01-16-2015, 06:10 PM | #51 |
Re: 1961 Crew Max
Very nice to have the amenities to build up something like this...
It would have been cool to re-use the early hood rather than hack it up and find a tasteful way to make a subtle cowl shape with another "pontoon" shape down the center.. I really like the earlier hood/grill designs..
My '65 Suburban Resto build-- http://smg.photobucket.com/albums/v6...65%20Suburban/ And it's story of being 'saved' http://www.jalopyjournal.com/forum/s...d.php?t=631495 |
01-16-2015, 11:56 PM | #52 |
Re: 1961 Crew Max
This is the coolest! I will be a lurker!
Active duty Navy CPO 1961 C10 SWB 1963 C10 LWB (donor) 1965 C10 LWB BBW |
01-17-2015, 10:11 AM | #53 |
Re: 1961 Crew Max
01-17-2015, 01:48 PM | #54 |
SAVING ONE TRUCK AT A TIME
Re: 1961 Crew Max
I was able to pull some plastic pieces off the top of the motor. Also got boost tubes and air box out of the way for now. The engine harness was a little tricky to get out in one piece. CHIZZLER
53-suburban (99% done) 40-pick up (99.9% done) 12-cc lb dually D-max (dd) 61-crew cab D-max "PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT" 53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091 1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088 1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999 |
01-17-2015, 03:28 PM | #55 |
Re: 1961 Crew Max
Man you guys have some big &@!!$ to tackle jobs like these. I am nervous about the minor job I have to do with my truck, no way I could do one like this, even though I would love a crew cab
-Chapa 65 SWB step-side / 383 stroker / TH350 / 4:10 gears / static drop 4 1/2" front 5" rear. |
01-17-2015, 06:14 PM | #56 |
Re: 1961 Crew Max
Nice work getting the harness out Chizzler.
Going to be so cool....and you have a really good looking shop too! |
01-23-2015, 01:08 AM | #57 |
Re: 1961 Crew Max
Got a bunch of metal from top banana tuesday. Both front cab mounts are separated from the backside of the rockers making the cab drop on both corners. Trying to get it to where we can brace the inside and start cutting rockers and floor out. The last picture is the cab raised up of the frame as before it was resting on it. Don't have another cab to measure the gap.Chizzler
01-23-2015, 01:21 AM | #58 |
Re: 1961 Crew Max
I'd like to check this thing out sometime, maybe lend a hand if needed.
"It ain't as easy as Chip Foose makes it look" |
01-23-2015, 01:53 AM | #59 |
Re: 1961 Crew Max
That sounds good. Send a pm with some info.
01-23-2015, 11:57 PM | #60 |
1961 crewcab
Re: 1961 Crew Max
wow! lots of repair panels! almost 2 of everything!
I have a question about yours, in this pic where I put the arrow: does the door pillar just end right there? is the gap between it and the rocker finished? this part is completely gone on mine on both sides just wondering if that is how the coach builders left this piece.
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
01-24-2015, 12:24 AM | #61 |
Re: 1961 Crew Max
Hope this helps. it just ends.
01-24-2015, 12:28 AM | #62 |
1961 crewcab
Re: 1961 Crew Max
perfect, that does help, as mine just ends as of now... I am still amazed at how low tech some parts of these crews are.
01-24-2015, 12:36 AM | #63 |
Re: 1961 Crew Max
Yup. I think mine might just be in a little bit better condition than yours but not by much. Im excited to start fixing the metal. I will need to make sure im up on my tetanus shot. keep up the good work jon.
01-26-2015, 09:44 AM | #64 |
Re: 1961 Crew Max
time and patience but either way, your making some progress =0)
keep up the good work ....
dont want to hear excuses, i want to hear solution(s) |
02-01-2015, 04:29 PM | #65 |
Re: 1961 Crew Max
Can anyone help me with the difference from a 61 frame to a 63 and newer. I've read that the back cab mounts line up but mixed comments about the front. The new floor pans are for a 61 so does that mean i will need to cut the perches off the old frame or just open the holes up. I don't have a new frame yet. My old frame is a 3/4 ton. Thanks
02-01-2015, 05:45 PM | #66 |
1961 crewcab
Re: 1961 Crew Max
here are some pics: a 60-62 frame, and a 63-66 frame*, and then a 61 cab sitting over a 63 frame with the bolt showing where the 61 mount hole comes through compared to the 63.
** in the last pic you can see a 65 cab on a 65 frame and the hole in the foreground on the brace is where it is still punched out for the 60-62 frame what frame are you going to use? * pic is a 68 frame, visually the same as a 63-66 except for the front bumper mounts
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 Last edited by jonzcustomshop; 02-01-2015 at 05:55 PM. |
02-01-2015, 06:06 PM | #67 |
Re: 1961 Crew Max
Thanks. I have not purchased a new frame but looking at a 63-66. The new front floor cab support i got has a second hole inward. I would assume that is where the cab will now bolt. It looks like it lands right on top of the front to back c-channel floor support.
02-01-2015, 06:08 PM | #68 |
Re: 1961 Crew Max
Your last pic details it exactly. Thank you.
02-02-2015, 02:19 AM | #69 |
60-66 Nut
Re: 1961 Crew Max
Mounting a '60-'62 cab onto a '63-'66 frame is as simple as drilling a new hole for the front cab mount bolt farther inward. The cab mount on the cab is already contoured to fit.
02-14-2015, 10:23 PM | #70 |
Re: 1961 Crew Max
Well today i found a donor truck for the crew cab. Overall sheet metal is in great shape. 1961 4wd on a newer frame. Big block with a turbo 400. Bed and front sheet metal are very usable. Drivers door is awesome. Also got a second passenger door. Grill is in amazing condition. Tear down went pretty good. Chizzler
02-14-2015, 11:36 PM | #71 |
1961 crewcab
Re: 1961 Crew Max
are you going to use that 4wd frame and keep it as a 4wd long fleet?
the frame stretch for that would be 30 inches-that is how much the cab is stretched-
02-14-2015, 11:49 PM | #72 |
Re: 1961 Crew Max
I think the frame is from a 73 on. Im going 2wd so still looking for a frame. Hey jon i found this chalk number on the firewall over the olive drab paint. Does yours have anything like this? Also i think we have the exact same truck from the same builder.
02-15-2015, 12:13 AM | #73 |
1961 crewcab
Re: 1961 Crew Max
yeah I am pretty sure they are from the same batch , mine has #178 in that spot, and then: "341 green" on the upper cowl.
02-15-2015, 09:37 PM | #74 |
Re: 1961 Crew Max
cool build, I have been tossing around a similar idea seeing as I have a c20 and a beat up duramax. If for some reason you decide to go with putting the old body on the new frame check out this build http://www.2brotherscustomtrucks.com...ild_week1.html.
02-24-2015, 09:52 PM | #75 |
Re: 1961 Crew Max
Made some progress. Had to let go of one of my future projects to fund this one. Floor pieces are held in place like a jenga game right now. Touch it and it will fall apart.
