01-20-2018, 02:18 PM | #1 |
5 speed swap?
Ive been learning the 5 speed in my Fathers 4x4 Dodge Dakota, I've decided a 5 speed is what I want to put in my 72 k25. What 5 speed swaps are most common? And what will hold up to the abuse of a 4x4? My thought was an NV3500.
01-20-2018, 03:01 PM | #2 |
Post Whore
Re: 5 speed swap?
nv4500 is what you need..
01-20-2018, 03:02 PM | #3 |
Re: 5 speed swap?
Being a K25, I'd move up to a NV4500. My son's DD is a K1500, 350/NV3500 with 300,000 miles & the trans has held up well but I'd still go NV4500. (He has not owned it since new & during a recent clutch job we found markings on the trans that suggest it's been replaced)
BTW, you'll love the overdrive 5th! |
01-20-2018, 07:52 PM | #4 |
Re: 5 speed swap?
NV4500 sounds like a plan. I'll have to research into it and the swap.
01-20-2018, 07:56 PM | #5 |
Re: 5 speed swap?
I own a 91 f150 with the Mazda Overdrive 5th. When my Dad started teaching me to drive standard my neighbor offered it in trade for some yard work. Trucks in amazing shape. Only thing I need to do to get her on the road is a new clutch and new shoes on all 4 corners. Only problem is its not a Chevy
01-20-2018, 09:07 PM | #6 | |
The Older Generation
Re: 5 speed swap?
http://67-72chevytrucks.com/vboard/s...d.php?t=673588 LockDoc
01-21-2018, 02:33 AM | #7 |
Re: 5 speed swap?
The 4500 is what you're after. A bunch here have swapped them both married and divorced to the transfer case. Mine runs a divorced 205.
FWIW, the 4500 shifts like a Porsche compared to my old 465s and Clark 5. No regrets here.
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
01-21-2018, 10:57 AM | #8 |
Re: 5 speed swap?
Ive been digging around the forums and a couple others a 4500 seems like the route to go eventually
02-15-2018, 11:58 PM | #9 |
Active Member
Re: 5 speed swap?
Any issues with where the shifter comes up through the floor? Is your shifter now bumping the dash? Or hitting the seat when shifting. What engine are you using? Mines a 350 cu in
02-16-2018, 12:10 AM | #10 |
Active Member
Re: 5 speed swap?
02-16-2018, 12:23 AM | #11 |
Re: 5 speed swap?
IIRC the shifter moves rearward 8". No hitting the dash and clears the seat
02-16-2018, 12:28 AM | #12 |
Post Whore
Re: 5 speed swap?
when I swapped from the 465 to the 4500 my trans tunnel hole moved about 3" back..
