Old 09-19-2017, 09:16 PM   #1
64patina
'60-66 American Auto Wire questions
I just bought a brand new wiring harness for me '62 and was wondering about the headlight wires, in the top corner by the master cylinder there was a plug/grommet and on the replacement it seems like the new wires just run right through no plug, are people just running it like that or putting a plug in?
64patina is offline   Reply With Quote
Old 09-19-2017, 09:19 PM   #2
Clyde65
Clyde65's Avatar
Re: '60-66 American Auto Wire questions
I have done both actually. If a show vehicle then get a plug.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 09-19-2017, 09:27 PM   #3
fredhlynch2
Like 64 Patina I have been wondering about the same thing. Will run a new harness soon and would rather use something that looks professional as opposed to typical hardware store rubber grommets. Any sources for what the pros use to bundle wires and pass through the firewall (with some weather protection) would be very helpful.
fredhlynch2 is offline   Reply With Quote
Old 09-19-2017, 10:20 PM   #4
rvrfoot
Put a plug in it.
rvrfoot is offline   Reply With Quote
Old 09-19-2017, 10:35 PM   #5
The Rocknrod
Moderator
The Rocknrod's Avatar
I think the one your referring to is this one: https://www.americanautowire.com/sho...tor-kit-9-wire
Old 09-20-2017, 06:48 AM   #6
PGSigns
PGSigns's Avatar
All that was in my AAW kit I used on the 65. Some assembly required. What kit did you get? I used the classic update kit for these trucks.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 09-20-2017, 07:23 AM   #7
bj383ss
bj383ss's Avatar
Mine had the plug as well.
You can see in this pic I don't have the headlight harness plugged in.
20170914_144344 by bjohnson388, on Flickr
Bret
64' Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=586955
bj383ss is offline   Reply With Quote
Old 09-20-2017, 11:39 AM   #8
Tonys1963
mine has the plug but did not come with the rubber gromet
Tonys1963 is offline   Reply With Quote
Old 09-20-2017, 12:36 PM   #9
rvrfoot
When you buy the wire harness the rubber is not in the kit.
Old 09-20-2017, 03:14 PM   #10
lsett
I was able to use the original grommet. It wrapped perfectly around the new harness.
lsett is offline   Reply With Quote
Old 09-20-2017, 03:16 PM   #11
rvrfoot
Get her done make it look nice LOL
Old 09-20-2017, 04:28 PM   #12
72cs20
I too used the AAW 60-66 classic update harness with my 62. The kit comes with all the plugs needed but not the grommets. You can get the correct grommets from any of the vendors that sell 60-66 parts. They will likely have all of them in kit form.
1966 K20 flatbed build thread - http://www.67-72chevytrucks.com/vboa...d.php?t=768827
62 C20 build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=703583
72cs20 is offline   Reply With Quote
Old 09-20-2017, 08:10 PM   #13
64patina
Thanks for all the feedback! my kit didn't come with the plug but I'm going to look into getting one
Old 09-20-2017, 08:11 PM   #14
64patina
Jimmy
I got the same one man
Old 09-20-2017, 08:12 PM   #15
64patina
That is the plan hopefully it works out! lol
Old 09-20-2017, 08:13 PM   #16
64patina
thats exactly what I'm after man thanks!
Old 09-21-2017, 11:53 PM   #17
Brad54
Brad54's Avatar
Quick tip: When you do the instrument cluster wiring, re-use the metal light sockets. Use the new connectors in the AAW kit, but use them with the original metal sockets that snap into the back of the instrument cluster.
That's the only complaint I had with my kit--the plastic light sockets left a lot to be desired.
The rest of the kit was top-notch!
-Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck!
'62 K-10 long-step project
'61 C30 Camper, aka "Valdez"
There's no cool like Old School
Brad54 is offline   Reply With Quote
Old 09-22-2017, 09:21 AM   #18
DakotaKid
One thing i havent had time to figure out yet is the wiper wiring on mine. I have a 62 and the plug is right but the second i put the fuse in it it pops the fuse.
Anyone know anything about what changes need to be made for this? they are just the single speed 62 wipers.
And i am using the AAW kit.
Current Project : 1962 Chevy SWB Fleetside
Others, 1958 Edsel Villager Station Wagon
1926 Ford Model T Roadster Hotrod
www.suedescarclub.com
DakotaKid is offline   Reply With Quote
Old 09-22-2017, 07:52 PM   #19
Brad54
Brad54's Avatar
DeD short inside the switch would cause that to pop.
A dead short wife would also do if.
I had the same problem with a factory spot light.
Old 09-26-2017, 07:18 PM   #20
rvrfoot
Bret
Very cleeeeeeeeeeeeeeeeeen.
Old 10-01-2017, 09:44 PM   #21
DakotaKid
Brad, i guess thats possible, but it worked before i changed the harness thats whats confusing me, and im usng the single speed wiper, is that an issue?
