Old 12-14-2018, 11:26 PM   #1
Thanos
Thanos's Avatar
Smile 72 GMC 8.1 coming along
Slowly...
hoods gone,went with a cowl and now I need new hinges.
8.1 installed today,new poly mounts,DD plates,Howell harness/cpu inc.
Led headlights and A LOT more.
Have to find a nv4500 cross-member and have dana 80 FF/4.10/LS to install, keeping it a duallie/dually getting rid of the dana 70 hd.
Feeling stoked after waiting a long time.
Thanos is offline   Reply With Quote
Old 12-14-2018, 11:47 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: 72 GMC 8.1 coming along
Originally Posted by Thanos View Post
Slowly...
Sounds good! What frame brackets did you use? I am planning about the same overall setup as you have but I may go ahead and use the Allison trans. Keep us posted on your progress.
LockDoc
Leon
Old 12-14-2018, 11:53 PM   #3
Thanos
Thanos's Avatar
Dirty dingo plates and the BB clam shells with some energy suspension inserts.Made the engine sit more forward and have plenty of room underneath. Was able to use my original 454 aftermarket headers also so that's a huge plus.
Old 12-15-2018, 12:02 AM   #4
LockDoc
LockDoc's Avatar
Thanks.
I have a pair of complete '72 mounts and a pair of '69 - '71 frame brackets and I wasn't sure which ones to use. I am going to use stock 454 cast iron exhaust manifolds.
LockDoc
Leon
Old 12-15-2018, 09:02 AM   #5
1972RedNeck
1972RedNeck's Avatar
Subscribed
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 12-22-2018, 11:18 PM   #6
Thanos
Thanos's Avatar
Originally Posted by LockDoc View Post
Thanks.
LockDoc
So far only issue was relocating 2 coil packs because of clearance issue however I am going to try and find a alternative to the brake booster or just fabricate something so not a big deal.
Between the Dana 80,nv4500 and the GV looks like I won't need a 2 part driveshaft anymore. Get some picks soon.
Old 12-23-2018, 12:43 AM   #7
LockDoc
LockDoc's Avatar
You might use a hydroboost setup for steering and brakes. Here is a thread on it. I am going to try and use the hydroboost out of the 8.1 donor truck on mine.
http://67-72chevytrucks.com/vboard/s...d.php?t=523502
What bell housing are you using for your NV4500 trans?
LockDoc
Leon
Old 12-24-2018, 01:54 AM   #8
Thanos
Thanos's Avatar
LockDoc
Yep a donor truck for hydroboost and need the drive by wire pedals.
Bell housing https://www.advanceadapters.com/prod...llhousing-kit/
Old 12-24-2018, 05:21 PM   #9
Benjamin
Benjamin's Avatar
Cool truck!
1972 K10, 350/SM465/NP205, 4 inch lift, 35x12.50s on 15x10 wheels
1976 K20 crew cab, 350/Ranger/SM465/NP205
Benjamin is offline   Reply With Quote
Old 12-24-2018, 10:23 PM   #10
Thanos
Thanos's Avatar
Originally Posted by Benjamin View Post
Cool truck!
Thanks! Just have a year or so ahead to complete it.
Old 12-25-2018, 12:38 AM   #11
57taskforce
All about them K’s
57taskforce's Avatar
I contemplated this swap for either my 57 or 72. I had a running driving 01 suburban 2500 to use as my play ground. The 72 ultimately went the way of the 6.0 and the 57 is still sitting. Alas my desire to go fast out weighed my ambition to do the 8.1 swap. The Suburban got sold and the Camaro got bought. After having two 8.1 trucks (other was an 05 3500 rclb) and the vortec 454 in my 98, the 8.1 is my favorite factory big block. Sooooo much torque. Cool swap I’m in to see this one!
Tyler
'72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879
‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206
'98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's
‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue
‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0
57taskforce is online now   Reply With Quote
Old 12-25-2018, 06:25 PM   #12
Thanos
Thanos's Avatar
Its pricey, yet so far its been pretty easy. I'm trying to find out if the TH400 cross member can be used with the NV4500 maybe with different mounts. I keep reading people have done this.
I'm jumping from one thing to another on this project and I have help doing it so its probably a year out since we are redoing the entire truck and not just the swap.
Going to try and post pics.
Old 12-25-2018, 08:11 PM   #13
Thanos
Thanos's Avatar
Home made fenders are not staying on heh, fabricating custom ones. Too many projects at once. Hardly any rust since its from Arizona
Old 12-30-2018, 01:18 AM   #14
Thanos
Thanos's Avatar
Anybody know if a TH400 cross member can be used with a NV4500? I'm finding mixed info all over the place.Maybe just a transmission mount change?
Old 12-30-2018, 09:43 PM   #15
LockDoc
LockDoc's Avatar
I can't help you there. The NV4500 that I put in my '72 Dually hangs out in mid air. I used the stock SM465 bell housing and clutch setup on it. If it warms up a little in the next couple of days I will go out and see if I can slip a TH350 or 400 cross member under mine.
LockDoc
Leon
Old 01-01-2019, 03:07 PM   #16
Thanos
Thanos's Avatar
LockDoc
Thanks, anybody else maybe know by chance?
Old 01-15-2019, 08:38 PM   #17
Thanos
Thanos's Avatar
Anybody swap in a Dana 80 in their 69-72? they have a pinion that's off center so trying to figure if I should leave it slightly off or center the pinion and let one side stick out a bit more...
Old 01-16-2019, 09:48 AM   #18
68Gold/white
Leave it as is. Ford 9" rears are made same. If tire/wheels are centered per chassis, you're done!!!
I wonder if you could run manual brakes on your setup, not using a booster, like many stock pickups were built back then...afterI get my 67 and 68 C-10's converted to 5 lug and disc, I plan to go manual disc on both...not sure if I will like it though...
68Gold/white is offline   Reply With Quote
Old 01-16-2019, 11:11 PM   #19
Thanos
Thanos's Avatar
Yea I figured it wouldn't hurt anything having a slight angle on the driveshaft so I'm just going to mount the diff squared off. I'm going to go with a hydro booster or something equal in size,I need the stopping power.
