Old 10-04-2012, 12:01 AM   #101
JRANGER
JRANGER's Avatar
Re: 1978 big ten build
not perfect but should give u a general idea
JRANGER is offline   Reply With Quote
Old 10-04-2012, 12:05 AM   #102
mud.man.rj
mud.man.rj's Avatar
What inch rim width are you going to use just wondering.
mud.man.rj is offline   Reply With Quote
Old 10-04-2012, 12:34 AM   #103
1978chevybigten
1978chevybigten's Avatar
Thanks man for the mockup. Looks good!
1978 big ten 350/350:chevy
1978chevybigten is offline   Reply With Quote
Old 10-04-2012, 12:36 AM   #104
1978chevybigten
Probly 15-16 nothing to crazy. Shes got 16's on right now.
Old 10-04-2012, 12:51 AM   #105
mud.man.rj
mud.man.rj's Avatar
Not rim heigth but width, how wide of a rim, most stock are a 7" a lot of guy's run a 8" or wider 10". My 4x4 has a wider 12" rim for the really wide tire, just thinking your prob a 8" on a 2wd.
Old 10-04-2012, 10:14 AM   #106
1978chevybigten
Probably going with 8-10 I like the wide tires gives it a mean stance.
Old 10-05-2012, 09:17 PM   #107
mud.man.rj
mud.man.rj's Avatar
8 front and 10 back is a real good choice, think it will work out well.
Old 10-05-2012, 11:22 PM   #108
1978chevybigten
Found a good deal today on craiglist, a gauge cluster with all gauges all working and a fan shroud for 20 bucks.
Old 10-07-2012, 12:06 AM   #109
1978chevybigten
Got the windshield replaced by safelite, they did an outstanding job. Also got the rest of the interior put together excluding the carpet.
Old 10-07-2012, 11:05 AM   #110
JRANGER
JRANGER's Avatar
what no pics? and if u need any cluster parts let me know...i got some i can give ya
Old 10-07-2012, 12:12 PM   #111
1978chevybigten
here are some pics
Old 10-07-2012, 12:13 PM   #112
1978chevybigten
thanks man!!! ill let you know if i need anything im picking up the new gauge cluster monday or tuesday so ill let you know if i need anything.
Old 10-07-2012, 07:06 PM   #113
1978chevybigten
Got the truck inspected today. and when i got my change. there was a lucky quarter!
Old 10-08-2012, 12:30 AM   #114
mud.man.rj
mud.man.rj's Avatar
Why is the quarter a lucky one?
Old 10-08-2012, 12:31 AM   #115
1978chevybigten
My trucks a 1978 the quarters a 1978.
Old 10-08-2012, 12:56 AM   #116
mud.man.rj
mud.man.rj's Avatar
Ohh I get it, cool maybe I should look for a 71, ahh I have enough luck already.
Old 10-09-2012, 11:25 PM   #117
1978chevybigten
Got the truck registered today, and drove her for the first time in a few months. she drove good. but had one hitch, the transmission dipstick filler tube boot broke off when i checked the fluids, and i was headed down the road and the engine started smoking like crazy. somehow tranny fluid came out of the filler tube and hit the headers... has this ever happened to anyone? the dipstick said i was right on not to full not to low.... also i need to replace the transmission gasket. whats the best way to take off the transmission crossmember??
Old 10-10-2012, 08:49 PM   #118
1978chevybigten
took some pictures today.
Old 10-10-2012, 10:09 PM   #119
THE "10" SILVERADO
THE "10" SILVERADO's Avatar
Need to get the tranny out to get the crossmember. Other than that pretty simple. "supposed" to be on with 9/16 bots. Mine had an assortment. Once the bolts are out just slide it out; you might have to hammer it out. If your truck cab mounts are not on a crossmember (like mine where) and are on the mounts that are rivited to the frame, you might have a problem with the frame bending and then you will have trouble getting the crossmember back in. Good luck.
Michael
Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9
THE "10" SILVERADO is offline   Reply With Quote
Old 10-10-2012, 10:51 PM   #120
JRANGER
JRANGER's Avatar
looking great..Hopeyou can resolve the issues your having
Old 10-13-2012, 10:49 PM   #121
1978chevybigten
Today was a good day!!! I got a fan shroud, kick panel, 2 gauges clusters and an edlebrock 600 cfm carb today for 50 bucks!
Old 10-14-2012, 02:54 AM   #122
Pop's C-10
Pop's C-10's Avatar
I'm loving tha black more and more..
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 10-14-2012, 01:12 PM   #123
1978chevybigten
heres the new gauges i got.
Old 10-14-2012, 03:21 PM   #124
1978chevybigten
Hey guys I need help identifying a "posi" the id # are US 4612825 CANADA 1987 and to the right of those # there is 20G4. Is it an auburn? It has 5 springs
Old 10-14-2012, 09:11 PM   #125
mud.man.rj
mud.man.rj's Avatar
Comes up as a 26 spline Auburn posi unit.
