved wheels.
an apples and oranges comparison but with unsafe consequences some safety organisations do not approve them and for good reason. I know that the fasteners that hold the wheels on huge trucks are themselves different and function specifically to fasten the wheel on and center the wheel. automotive lug nuts dont do that, or rather are not designed to do that. maybe theres a good reason or two not to do it. BY all means justify doing it but also accept the consequences. Last edited by mike16; 11-12-2017 at 08:52 PM. |
11-12-2017, 09:42 PM | #14 |
I had the centers bored out on my transits. The axle hub specs at 3.5” but my center bore is about 3.6”. It definitely doesn’t center the wheel like the stock setup does, so it’s all up to the studs/lugnuts to center the wheel. That being said, I haven’t had any issues with vibrations or loose wheels. I have upgraded to longer Moser studs as well. If I were to do it again, I definitely would have pulled the axles and had the hub turned down to fit snug in the transit wheel center bore instead. As was mentioned above, these wheels won’t fit on the back with the 6” of backspacing. I flipped the centers on mine to give me 4”BS and they fit perfectly now. Oh, and these wheels are DOT approved, it’s stamped right on them.
Builds: Green Gus the 68 C10 ; Sullii the 72 1500 - Instagram: @dr.hewitt - C10 Concept/Development Photos: Master Thread |
11-13-2017, 06:44 PM | #15 |
C10 Collector
Easiest way to fit the front is 1/2" wheel spacer and longer studs. Then the wheel will sit flat. I ran like this for over a year.
On the rear you can use a 1.25" spacer or I did as the guy above and flipped my rears.
///Ryan 1972 Chevy C-10-Bagged, Blown LT1, 700r4, Suicide Doors 1967 GMC- SC & Cam'd 4.8, built 4l80, 3200 stall, posi, 4.10 1967 Chevy LWB- 454 and patina 1971 Blazer - Rusty 1968 Crewcab project |
12-10-2017, 06:26 PM | #16 |
So my question is this. Can you not run these wheels without a spacer due to backspacing ?
12-10-2017, 09:04 PM | #17 | |
In the rear, you CANNOT run these without a spacer in the stock size (22x9 w/ 6" BS). The wheel will interfere with the edge of the bed floor. You basically have two options here as well: 1) flip the center and do a custom backspace between 3.5" - 4.5", or 2) run at least a 1.25" spacer. How much depends on which rear end you have (earlier pre 69 rear, or 1.5" wider 69-up rear).
12-11-2017, 10:43 AM | #18 | |
12-11-2017, 11:44 AM | #19 |
The other option is machine down the center of the rotor or hub to fit the wheels, I changed to 5 x 4 3/4 pattern once and had the rotor machined to fit he wheel. Check it to see if the hub or rotor has enough meat to machine it down.
12-11-2017, 03:32 PM | #20 |
This is definitely a good idea too, and actually the way I would have gone if I were to do it again. The rear axles can easily be pulled out and machined down to match the center bore size on the transit wheel. The only thing you'll have to figure out then is backspacing (either run a spacer or change the backspace on the wheel). For the front, if you do a disk brake swap then the transit will fit without issue.
12-11-2017, 03:48 PM | #21 | |
What is everyone doing here?
12-11-2017, 04:08 PM | #22 |
10-24-2018, 09:55 AM | #23 | |
10-24-2018, 10:01 AM | #24 |
C10 Collector
So I reversed my wheels to get the backspace correct. Then I (myself on my lathe) turned down the hub register to fit the wheel. I left it the stock OD for the drum, then stepped it down to the rim size. A disc brake conversion really should be done on the front so its a moot point anyways.
10-24-2018, 01:00 PM | #25 |
Whether or not you decide to go this way have the machinist measure your hubs. That way you will avoid any arguments if the wheels don't fit correctly when you get them back. That's why the shop wants you to give them the hubs, so they are covered. Explain to them that you need to keep driving the truck. Or find a spare hub and take that to the machinist.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban the WMB,1991 S(stink)-10 Blazer,1969 GTO, 1970 Javelin, 1952 F2 Ford 4X4, 29 Model A, 72 Firebird. 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
