04-03-2017, 10:51 PM | #76 |
Re: La Crosse- 1960 GMC Custom
Next things will be bolting the carb on and figuring out the shift and kick down linkage. Then power steering parts and bolting the brake booster and master cylinder on. Radiator and distributor are supposed to be here Thursday.
Current projects: 1966 Chevy Custom PS PB A/C BBW 283 v8 3 speed OD 1966 GMC Long Step 1966 GMC 3/4 ton Custom PS PB Sport trim 351 v6 1966 GMC 3/4 ton 4x4 Custom PB 305 v6 np435 1960 GMC Custom 1968 GMC 3/4 ton 4x4 Short Bed 1962 K20 Tow truck 1961 GMC Extended Suburban Panel and a few more |
04-03-2017, 10:55 PM | #77 |
Just answered that question in my previous post.
04-03-2017, 11:06 PM | #78 |
One foot in front of the other
What carb?
04-03-2017, 11:15 PM | #79 |
New Holley 600. It is probably a little big for the motor but it is what I have right now.
04-04-2017, 10:57 AM | #80 |
Very nice!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
04-04-2017, 02:23 PM | #81 |
I used an aftermarket kickdown for my 283/350TH. Works great. Got it from Speedway maybe?
04-04-2017, 03:49 PM | #82 |
I might go that way if I can't get what I have to work.
04-05-2017, 10:01 PM | #83 |
In between the rain we have had the last couple days I was able to get the brake booster and master cylinder bolted on. Still need to work on the push rod.
Also bolted the Holley on. Had to use a 3/4" spacer because the linkage was hitting on the intake.
04-06-2017, 12:51 AM | #84 |
Looking good! I was born in overland Park as it turns out. But haven't been back there in over twenty years.
04-06-2017, 10:20 AM | #85 |
Thanks. Oh wow that is neat.
04-06-2017, 12:07 PM | #86 |
Making some good progress!
04-06-2017, 10:14 PM | #87 |
04-11-2017, 10:01 PM | #88 |
Bolted some more parts on and figured out the linkage.
04-11-2017, 10:03 PM | #89 |
Pics
04-11-2017, 10:05 PM | #90 |
Pics 2
04-16-2017, 10:51 PM | #91 |
Crossed a few more items off the list. Will be running soon.
Still need trans cooler lines, fuel line from tank to pump and some wiring.
04-16-2017, 11:02 PM | #92 |
Looks great.
Can you tell me which alt you are using and both the vbelt numbers? |
04-16-2017, 11:10 PM | #93 | |
For the alt we just ordered one for a 73 c10 so it would be internally regulated. I will get the belt numbers tomorrow.
04-17-2017, 12:26 AM | #94 |
Coming together nicely!
Nik...................____ 62 lwb c10 step-side 261 5 spd .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ my build thread. Sending unit solution |
04-17-2017, 10:54 AM | #95 |
04-17-2017, 11:26 AM | #96 |
Looking good!
04-17-2017, 11:36 AM | #97 |
04-17-2017, 10:29 PM | #98 |
The belts are 15555 and 15348
04-17-2017, 10:35 PM | #99 |
04-19-2017, 10:26 PM | #100 |
Today I removed the old choke and throttle cables and put the plug back in the hole.
While I was under the dash I saw a key hanging in the heater duct. I got them out and one is for the truck and the other was for the gas cap. They must have fallen down the defroster vent. And here are some pics with the gauges that we installed on the weekend. Not sure if I will keep the chrome bezels/face plates.
