Old 05-15-2013, 11:23 PM   #1
Mikec10
Mikec10's Avatar
avs paralle4 link
http://www.avsontheweb.com/product.p...cat=335&page=1
does anyone know if this will work on a 73-87 with a truck 12bolt? Im just curious if the part that you weld onto the axel housing fits right, it looks pretty universal. Also, is a parallel 4 link good? or should i go with a wishbone 4 link, or a triangulated 4 link?
1980 C10 SWB Yukon 5.3/5 speed 3.73 gears.
Mikec10 is offline   Reply With Quote
Old 05-16-2013, 02:40 AM   #2
andrewmp6
Re: avs paralle4 link
It does look universal to me,But it depends a lot on what your trying to do with the truck.Are you going to bag it or run coilovers and are you going to lay frame or just lowered?
Old 05-16-2013, 11:27 AM   #3
Mikec10
Mikec10's Avatar
I plan on bagging it. Idk about laying frame but I'd definitely like to be as low as possible in the back.
With out having to z the frame or anything I want to bee as low as possible on a 28 inch tall tire
Old 05-16-2013, 04:52 PM   #4
AVS_JASON
AIRBAGPARTS.COM
AVS_JASON's Avatar
Our parallel 4-link is universal. It is designed to fit a 3" rear axle tube. But can be easily modified to work with a 3.5" or any other size tube you are running. That link also is our most popular with leaf spring GM trucks, where the gas tank will not affect the travel of the links.
AVS_JASON is offline   Reply With Quote
Old 05-16-2013, 07:26 PM   #5
Mikec10
Mikec10's Avatar
Awesome all I needed to know is if it fits a 3" axle tube. Thank you very much
Old 05-16-2013, 08:00 PM   #6
tinydb84
tinydb84's Avatar
Not to highjack too much but how thick are the bars and tabs? Are they ready to ship?
David
Instagram: myfabguy
Old 05-17-2013, 02:43 AM   #7
andrewmp6
The rear is easy to lay frame,But the front won't lay frame with out a zing or aftermarket front suspension like a dropmember or ifs from scotts.
Old 05-17-2013, 05:45 PM   #8
AVS_JASON
AIRBAGPARTS.COM
AVS_JASON's Avatar
1.5" on the tubing of the links and panhard bar. Tabs are all 1/4" thick. And I have tons of these in stock and ready to leave.
Old 05-17-2013, 06:45 PM   #9
tinydb84
tinydb84's Avatar
Looks like I will be going with that kit! (sadly not for a few months though)
David
Instagram: myfabguy
Old 05-19-2013, 09:12 PM   #10
83 Silverado
83 Silverado's Avatar
I've been looking at the 4 link kit, and like the know the length of the links and from the axle tube mount to frame mount. Thanks
83 Silverado is offline   Reply With Quote
Old 05-20-2013, 07:53 AM   #11
andrewmp6
Give Jason a call his number is in his sig.
