12-21-2020, 01:32 PM | #1 |
Trailing arm option
I am wondering those that have replaced the factory trailing arms did you use a newer style with johnny joint ends and what are your opinions on using them?
12-21-2020, 01:43 PM | #2 |
67-72 parts collector,…
Re: Trailing arm option
I highly recommend these from Tinworks Fabrication.
Excellent Quality and customer service. https://tinworksfabrication.com/prod...y-truck/63-72/
12-21-2020, 03:54 PM | #3 | |
12-21-2020, 04:40 PM | #4 |
12-21-2020, 04:42 PM | #5 |
12-21-2020, 10:35 PM | #6 | |
The I-beam design of the stock trailing arm allowed it to twist. When you build a solid trailing arm (round or square tube) it has to have a flexible joint at the front.
12-22-2020, 10:16 AM | #7 |
12-22-2020, 10:17 AM | #8 |
12-23-2020, 11:10 AM | #9 | |
I think of it as going from Radials to Bias-Ply tires (backwards in functionality). The combo of the original I-beam construction, length, orientation, & the front rubber bushings made them compliant enough to survive. Start changing some of those dynamics & it will possibly impact the effectiveness on the others. If you're choosing aftermarket tubular constructed Truck-Arms, they need to have a spherical joint to work better than what came form GM.
12-23-2020, 05:47 PM | #10 | |
