01-16-2014, 01:18 AM | #401 |
Home Built '87
Re: 86 Silverado Father and Son project
Looking great!!
Gordon 1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424 1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833 Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969 |
01-16-2014, 05:05 PM | #402 | |
Thanks man
Thank ya |
02-02-2014, 12:59 AM | #403 |
The LS swap turned out great Landen, Looks like I should drop my truck off at mcbassins for some work after your spring semester something might actually get done on it
Dan <---(my name) 67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car |
02-02-2014, 01:52 AM | #404 |
Thanks Dan, bring it on over.
04-01-2014, 10:57 PM | #405 |
I've got a little update. The truck's been running great with very few issues. I'm still daily driving it.
I just wanted to post the total cost of the swap... Swap cost Donor truck..........................-600 Gas for pickup.......................-70 Trans fluid and coolant............-41 Wires....................................-9 Cam position sensor................-42 Oil pressure sensor.................-28 Fuel hose and clamps.............-15 Mufflers................................-67 Exhaust clamps.....................-23 Ujoint..................................-26 PCM reflash..........................-75 Fuse box, relays, teriminals....-40 Temperature sending unit.......-16 Wire loom.............................-7 Electrical tape.......................-3 Air filter................................-22 Cost.....................................-1,084 Truck scrap...............+442 Rear differential.........+250 Air bag set................+80 Airbag clock spring.....+55 Cat converters...........+40 Earned......................+867 Total cost...................-$217 Last edited by EightiesOnly; 04-01-2014 at 11:05 PM. |
05-11-2014, 03:08 PM | #406 |
Still Learning
Doing work....
05-21-2014, 02:54 PM | #407 |
Where did you get your pcm flashed for $75?
Have any drawings for the homemade swap mounts? |
05-22-2014, 01:31 PM | #408 | |
Still Learning
See attached drawings of the plates we made. I may have had to countersink holes for the RH side for the air conditioner compressor bracket. I can't remember for sure.
Mike "69 Short Wide" My Project 86 Silverado Landen's Project Instagram: @mcbassin My Website C/10 Club Oklahoma Facebook Group Last edited by mcbassin; 05-22-2014 at 01:59 PM. |
05-22-2014, 01:39 PM | #409 |
Very nice! Thanks. What CAD software you use? I use a lot of AutoCad & Inventor. Some solidworks and Pro-E as well.
05-22-2014, 01:54 PM | #410 |
Still Learning
Solidworks pretty much exclusive for modeling and drawings now. I have ProE on my machine but it's really cumbersome. I actually used FeatureCam modeling these and for machining. I can send you solid if you would like. I think we had to tweak them a little like I said but it was simple countersinks for metric flat head hardware.
05-22-2014, 01:56 PM | #411 |
What you sent is perfectly fine unless you just feel like sending me a .step file or something. Either way i will get a 1:1 and make some. Beats $100+ for the dirty dingo mounts I was thinking I was going to have to get.
05-22-2014, 02:00 PM | #412 |
Still Learning
Shoot me a pm with your email address.
06-18-2014, 09:24 PM | #413 |
Just a bit of an update here. First I swapped my cluster lamps out with these LED 10 SMD bulbs...
They make a big difference in brightness, hard to tell from the pic... Then I decided to wire up the all lamps on when on high beam set up, stole from project "Fred". I wired it up just like this. Relays Lows Highs There's a noticeable difference in brightness. This set up allows you to have lows on at all times and allows you to run heavier gage feeds straight from the battery to the lights. That's all for now. |
06-18-2014, 10:02 PM | #414 |
I really need to do that as well to the 89 front clip on my 79 4x4, that looks real nice with all 4 lit up,
I really need to look into the LED dash bulbs as well, my 87 is really dim, very hard to see at dusk, or on a cloudy day. -Sam
1987 Chevy R30 CC 454/4spd Work Truck 1979 Chevy K10 SWB 350/4spd/NP205, 1979 Chevy C10 LWB 350/TH350 Project 1981 Chevy K30 350/Th400/NP205 1986 Chevy K30 CUCV 6.2L/TH400/NP208 |
06-19-2014, 06:42 AM | #415 |
Nice work... you are becoming the wiring expert that your dad has always needed...
