11-09-2017, 10:58 AM | #1 |
C10 CLUB Y QUE!
Gmc v6 ignition problem
Buddy of mine is having spark problem and im trying to fig out how to solve his issue. No spark. V6 points. I started with the coil it has 12 volts going in. I turn the truck over and no spark at the plug. Replaced the coil and still no spark. Is there amything else i sshould be Looking at.
11-09-2017, 11:07 AM | #2 |
Re: Gmc v6 ignition problem
Replace the points and condenser. Set the dwell to spec.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent. |
11-09-2017, 11:16 AM | #3 |
C10 CLUB Y QUE!
condenser is that round thing in the cap with a wire going to the points.?
11-09-2017, 11:17 AM | #4 |
C10 CLUB Y QUE!
what happens if I still don't get any spark?
11-09-2017, 11:31 AM | #5 |
There should be a ballast resistor wire that limits the voltage to about 9 volts. 12v into the coil damages the condenser and points. If there is still no spark after all parts are replaced correctly then the distributor is internally grounding somehow. Then you swap out the distributor for another. You need to get a service manual that guides you through trouble shoots. Or do more research online. There is another site you can also post for help. Jollys gmc guy site http://6066gmcclub.com/index.php
11-09-2017, 11:59 AM | #6 | |
C10 CLUB Y QUE!
I checked the incoming power to the coil and that 11 to 12 volts. is their a resister on the wire from the ignition switch? |
11-09-2017, 12:30 PM | #7 | ||
Moderator
11-09-2017, 12:40 PM | #8 |
1962 C-10
Make sure the points are adjusted correctly. Around .017", I believe?
Joseph Chavez "See the USA in a Chevrolet!!" ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1962 C10 Shortbed Fleetside 327/th350 GV overdrive 1974 C10 Longbed Fleetside 350/th350 "The Trash Truck" 1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4 2015 GMC Sierra SLE 1500 4x4 |
11-09-2017, 01:10 PM | #9 |
C10 CLUB Y QUE!
this is before the coil correct and if this is damaged I wouldn't get any power to my coil?
11-09-2017, 01:35 PM | #10 |
Moderator
11-09-2017, 01:39 PM | #11 |
C10 CLUB Y QUE!
Standard troubleshooting procedure:
Take off the distributor cap so you can see the points. Turn on the ignition switch and rotate the engine by hand until the points are open. Now use a multimeter or test lamp to check for power at both the (+) and (-) terminals of the coil. If no power on either one, you have a break somewhere between the coil and the switch. Work backward toward the switch, checking at each point where there is a terminal or connection until you find the break. If you have power at (+) but not at (-), disconnect the lead going to the distributor. If you have power at (-) now, you have a short to ground somewhere in the distributor or the connecting wire. If you still have no power at (-) with the lead disconnected, you have an open coil primary, but this is VERY rare. If power at both (+) and (-), turn the engine by hand until the points are closed. Now you want to see power at (+), but not at (-). If you still see power at both terminals, you have a break between the coil and the distributor, or else the points aren't making contact. |
11-09-2017, 03:08 PM | #12 |
For about $75.00 you can change out all the internal components with Petronix Electronic Ignition, I did mine 6 years back and have not had any problems with it.
http://s1299.photobucket.com/user/jb...23904108567829 |
11-09-2017, 03:34 PM | #13 |
C10 CLUB Y QUE!
I would if it was something i get locally. I meed to get it running asap
11-09-2017, 04:17 PM | #14 |
call NAPA or ORielles you can go and order it from their website as well.
11-09-2017, 11:14 PM | #15 |
C10 CLUB Y QUE!
Ok i pulled the dizzy out cleaned it and put it back. Started fine. Went for a ride drove a block away and shut off.. wouldnt start till 5 min of sitting
11-09-2017, 11:18 PM | #16 |
11-09-2017, 11:53 PM | #17 |
C10 CLUB Y QUE!
Yeah im getting fuel.. what would cause that?
11-09-2017, 11:55 PM | #18 |
C10 CLUB Y QUE!
Do tgis dizzy have a pick up?
11-09-2017, 11:56 PM | #19 |
11-10-2017, 12:27 AM | #20 |
C10 CLUB Y QUE!
So.maybe the wire that goes from the coil to the inside of the Distributor
11-10-2017, 08:33 PM | #21 |
