Old 01-30-2015, 10:10 PM   #1
Back row pupil
1/2 ton to 3/4 ton running gear
I need advice on choosing the right year of 3 / 4 ton running gear, to put under my '72 short box. I want a relatively easy transition. Plus I am looking to disc brake the rear! Looking to run the new 37's or old school 38's. Budget is not Substantial!
Back row pupil is offline   Reply With Quote
Old 01-30-2015, 10:46 PM   #2
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: 1/2 ton to 3/4 ton running gear
Lol...
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 01-30-2015, 11:56 PM   #3
Either bolt-in a 67-72 HO52 or Dana60, or a 14-bolt just needs reconfigured mounts
Old 01-31-2015, 12:30 AM   #4
argonaut
argonaut's Avatar
Find a 73 to 87 3/4 ton truck and pull the axles. The front will bolt right in. Reposition the rear axle spring perches and it will bolt in. You'll have to upgrade the rear axle to run larger ujoints or they also make a conversion ujoint but it won't be as strong. You'll have to adjust the shock mounts too.
but the axles should be cheap. I wouldn't pay more than 500 for a set in good condition.
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
Old 01-31-2015, 03:46 AM   #5
andrewmp6
With 38s you want 1 ton axles,The 3/4 ton will break over time if you push it hard enough.
