Old 12-06-2010, 06:06 AM   #1
TheApocalyptican
TheApocalyptican's Avatar
Core support swap
Searched and didn't find this question based on the years that I am interested in. Does anyone know how much difference there is between an 89-91 dual headlight core support, and either an 81-82 dual or an 83-88 dual headlight core support?
I would like to be able to just swap the cores and the lights, and not have to do the entire front clip. As of right now my current grille and headlight surrounds are trash, and I figure now would be the time to look into switching the core over the the stacked headlight(which I myself like better)instead of the side by side style.
Edit: figured I'd toss in the 89-91 single light support too...I am pretty sure this one would mount right up, would it not? Especially because I doubt Chevy spent the money to the fenders and core supports attachment any different.
1995 Suburban K2500 454.....off road & towing
1999 Astro, work van
2006 Silverado 2wd 5.3 w/4.5" lift and 33s
TheApocalyptican is offline   Reply With Quote
Old 12-06-2010, 11:37 AM   #2
bmchevy1979
bmchevy1979's Avatar
Re: Core support swap
Basically its just the arrangement of the lights and how they mount to the core you would need the whole front clip minus fenders and hood (they are the same)
<Brandon>
1974 Chevrolet K5 Blazer 350sbc/SM465/NP205, dana44 front, corp 14bolt rear with 4.10s and a powertrax locker, custom rear bumper 400sbc in the works.
1981 GMC C1500 stepside 250i6, 3spd, 12bolt with 3.08s 2.5/4drop on 15x10 with 275/50r15
81 GMC C3500 cab-chassis dually with utility bed 350sbc, Sm465, 14bolt with 4.10s nv4500 getting ready to go in
1979 Chevrolet K5 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434096
1976 Chevrolet C10 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434195
bmchevy1979 is offline   Reply With Quote
Old 12-06-2010, 03:11 PM   #3
TheApocalyptican
That's exactly what I was hoping it would be! Thanks!
Old 12-08-2010, 11:27 AM   #4
Jonboy
Slots go on anything!
It's not a really hard swap to do, you don't even need to take the fenders off. Make sure you get the light harness if you are going with the dual light front end; you may have to splice some wires too. Not too bad, as the colors stay the same.
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline   Reply With Quote
