Old 01-13-2018, 09:04 PM   #26
57larry
Re: Firewall holes for Vintage Air
good AC info, thanks
57larry is offline   Reply With Quote
Old 02-18-2018, 04:51 PM   #27
Perpendicular
For those with a smooth firewall, did you opt to not use the VA plate and if not, does the holes in the firewall they unit bolts through hold up to daily driving or would the plate really be necessary?
I am getting ready to drill the holes but wonder if I need the plate to give the unit some structure....
-Paul
Perpendicular is offline   Reply With Quote
Old 02-18-2018, 04:58 PM   #28
Perpendicular
Old 02-18-2018, 06:10 PM   #29
lux
I didn't use the VA plate, but I did use a bulkhead plate for the hoses. I didn't want to just put the hard lines through the fire wall. The difficulty in that I'd that you have to make up new hoses on the cab inside to replace those hard lines. And boy is it tight under there.
To answer your original question. The weight of the unit will be fine bolting directly to your firewall. The bracket also hangs on the inside of the under dash.
lux is offline   Reply With Quote
Old 02-19-2018, 12:07 AM   #30
lux
Old 02-20-2018, 01:28 PM   #31
TXgearhead67
I’m not trying to hijack your thread Elf. I too am planning to run the VA unit. I am going to shave the kick panel vents. When I do this there will be no need for the cowl vents. Am I correct? I want to weld them for a cleaner look. Also how does the VA kit get fresh air? Thanks fellas!
TXgearhead67 is offline   Reply With Quote
Old 02-20-2018, 03:44 PM   #32
lux
The.VA kit does not have a fresh air intake.
Old 02-20-2018, 03:58 PM   #33
69Tom
69Tom's Avatar
Not being a jerk, just curious: with the wing windows and the kick panel vents, is it a big issue? When I'm using the A/C here in Phoenix, I'm using it mainly on re-cyclical function. Having the unit where it is just processing extreme hot air over and over isn't nearly as effective.
Also, are there any aftermarket systems that maintain the ability to use fresh air?
69Tom is offline   Reply With Quote
Old 02-20-2018, 04:25 PM   #34
lux
I just put my VA kit in, so as of now I haven't seen fresh air necessary. I guess if I have a passenger that ate to much cabbage I'll just roll down the window.
I'm not sure if any other kits have fresh air.
Old 02-20-2018, 04:40 PM   #35
69Tom
69Tom's Avatar
LOL. Well, keep us posted how you find it once it gets hot out.
Old 02-21-2018, 07:59 PM   #36
elf w/capital T
Haha! Thanks guys! Love this forum!
elf w/capital T is offline   Reply With Quote
Old 02-21-2018, 08:58 PM   #37
argonaut
argonaut's Avatar
I've looked but not seen any aftermarket kits that have fresh air functionality. I'd be curious to know if anyone else has.
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
