01-21-2018, 11:32 PM | #1 |
Before and After
Installing components in a naked cab.
It has been a while since I removed everything from my cab before repairing the rust. Months and months later, I am ready to put it all back in.
I have everything bagged and labeled, so this shouldn’t be a problem, but is there a smart order to install them back in? I don’t want to fight with other components during the rebuild. This is not an A/C cab. 3ott. Any tips will be appreciated.
Not Grandpa's C-20 anymore... 383 Stroker 425HP, 485Ft/Lbs Lowered 3.5" Front / 5" Rear 66,000 miles. Alberta, CANADA |
01-21-2018, 11:53 PM | #2 |
Re: Installing components in a naked cab.
Good question...
1. Firewall insulation 2. Kick panel vents 3. Emergency brake unless it’s under the column like a 67-8 4. Brake pedal assembly 5. Brake booster or master cylinder rod. 6. Wiper motor 7. Wiring harness with all dash switches 8. Gas pedal, Oil line and th400 wiring if required 9.dash pad 10. Radio 11. Heater sssembly, pre assembled with controls and cables. 12. Rear window 13. Carpet seat belts and seat Any order on the remainder but glove box and liner last after heater is tested. |
01-22-2018, 01:06 AM | #3 |
The Older Generation
Install the gauge cluster before you install the column, or at least before you tighten the column up. LockDoc
01-22-2018, 05:19 AM | #4 |
Six in a row makes it go...
Great timing. This exact question has been rolling around in my head this weekend.
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086 66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790 CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224 “The height of sophistication is simplicity." - Clare Boothe Luce |
01-22-2018, 09:14 PM | #5 | |
Before and After
Exactly what i was looking for, thanks Randy.
01-22-2018, 10:49 PM | #6 |
01-22-2018, 11:31 PM | #7 |
#1. Dash pad.
other Larry Build thread, Arkansas K10 https://67-72chevytrucks.com/vboard/...=755797&page=5 The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless. |