Mark ----------------------- Crash's 69 4x4 SWB Crash's Roof over Lake Home Crash's 1988 Land Cruiser Build |
06-19-2014, 08:39 AM | #416 | |
http://www.ledlight.com/t10-wedge-5-...led-light.aspx ...for my side markers and they're really bright. The side markers and cluster lamps are the same 194 wedge bulbs. Thanks, that's the plan! |
06-26-2014, 12:17 AM | #417 |
Another lighting update. I got these LED backup lamps on ebay...
...installed. Also put LED lamps in for my taillights. They're the same 194's as the instrument cluster. I'm pleased with the difference in brightness, here's side by side halogen and LED. |
06-29-2014, 02:05 PM | #418 |
Yet another light related update. I decided to make some underhood lighting.
I used two of these courtesy lights from an old car harness. I mounted one on each half of the hood and installed LEDs. I used a radio shack rocker switch. My original intent was to mount it directly to the hood but due to it being nut mounted I couldn't tighten the nut. I also tried to just thread a hole and screw it in but the three terminals on back are wider than the threads. So, instead of relocating it somewhere else I made a mounting bracket. This was a fun little project and total cost is about $7. I do still need to get an under hood insulation, which the lights should work just fine with. |
06-29-2014, 03:06 PM | #419 |
That is an excellent idea!
-Sam
06-30-2014, 11:11 AM | #420 |
07-27-2014, 07:29 PM | #421 |
A little update here.
First, back when we finished the swap I said the A/C could wait until spring. Well it's mid summer now and the A/C is way overdue. I had mcbassin make some one-off A/C lines by cutting fittings from the LS lines and welding them to the original A/C hoses (picked up at pull-a-part). This line is redirected out the side of the fitting. It's really the only way to do it without a large notch in the frame. He saved me a couple hundred dollars again because I simply don't have the welding skills to do this. I wired up the system like this. This is power straight from the original compressor feed (on with AC on) that goes through the compressor clutch then through the high pressure switch (normally closed until over pressured) on the LS comressor on its way to ground. The original compressor feed actually flows through the low pressure switch on the dryer, I just didn't draw it. I went ahead and got a new dryer and orfus tube and installed the lines. A small frame notch was needed for clearance of the upper line. The system held 110 psi of air for 20 hours, so we then evacuated it for about 18 hours and it held at about 0.01 psi so we charged it and it's working great so far! Also, I decided to install the LS cruise control. I was doing a preliminary test to confirm the outputs of the cruise buttons and the Set/Coast button (momentary on) wasn't working. After further investigation I found this. The wire was cut clean through, so I got a new turn signal lever. I used this chart and Ls1nova71's diagram as references to do the wiring. I mounted the cruise module on the drivers side inner fender which required a small bracket. I did this because there's simply no room for it on the firewall. That's all for now. |
07-28-2014, 01:32 AM | #422 |
You have done an excellent job on your truck. I had not read your thread until today (just finished reading it all the way through). Keep having fun with it and improving it.
C@rnut001 (Owen) Alaskan Members Check In http://67-72chevytrucks.com/vboard/s...22#post5094422 http://67-72chevytrucks.com/vboard/s...18#post6778618 |
07-28-2014, 11:18 AM | #423 |
Thanks for taking the time to read the thread. It's been fun taking the truck from a decent old truck to a solid one. And that's what this project is all about, cheap, easy, and fun!
07-28-2014, 03:13 PM | #424 |
I'm just glad to be here!
Nice truck and the extra's you did since the LS swap are a good touch.
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
07-29-2014, 04:44 PM | #425 |
Thank you, it looks your swap is going smoothly.
