Old 01-21-2019, 02:47 PM   #1
1998c1500
1998c1500's Avatar
Aftermarket Steering column
Has anyone used this one from Jeg's?
Is there anything that would prevent this from being a bolt-in installation in a 65? I realize I would need linkage. 350/700r4 combo.
https://www.jegs.com/i/JEGS/555/7047...EaAl-PEALw_wcB
1965 C10
1967 Camaro
1998 C1500
2011 Colorado W/T
1998c1500 is offline   Reply With Quote
Old 01-21-2019, 04:28 PM   #2
65c10restomod
Re: Aftermarket Steering column
this column has no mounting holes and is only 30" long and connects with Double D
65c10restomod is offline   Reply With Quote
Old 01-21-2019, 04:57 PM   #3
66_C20
It looks identical to the one I got from a different vendor and installed in my ‘66. It was pretty straightforward to install using the factory brackets and hardware but as already stated, there are no mounting holes which I wasn’t aware of when I bought it. It worked out just fine tho as it allowed me to position the column where I wanted it, and then just marked, drilled, and tapped the holes. My combo is a 1966 C20 with a 454 and a TH400.
66_C20 is offline   Reply With Quote
Old 01-22-2019, 01:26 AM   #4
Mack B
Mack B's Avatar
Where you able to adapt a stock wheel to the tilt column or did you go a different direction?
Mack B is offline   Reply With Quote
Old 01-22-2019, 09:14 AM   #5
66_C20
Yeah the column comes with a coupler attached to it for an aftermarket wheel but removing the center nut allows you to remove that coupler and then you can use the stock steering wheel with that same center nut. Which is the exact route I took. The splines line up with no issue.
Side note: what part of lower Alabama are you in?
Old 01-24-2019, 01:04 AM   #6
Mack B
Mack B's Avatar
Thanks for the information! My wheel is dang near on my legs, I would love to upgrade to tilt.
I'm just north of Mobile, Al.
Old 01-24-2019, 09:21 AM   #7
kens65fb
What do you mean by " mounting holes "
kens65fb is offline   Reply With Quote
Old 01-24-2019, 10:24 AM   #8
whitedog76
How is the quality on these columns? I’ve read some poor reviews on overseas columns. I would like to think Jegs has a little higher standards.
whitedog76 is offline   Reply With Quote
Old 01-24-2019, 11:09 AM   #9
1998c1500
1998c1500's Avatar
This is why I asked.
Does anyone know the length needed? I feel I read it somewhere, but can't find the post.
I also should have mentioned that my truck was converted to power steering with an 80"s gear and pump and has the DD shaft.
Thanks for the replies.
1965 C10
1967 Camaro
1998 C1500
2011 Colorado W/T
Old 01-24-2019, 11:19 AM   #10
The Rocknrod
Moderator
The Rocknrod's Avatar
Measuring a steering column doesn't seem to be done the same way by everyone. You could find a couple inches difference depending on who measures it. So here are three places that show how to measure a steering column, all three are the same:
https://www.ididitinc.com/files/pdf/...ringcolumn.pdf
https://www.youtube.com/watch?v=Ufl6IP90alY
https://www.performanceonline.com/bl...eering-column/
Old 01-24-2019, 11:20 AM   #11
DaHos
DaHos's Avatar
Installing one similar as we speak.........Lets just say the labor to modify this column offsets the additional cost of buying the Ididit Retrofit column !!!! NO NSS or Rev light provisions, no mounting provisions and the 1" Female DD output is a joke !!!!!
1967 C10 SWB
Owner - Rustbelt Restorations
DaHos is offline   Reply With Quote
Old 01-24-2019, 11:28 AM   #12
The Rocknrod
Moderator
My only issue with the aftermarket columns are the horn contacts are so long, made for using the 9 bolt billet steering wheel adapter. I want to use a 57 type wheel and I only found Ididit makes that possible out of the box. Now if I 'knew' the correct part that would swap that out I'd save a bunch.
Old 01-24-2019, 08:18 PM   #13
65c10restomod
no bolts .Needs to be clamped
32"
Old 01-24-2019, 09:02 PM   #14
Pinball Chris
Read this before buying an aftermarket column.
https://lvvta.org.nz/documents/infos...ng_Columns.pdf
Pinball Chris is offline   Reply With Quote
Old 01-24-2019, 09:28 PM   #15
kens65fb
That article is over 5 years old, the defects have been corrected
Old 02-06-2019, 10:26 PM   #16
Pontitruck
Pontitruck's Avatar
32"
Interesting, when I look them up for my 65 they come up 33", anyone else have some input and pics of course.
Pontitruck is offline   Reply With Quote
Old 02-07-2019, 12:43 AM   #17
The Rocknrod
Moderator
People 'sometimes' measure differently. Here is an example of standard steering colum measuring total length from end of the shaft (box end) to wheel mount, not to include the steering wheel mounting spline shaft:
