08-13-2016, 08:50 AM | #1 |
Converting to a 292
Looking to convert the 250 in my 69 SB to a 292. I understand that 1963 was the first year for this engine, did they change much over the years? Have access to a 1963 model and am a little Leary being the first year. What did I need to switch from the 250 to the 292? Do I need to change both frame brackets or just the right one? My truck has the 3 speed automatic, all of that should bolt to the 292, correct? I have a fan shroud on my 250, does the 292 sit at the same level so that I can still use that? I also would like to run a set of headers with duals, any problems there? Is there anything else I should know before I get started? Any information is greatly appreciated.
08-13-2016, 02:42 PM | #2 |
You'll need the Right side engine mount they are hard to find (I have an extra) , if your wanting to use headers that's just reconnecting the exhaust , fuel line , not sure on fan shroud most didn't have one ,Trans should bolt up ,not really too much to change .
08-13-2016, 07:18 PM | #3 | |
Re: Converting to a 292
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
08-14-2016, 07:42 AM | #4 |
I have not bought an engine as of yet, the 63-292 was taken from a 2-ton truck, rebuilt and put into a combine which has since been scraped, but he saved the 292. Therefore I doubt if he has any of the mounts. Are the intake and exhaust manifolds along with the carb the same on the 292 as the 250's? If so I could run the original exhaust for a while. Also the PS from my 250 should also bolt up to the 292 with no problem right? I just bought this truck out of California and it has a 3 core radiator along with the fan shroud, so I'm thinking that should handle the 292 also. What color were the 292's painted from the factory?
08-14-2016, 10:21 AM | #5 | |
08-15-2016, 08:04 AM | #6 |
Were all of the 292's painted green? If ordered in 69/70 in a pickup they would also be green? I take it that if the intake on the 292 is larger than the one on the 250, that the Carb should also be larger, would that be correct? I have been looking through the pictures of the 66 your building. Looks great, love the 4 barrel carb with the headers. Thanks for the information.
08-15-2016, 10:51 AM | #7 | |
08-15-2016, 08:46 AM | #8 |
67-72 parts collector,…
I'm pretty sure the 292 use a different set of P/S mounts.
I never found a set for my '69 with a 292. I bought a set off the board that were "suppose" to be 292 P/S brackets. They ended up being from a 250. My 292 had a fan shroud,...
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 08-15-2016 at 08:51 AM. |
08-15-2016, 02:03 PM | #9 |
Six in a row makes it go...
292s changed the flywheel bolt size in the late sixties if I remember correctly. Good to remember if you go looking for spare parts.
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086 66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790 CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224 “The height of sophistication is simplicity." - Clare Boothe Luce |
08-16-2016, 09:07 AM | #10 |
Now that brings up a good question. Is the crank the same in the 250 & 292? We are sure the transmission will fit, but how about the harmonic balancer, flywheel, and etc. Just trying not to have to many surprises when I get into this project, Gm did some funny things.
08-16-2016, 10:57 AM | #11 | |
08-16-2016, 03:21 PM | #12 | |
The 194, 215 Pontiac, 230, and 250 are very similar except bore and stroke. The 292 shares some common parts and architecture, but is quite a bit different too.
08-17-2016, 08:18 AM | #13 | |
08-17-2016, 10:57 AM | #14 |
The one from the 250 may work, you could always bolt it on to see. I will ask my fellow inliner's and see what they think.
