Old 05-15-2013, 11:14 PM   #1
Dclassen
Dclassen's Avatar
Horn wiring?
Trying to get my horn working in my 72 blazer, bought a new one, but not sure how they are normally wired in these trucks. 1 or 2 wires? Any help would be appreciated thanks.
Dclassen is offline   Reply With Quote
Old 05-16-2013, 12:04 AM   #2
Slinger60
Slinger60's Avatar
Re: Horn wiring?
Most of them I have seen have one green wire.
1969 C10 LWB GMC.
1970 K5 Blazer
1971 K10 Burb
Build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=529970
Shawn
Slinger60 is offline   Reply With Quote
Old 05-16-2013, 01:31 AM   #3
Dclassen
Dclassen's Avatar
Re: Horn wiring?
Well I've got the right wire hooked up then. What could be preventing it from working? wires look good at least under the hood. A fuse maybe?
Old 05-16-2013, 03:53 AM   #4
Mint68
Mint68's Avatar
Re: Horn wiring?
My truck was missing all the horn components that are in or behind the steering wheel, leaving me with no horn. I'd make sure it has all the correct pieces first, and no wire issues. If you're not missing any parts, and the wires are all good, maybe the horn relay is bad.
Mint68 is offline   Reply With Quote
Old 05-16-2013, 04:26 AM   #5
Dclassen
Dclassen's Avatar
Re: Horn wiring?
The wires seem to be good and all there, I don't think anything is missing as it used to work. Is there something within the steering wheel that can break? I know my dad used to pound on the damn thing. I'm gonna attempt to replace the fuse if any first then I guess the relay. Thanks.
Old 05-16-2013, 01:27 PM   #6
Dclassen
Dclassen's Avatar
Re: Horn wiring?
Well I found the problem. Just have no idea whats going on with these wires. Theres nothing plugged into the relay, and what looks like the red green black wire for the relay wouldnt fit in it anyway, instead theres a single wire connected into the rgb wire. Hmmm..
Ideas? Sorry if I posted this in the wrong forum.
Old 05-17-2013, 03:36 PM   #7
gfreeze1025
gfreeze1025's Avatar
Re: Horn wiring?
I had same problem. I just bought an aftermarket horn kit from the parts store (autozone, advance, etc). ran the green, red, and black wires to the new kit. I also had to get a new modern style relay.
Horn works now.
Here is something similar to what I bought
http://www.amazon.com/Wolo-HWK-1-Horn-Wiring-Switc... http://www.amazon.com/Wolo-HWK-1-Horn-Wiring-Switc...
I can take picutures later tonight (If I can remember)
Gary
1971 K5 Blazer 350 V8
gfreeze1025 is offline   Reply With Quote
Old 05-17-2013, 09:30 PM   #8
Dclassen
Dclassen's Avatar
Re: Horn wiring?
Horn works now.
http://www.amazon.com/Wolo-HWK-1-Hor...words=horn+kit
I guess I'll pick up a new relay and one of those kits tomorrow. A pic of wiring would be appreciated, so I know how to hook it in that is. Thanks.
Old 05-25-2013, 11:23 PM   #9
gfreeze1025
Re: Horn wiring?
Did you ever get your horn working? I tried to get a few pics but my wiring is such a mess that you couldn't see anything.
I did order a new wiring kit and once that gets installed I will take pics.
Gary
