02-10-2013, 10:16 PM | #1 |
wilwood master cylinder install pics?
Anyone got photos of an install on a 67-72 cab? How it bolts to the firewall and which mounting holes are used.
02-10-2013, 10:20 PM | #2 |
67-72 parts collector,…
Re: wilwood master cylinder install pics?
Here you go,...
02-10-2013, 10:24 PM | #3 |
Nice, does it cover the entire hole in the fire wall since you only use the bottom holes? Did it come with the adapters you have in the picture on the brake line fittings?
02-10-2013, 10:26 PM | #4 |
Yes and yes.
02-10-2013, 10:28 PM | #5 |
One more question, is it pretty much a bolt in with the brake rod and pedal?
My truck had a power brake setup from the factory. |
02-10-2013, 10:31 PM | #6 |
Mine had manual brakes,... and it was a direct bolt on.
02-10-2013, 10:38 PM | #7 |
No problem finding a manual setup, just glad it is a bolt up unit. Thanks for all the fast responses. Going to give Scotts Hotrod a call in the morning and get the order in.
02-10-2013, 10:45 PM | #8 |
I ordered mine from Jegs.
02-10-2013, 10:50 PM | #9 |
02-10-2013, 11:43 PM | #10 | |
Man of Mini-Talents
Justin's a great guy to do business with.
Steve Project - Ruth 66 Skylark Project - Lola 60 Biscayne Project - Iron Ox 54 GMC 100 Project - Darth 69 Camaro |
02-11-2013, 03:19 PM | #11 |
Yeah baby!
lolife, which bore size did you use?
11.37 @116 |
02-11-2013, 04:07 PM | #12 |
02-11-2013, 06:49 PM | #13 |
02-11-2013, 06:49 PM | #14 |
Nope.
02-11-2013, 07:51 PM | #15 |
02-11-2013, 08:07 PM | #16 |
This truck is not on the road yet.
My '69 also has a 1" bore M/C with no booster. It is a disc/drum set up. Pedal effort is a little more than a truck with a booster,... but I think it's worth it to clean up the firewall. I'm using Wilwood D52 calipers.
02-11-2013, 08:44 PM | #17 |
Yeah baby!
Thanks.
11.37 @116 |
02-11-2013, 09:52 PM | #18 |
Just got off the phone with Justin at Scotts, got a killer price and service. Thanks again board vendors. Its on the way boys and girls.
02-11-2013, 10:05 PM | #19 |
Man of Mini-Talents
Very nice. Be sure to let us know when you get it.
02-11-2013, 10:28 PM | #20 |
One more question Keith if you don't mind ( and if it's ok with the OP I don't mean to threadjack) are you using an OE (or OE type) combination valve on either truck and if so are you also using an aftermarket adjustable prop valve in addition to the OE valve.
2 questions, sorry. Thanks Posted via Mobile Device |
02-11-2013, 10:45 PM | #21 |
My stepside has a SSBC prop valve mounted on the frame.
My '69 has a standard disc/drum prop valve that hangs below the M/C.
02-11-2013, 11:12 PM | #22 |
Man of Mini-Talents
Nice workmanship on the line bending Keith!
02-12-2013, 12:43 AM | #23 |
Never seen that SSB valve before, nice piece but dude, that is the cleanest work on the lnstall/tube bending I have ever seen. Period. Anywhere. 180 into a 90 that close to a fitting? I would not believe that was even possible. I am seriously impressed.
BTW, thanks for the info.... |
02-12-2013, 07:46 AM | #24 |
http://ssbrakes.com/c-407225-shop-by...ortioning.html
Wilwood also makes a cool "distribution system" that is also adjustable. But I already had the SSBC unit. http://www.wilwood.com/MasterCylinde...derValves.aspx
