Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 02-14-2017, 12:21 AM   #1
Revorollerr
Manual FR/RR Disc MC
Anyone running front and rear disc brakes with a manual MC (master cylinder)? If so, what MC are you using? Is there any "budget" options?
Revorollerr is offline   Reply With Quote
Old 02-14-2017, 09:22 AM   #2
vin63
It's Better With Nitro
vin63's Avatar
Re: Manual FR/RR Disc MC
I've used a '62-'74 Mopar-type aluminum master cylinder on several of my drag cars with disc brakes all around. They can be had for around $70 to $90 at your usual drag racing or regular parts suppliers.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 02-14-2017, 03:31 PM   #3
hotrod 80
mini truck racer
hotrod 80's Avatar
I have Aerospace 4 piston disc brakes in all 4 corners and I also used the Mopar master . Pay attention to your rod position and pedal ratio . I thought mine was from a mini van . Also pay attention to piston size in the master.
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 02-15-2017, 12:03 AM   #4
Captainfab
60-66 Nut
1967-74 Corvette master cylinder found at your local auto parts store.