08-19-2016, 08:03 PM | #15 | |
The passengers' side motor mount is different on the C10 -20 -30. On the K/10-20 -30, you need a special diagonal crossmember. [Very rare]. I believe the 292's Flexplate and/or Flywheel is the same as the SBCs. The '63 Model Year L6 292 has a 6-lobed counterweight crank made of forged steel. The ['63-'66] Crank Drive End has 6 holes bored 7/16''-20 and one dowel pin, like the 230/250s. '67 and later 292 cranks have six 1/2''-20 bolts and 3 dowel pins. '67 and later cranks have 12 counterweight lobes and are considered better balanced. If you have a gifted, performance-oriented machinist, the Six lobe crank can be 'feathered' or shaved to minimize resistance and improve balance. But that's a racers' trick, probably not much help on the street. Also some of the early 292s had an oil pan sump that's not as far back as the later 292s. Some 292s from C/40 and bigger trucks had a wider inside diameter exhaust manifold. It has 3 studs unlike the 250/292 C/10 exhaust manifolds with 2 studs. On the showroom floor, the new-for-'63 292s had Alpine Green paint. While 230/250s were Blue Flame Six blue. In 1967 all Chevy engines got the [formerly SBC] Chevy Engine Orange. A period correct '69 truck would have an orange engine. A period correct '63 engine would be Alpine Green. Your choice. All 292s take a bigger, 3-groove Harmonic Balancer: GM p/n 10141202. The 230/250 HB is not recommended on the bigger L6. If you don't have a copy yet, I recommend the "Chevy InLine Six-Cylinder Power Manual" by Leo Santucci. Good Luck.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 08-20-2016 at 01:07 AM. |
08-19-2016, 08:43 PM | #16 | |
08-19-2016, 09:17 PM | #17 | |
08-20-2016, 12:15 AM | #18 |
Take a look at aussiespeed. Neat stuff.
Don't know much about these L6's yet but I think a 250 can be made to scream. My Cherokee 6 has taken serious abuse beatings which is why I'm starting to like the 6 more. Evidently ford 300 s and jaguars can be made to kill small locks too. Either way Leo santucci did some cool stuff. Have fun whatever you do. Posted via Mobile Device
'69 K20 350/4 speed/Rockwell/D44/HO52. "orange rhymes with door hinge" |
08-20-2016, 12:42 AM | #19 | |
https://www.summitracing.com/parts/r...make/chevrolet And here is the behemoth. Never have seen these in 1/2 to 1 ton rigs. Maybe they were a special order? https://www.summitracing.com/parts/p...make/chevrolet
08-20-2016, 06:40 AM | #20 |
I currently have the behemoth on my 292. My original balancer spun the outer ring and that was all my local parts store could conjure up. Seems to work fine. Might be carrying a little extra rotating weight that I don't need.
08-20-2016, 08:25 AM | #21 | ||
Thanks again guys, appreciate all the help. onn |
08-20-2016, 12:00 AM | #22 |
*** That's interesting ***
The 292 definitely has a different flexplate than all other L6s and SBC. As mentioned, it needs 3 dowels and larger bolts.
The good news is, depending on what trans you have, you should be able to get a parts-store replacement flexplate. Companies like Pioneer and ATP still make them. Just search for a flexplate for any 70s era truck with the 292. Then again, what trans do you have? They were mostly mated up to a TH400, and are usually drilled for a 6-bolt converter. Will also work with a 3-bolt converter. But might need a custom drill for something else.
Tom Chevy by day... 1969 Chevy C30 Rollback Tow Truck -- 383 stroker, 4L80E 2011 Chevy Caprice PPV 9C3 6.0L 1995 Chevy Caprice 9C1 1994 Chevy Caprice 9C1 #3 1995 Chevy Caprice Wagon #2 1995 Chevy Impala SS Mopar by night... 1969 Dodge Charger 1972 Chrysler Newport 2dr Hardtop (27K miles) Plus others... |
08-20-2016, 06:42 AM | #23 |
If the bolts were enlarged in '66 and more dowel pins added, wouldn't the '70s flex plate have a problem bolting up to his '63 292?
08-20-2016, 08:36 AM | #24 |
I think my '67 C20 came from the factory with a fan shroud. At least it looks stock to me. Here's a pic of the engine compartment. The shroud is out now and I can take pictures of it if you need 'em.
Buying a rebuilt engine is a dicey proposition. Who knows what was really done to it and what parts were used? Unless it's someone I know well, I'd rather get a tired engine and have it rebuilt myself. That may cost more than $1500.00 though.
08-20-2016, 10:42 AM | #25 |
To rebuild a 292 stock is pretty cheap. You can still get crate 292's as well. I think they are under 2K. I've seen 292 rebuild kits for under $500. Cool thing is Summit Racing has everything you need to rebuild a 292.
