Old 11-16-2017, 11:23 AM   #1
T and S
T and S's Avatar
Need brake info .......
I am installing a offenhauser intake with a 390cfm Holley on a 250 straight six. Currently I am running drum brakes all around, but am thinking of doing the disc conversion. I am concerned about the Holley interfering with the brake master / booster assembly. Does anybody have pics of this set-up they could share for reference ?? Thanks in advance !!
If you don't like this pound sand .....
T and S is offline   Reply With Quote
Old 11-16-2017, 11:40 AM   #2
T and S
T and S's Avatar
Re: Need brake info .......
Oh - forgot to mention. The 390 will be mounted 90 deg. to the motor (linkage to front of motor ).
Old 11-16-2017, 12:47 PM   #3
slepysal
slepysal's Avatar
Here is what I did booster pic is on post #8
I have had zero issues with this set up .
http://67-72chevytrucks.com/vboard/s...highlight=disc
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 11-16-2017, 01:49 PM   #4
The Rocknrod
Moderator
The Rocknrod's Avatar
Here is a link on that:
http://67-72chevytrucks.com/vboard/s...5&postcount=94
Old 11-16-2017, 11:17 PM   #5
T and S
T and S's Avatar
Thanks for the replys. But my Holley will be 90 deg. to the motor. (Primaries toward valve cover). What I am concerned about is the float bowl interfering with the master / booster. In your posts your carb. is perpendicular to the engine .......
