Old 10-30-2017, 02:19 PM   #1
Depdon
1950 3100 door glass help
I really need some help with my door glass. I have full door glass with frames and have purchased the run channel but it is to thick so the inside door frame will not fit ? Any help and pics would be great thanks
Depdon is offline   Reply With Quote
Old 10-31-2017, 09:07 AM   #2
gigamanx
Re: 1950 3100 door glass help
Pics of your problem would help us too
Current Build Thread 1930 Ford Model A Modern Twist: Ford Model A Rat Rod With a Modern Twist
Build Thread Phase 1 "The Swap": 1949 3100 with S10 swap. Beginner build with ambition!
Build Thread Phase 2 "The Drop": Beginner Build with Ambition gets Air Ride
gigamanx is offline   Reply With Quote
Old 11-09-2017, 12:55 PM   #3
Chris(NJ)
Definitely need a better description of what the problem is. I can't really figure it out based on the OP. Take more than 30 seconds to construct the question and repost. And yea, some pics too, if you want.
Chris(NJ) is offline   Reply With Quote
Old 12-01-2017, 10:24 PM   #4
Iceburgh
Iceburgh's Avatar
1 post probably won't check back....
But channels are two different sizes. If I remember correctly Mon wing doors are thicker.
Both you shape and trimbto fit
1953 suburban build
http://67-72chevytrucks.com/vboard/s...d.php?t=621331
Iceburgh is offline   Reply With Quote
Old 12-01-2017, 11:03 PM   #5
joedoh
joedoh's Avatar
if you have a corrugated looking channel in the door currently, thats the remnants of the old felts. threw me off too fist time i did it, had to remove the channel to install the new felts.
Old 12-02-2017, 01:26 AM   #6
Jesse Z
Exactly. Sounds like you got the wrong channel. Go to your nearest auto glass shop and look at their selection of glass channels. Pick the one that best fits your application. The stuff is relatively cheap, no big loss.
Jesse Z is offline   Reply With Quote
