Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 05-05-2015, 11:46 AM   #1
chase@ridetech
chase@ridetech's Avatar
Anyone use 3m tape for trim instead of clips on a square fender c-10
I run a small paint and restoration shop on the side and I am putting together a 73 C-10. This truck didn't come with a trim package but now my customer wants to add the side trim. I really don't want to drill the holes for the trim clips because I have most of the parts painted already and I fear that he may change his mind again after its installed. has anyone used a double-sided tape on the aluminum trim? Will it hold?
chase@ridetech is offline   Reply With Quote
Old 05-05-2015, 12:25 PM   #2
hugger6933
Re: Anyone use 3m tape for trim instead of clips on a square fender c-10
It ought to be fine. Most of the trim on the later trucks was held on by the double faced tape. So I wouldn't have a problem with it. Jim
hugger6933 is offline   Reply With Quote
Old 05-05-2015, 12:54 PM   #3
Smoothride
I installed my lower moldings with 3m tape and it has held up for a year with no problems
Smoothride is offline   Reply With Quote
Old 05-05-2015, 03:30 PM   #4
chase@ridetech
Thanks for the replies, I may give it a shot and see how it holds up.
Old 05-05-2015, 09:13 PM   #5
hugger6933
The only one that bolts on that I remember is the back corner pieces, and they are made of a different material. Jim
Old 05-06-2015, 11:28 AM   #6
MARTINSR
MARTINSR's Avatar
One thing you want to do is make sure the mouldings are clean and use an adhesion promoter like this http://www.amazon.com/s/?ie=UTF8&key...l_11r90huyfr_b
If the paint is near fresh, don't use it on that as it will "bite" into it pretty good. Which is fine if it's ONLY where the moulding will be installed but if you drip some on the paint it will mark it.
But use a quality tape, there are different colors and qualities get a pro-grade one like this http://www.tcpglobal.com/MMM-6386.ht...A#.VUoxK_lViko
And also, a dab of window urethane at the ends is a good idea too depending on how big the moulding is. But a tiny dab of urethane will be added insurance.
Brian
1948 Chevy pickup
Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats!
Bought with paper route money in 1973 when I was 15.
"Fan of most anything that moves human beings"
MARTINSR is offline   Reply With Quote
Old 05-06-2015, 05:54 PM   #7
chase@ridetech
Brian
I appreciate the links and the input. It is all fairly fresh paint and the trim is new as well.
Thanks again!
Old 05-07-2015, 12:42 AM   #8
UKNOWME
UKNOWME's Avatar
I'd like to know how well this works. We are about to install a complete molding kit on mine and I've wondered the exact same thing. When are you planning to try this?
2018 Audi S5- wife's ride
1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511
1981 Chevy Silverado- in pieces
1964 Chevy c10
2017 Jeep Wrangler JKU
UKNOWME is offline   Reply With Quote
Old 05-07-2015, 01:04 AM   #9
MARTINSR
MARTINSR's Avatar
The hard part is if there is enough surface area on the moulding to put he tape. If it's a metal moulding with the slot for the "T" moulding clips to slide into, that leaves just the little strip of metal along the edge for the tape, that may not be enough.
Then the other issue, this is a biggie, the moulding has to perfectly fit against the body in it's entirety. And that's not easy with a metal (aluminum, stainless, what ever) because the studs or clips are what pulls it into place, twisting it, flexing it to fit.
If it doesn't fit perfectly you may be able to push it into place but it will be fighting to pull off every second of it's life after it's installed. It can very easily pull up away from the panel be damned how good it's taped on. The tape is foam, and it can pull apart with the moulding pulling away from the body.
So the fit of the moulding would be of upmost importance.
Brian
1948 Chevy pickup
Old 05-07-2015, 02:53 PM   #10
chase@ridetech
I think i am going to cut some aluminum to fit in the groove on the back of the trim so i can run tape the entire length. I am going to try to do a test run on a piece this weekend before i do the whole truck.
Old 05-07-2015, 03:06 PM   #11
Advanced Design
Advanced Design's Avatar
That will be an interesting test Chase. If you can, please take pic's and let us know how it goes.
Advanced Design is offline   Reply With Quote
Old 05-07-2015, 04:04 PM   #12
UKNOWME
UKNOWME's Avatar
Yes, please do!
1964 Chevy c10
Old 05-07-2015, 04:06 PM   #13
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
i'm interested to see your outcome as I had the same idea to put trim on my 76. I don't want to drill holes in the new sheet metal if I don't have to.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 05-11-2015, 11:35 PM   #14
UKNOWME
UKNOWME's Avatar
How did it work?
1964 Chevy c10
Old 05-12-2015, 10:31 AM   #15
chase@ridetech
Didn't make it to my shop this weekend... Luckily I remembered in time that it was mothers day I have a wedding out of town this coming weekend but hopefully I can come up with some time during the week.
I will post results hopefully sooner than later
Old 05-24-2015, 09:27 AM   #16
UKNOWME
UKNOWME's Avatar
Any luck?
1964 Chevy c10
Old 06-13-2015, 05:00 PM   #17
UKNOWME
UKNOWME's Avatar
We are using only double sided tape and a few extra screws like what came with the kit. Seems to be working great and looks just as good without all the headache.
1964 Chevy c10
Old 07-02-2015, 01:17 AM   #18
UKNOWME
UKNOWME's Avatar
Finished product
1964 Chevy c10
Old 07-02-2015, 11:50 AM   #19
chase@ridetech
Looks Great! I haven't been able to get back on my project, but I think I am going to do it the same way.
Old 07-02-2015, 12:04 PM   #20
UKNOWME
UKNOWME's Avatar
1964 Chevy c10
Old 07-05-2015, 07:34 PM   #21
_Ogre
_Ogre's Avatar
if you use double side tape for anything use the primer/adhesion promoter on all your surfaces
it really improves the grip and life span on the tape
most any body kit is held on with 3m grey double sided tape, they all come with adhesion promoter
we ship the packets with any tape on product
shop air compressor timer
Old 07-06-2015, 08:26 PM   #22
FlameOut
I bought a complete side moulding kit for my 72 and was surprised to see that it came with double sided tape. I wish I had opened the box before drilling my doors. I haven't installed itthough, so I hope the tape holds up
2004 Chevy Silverado Z71 Ext Cab 1500
1972 Chevy K-10 SOLD
1967 Chevelle SS
FlameOut is offline   Reply With Quote
Old 12-04-2018, 12:00 AM   #23
buspilot23
buspilot23's Avatar
Originally Posted by UKNOWME View Post
Finished product
Getting ready to do moldings on my '70 SWB. This thread is now over three years old. . . how are your moldings holding up/on to your metal UKNOWME? Still holding good? Thanks in advance!
buspilot23 is offline   Reply With Quote
Old 12-04-2018, 12:23 AM   #24
UKNOWME
UKNOWME's Avatar
Yes still holding good.
1964 Chevy c10
Old 12-04-2018, 10:18 AM   #25
buspilot23
buspilot23's Avatar
Thanks for the reply. I'll tape mine with confidence!
