Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1988 - 1998 GMT400 Chevy & GMC Pickups Message Board > projects and builds 88-98
Old 11-25-2011, 10:46 PM   #1
pacobeagle
Project: The Brown Nugget!
Hello all, this is my first post and figured I would list my truck and what I'm doing with it.
First off I purchased my 1997 GMC Sierra extended cab from a friend in a trade of sorts. I had to get the Dodge diesel of his tuned-up. So I did and payed for all of the maintenance items and did the labor. In return I get the truck which hasn't been running for a year and sitting.
Here's a picture of when I got it home.
Then a quick wash
pacobeagle is offline   Reply With Quote
Old 11-25-2011, 10:51 PM   #2
pacobeagle
Re: Project: The Brown Nugget!
I've installed a 2000 4.8l V8 in place of the 5.0l(of which I have spare parts). Here is a picture of what it looks like currently.
New(er) engine going in
Prelim setup(notice the placement of alternator)
Harness gone wild
Ebay intake off an H2 hummer
Sweet engine mounting(junkyard blazer ecu tray)
Old 11-28-2011, 10:53 AM   #3
dragginmetal
here, just not logged in
dragginmetal's Avatar
That "Harness gone wild" looks like a headache..... What are your plans for the truck?
dragginmetal is offline   Reply With Quote
Old 11-28-2011, 12:11 PM   #4
pacobeagle
Really, the plan is to try to keep it looking stock. I would really like to eventually convert it to the 6-lug set in order to get some of the fancier 17" factory wheels which I like. Also, I would love to add posi to it. For the most part, the truck will be a tow vehicle and regular all-arounder.
The harness, yes it's a PITA. My friend is a wire-harness genius though. He's grafted the harness together and is in the process of the final stage- wire loom. Hopefully, I'll be able to drive it before Christmas.
Old 11-29-2011, 05:07 PM   #5
jb1016
"Oh well, it's a driver."
jb1016's Avatar
I think this is just the second LS swap in this section. Very cool. Welcome to the board! And just so you know, there is a dedicated section for LS swaps under "engine and drivetrain." Those guys can answer just about any question, if you run into a head-scratcher.
Old 11-29-2011, 08:29 PM   #6
pacobeagle
Thanks for the kind welcome. So far my biggest "head-scratcher" is fabbing up a custom trans. cross-member. You see, I am using the 4.8L Y-pipe with catalytic converters(I don't want the fuel smell). Unfortunately, the 4.8l Y-pipe crosses over right underneath the tranny mount!! SO, I'm modding my OEM unit to fit. Eventually, I'd like a custom tube type cross member.
Old 11-29-2011, 10:48 PM   #7
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Didn't see ya in class tonight
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 01-12-2012, 04:53 PM   #8
75ChevyGuy
GM Parts Guy
75ChevyGuy's Avatar
Any updates on this?
1975 Chevrolet C-10 Custom Deluxe (DD/WIP)
1989 Chevrolet C1500 reg cab stepside (Winter Truck)
1977 Harley Davidson XLH 1000 (Summer Cruiser)
75ChevyGuy is offline   Reply With Quote
Old 01-12-2012, 05:33 PM   #9
pacobeagle
Currently, I'm waiting on some time to loom the wire harness. I stopped by Lowe's today to get some sawzall blades in order to finish customizing my trans. crossmember. I'm using the OEM '00 Y-pipe with cats and so I figure this will be better. The newer y-pipe merges right under the tranny mount so I have to cut and re-weld the cross member. Oh, and I guess from sitting, two of my injectors aren't working.
Old 01-25-2012, 10:59 PM   #10
pacobeagle
She's running, although a little rough. Decided against the custom crossmember. Custom exhaust is easier.
I've only driven it two miles and I've got some harness issues to resolve. Mainly, I'm lacking a speedometer, trip indication. As a result, I'm getting an ABS fail. Lastly, I've yet to wire the OBD-II plug for the new ecu.
Hope to be finished soon, it's been almost a year.
