Old 02-12-2017, 12:55 AM   #1
Cjcolbyjack
85 crewcab on a denali sub chassis
i have a 85 crew cab long bed Dooley i would like to cut the bed to fit a denali suburban chassis and make it single rwd. does anyone know where i could find info about this? thanks!
51 motor buildhttp://67-72chevytrucks.com/vboard/s...d.php?t=718113.
54 3600 Lincoln aviator chassis swap
http://67-72chevytrucks.com/vboard/s...d.php?t=717927
Cjcolbyjack is offline   Reply With Quote
Old 02-23-2017, 12:25 AM   #2
13jraven
13jraven's Avatar
Re: 85 crewcab on a denali sub chassis
Got to start with wheel base and overall length.
Denali Suburban vs Crew Cab Dooley
Wheelbase - 116" vs 164.5"
Overall length - 203.9" vs 211.8"
Then see how you are going to put a body that requires a 164.5 wheel base on a chassis with a 116" wheel base.
Are you planning on making the crew cab a short bed dooley?
Lot easier to section a frame then to add frame rail.
And can you make body mounts? The suburban frame is dramatically wider than 80s frames.
Give the google a shot or ask the guys at Pirate4x4.com - they are very accommodating.
13jraven is offline   Reply With Quote
Old 03-03-2017, 06:46 PM   #3
Cjcolbyjack
thank you so much!
