Spare Tire Tub Lid
I most likely will not be using my spare tire tub to hold the spare due to my tire size. I was thinking about making a lid for the spare tire tub to use that as storage and also extending my flat area of the bed when the lid is closed. Has anyone done this or seen someone do it?
Thanks. |
The Older Generation
Re: Spare Tire Tub Lid
I haven't seen anyone do that. Please post up some pictures of how you do it if you go through with the project.... LockDoc
Junior Member
Welcome to the board neighbor! Post up some pics of your burb!
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 |
I have a long list of things that need to be done. If I ever get around to the lid idea, I will try to do a write up.
Is that a 68? I like the taper on the hood leading edge. My 69's is almost straight up & down. Your hood has a much sleeker look.
Excelant idea! Since the floor in that area is plywood, a matchin cover should be easy. And you already have bolts holding the spare tub in place.
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
It is a 72 with a 68 clip. I bought it that way. I find the 68 front end to be a lot sleeker than the 72. I picked this burb up last October, so it is still new to me.
Too many projects
I have a little piece of plywood covering mine that the previous owner had made up. Nothing fancy, and I keep extra ratchet straps in the spare tire well. I can grab a picture if ya'll want one, but there aren't any hinges, it just sets on.
Andrew 84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck" |
